[B5 ALF] Proszę o analizę błędów
Czy mam się czym martwić? Ewentualnie, jak pozbyć się tych błędów lub czym są spowodowane i jakie mogą mieć skutki? :)
Thursday,09,August,2007,16:55:01:64983
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 4B0 907 552 F
Component and/or Version: 2.4L V6/5V MOTR HS D02
Software Coding: 05001
Work Shop Code: WSC 06335
15 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
P0150 - 35-10 - - - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-10 - - - Intermittent
17547 - Fuel Trim: Bank 2 (Add): System too Rich
P1139 - 35-10 - - - Intermittent
17538 - Fuel Trim; Bank 2 (Mult): System too Lean
P1130 - 35-10 - - - Intermittent
17645 - Fuel Injector for Cylinder 1 (N30): Open Circuit
P1237 - 35-10 - - - Intermittent
17646 - Fuel Injector for Cylinder 2 (N31): Open Circuit
P1238 - 35-10 - - - Intermittent
17647 - Fuel Injector for Cylinder 3 (N32): Open Circuit
P1239 - 35-10 - - - Intermittent
17648 - Fuel Injector for Cylinder 4 (N33): Open Circuit
P1240 - 35-10 - - - Intermittent
17649 - Fuel Injector for Cylinder 5 (N83): Open Circuit
P1241 - 35-10 - - - Intermittent
17650 - Fuel Injector for Cylinder 6 (N84): Open Circuit
P1242 - 35-10 - - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
17834 - EVAP Purge Valve (N80): Open Circuit
P1426 - 35-10 - - - Intermittent
Readiness: N/A
