smajko Opublikowano 1 Kwietnia 2010 Opublikowano 1 Kwietnia 2010 Witam Przestal mi dzialac centralny z pilota z kluczykiem, co ciekawe dziala z pilota od alarmu, podpialem VAGa i to co dostalem: VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 LJ Component: 1,9l R4 EDC 0000SG 5934 Coding: 00002 Shop #: WSC 06325 WAUZZZ8E05A100440 AUZ6Z0D0383026 No fault code found. Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 4529 Coding: 04255 Shop #: WSC 06435 1 Fault Found: 01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30 35-10 - - - Intermittent Address 08 ------------------------------------------------------- Controller: 8E0 820 043 AA Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 06325 No fault code found. Address 09 ------------------------------------------------------- Controller: 8E0 907 279 F Component: int. Lastmodul RDW 0517 Coding: 00001 Shop #: WSC 06325 No fault code found. Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 S Component: Lenksáulenmodul 0611 Coding: 01012 Shop #: WSC 06325 2 Faults Found: 01749 - Switch for Tiptronic in Steering Wheel (E439): Down 29-00 - Short to Ground 00576 - Terminal 15 57-10 - Electric Circuit Failure - Intermittent Address 17 ------------------------------------------------------- Controller: 8E0 920 930 T Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 00001 Shop #: WSC 22438 WAUZZZ8E05A100440 AUZ6Z0D0383026 No fault code found. Address 37 ------------------------------------------------------- Controller: 4B0 919 887 E Component: BNS 4.2 H05 BNO 0050 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AS Component: Komfortgerát T01 1412 Coding: 06976 Shop #: WSC 06325 3 Faults Found: 00955 - Key 1 35-10 - - - Intermittent 00956 - Key 2 35-00 - - 01030 - Central Locking Key Switch: Driver Side: Lock 27-10 - Implausible Signal - Intermittent Address 56 ------------------------------------------------------- Controller: 8E0 035 186 D Component: concert II GRO 0004 Coding: 01013 Shop #: WSC 06325 No fault code found. End ------------------------------------------------------- Jeszcze jedna uwaga, musialem odlaczyc aku na chwile bo mialem problem z alarmem, byc moze czesc tych bledow ma z tym zwiazek choc przejechalem ze 20km wiec powinny poznikac Pomoże ktos jak sobie z tym poradzic? Pozdro
domjenick Opublikowano 1 Kwietnia 2010 Opublikowano 1 Kwietnia 2010 skasuj błędy i zobaczysz,czy się znów pojawią
smajko Opublikowano 2 Kwietnia 2010 Autor Opublikowano 2 Kwietnia 2010 tego sie wlasnie troche obawiam bo moje auto mnie troche zaskoczylo, podczas odpalania fury rano zamknely sie wszystkie drzwi i przestalo dzialac ich otwieranie z kluczyka i ze srodka, no i wyjacy alarm musiala mnie zona ratowac drugim kluczykiem Po tej akcji odlaczylem aku bo nie dalo sie niczym wylaczyc alarmu, no i wszystko wrocilo do normy (oprocz tego ze otwieranie z kluczyka dalej nie dziala) WYglada to na jakies zwarcie w ukladzie, raczej nie chce zeby sie sytuacja powtórzyła dlatego troche sie boje kasowania tych bledow ;( aaaaa no i odpalanie fury zawsze z otwartymi drzwiami tez przestaje byc fajne
