1,8 adr błędy
witam wszystkich,po lilku dniach walki z podłączeniem vag-coma dzis udało mi sie w koncu połączyc:)miałem problem z falowaniem obrotów ale po adaptacji i skasowaniu błędów jak ręką odjął.pozostało mi tylko cos takiego:moze ktos wie co one oznaczają??
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 557 S
Component: 1,8L R4/5V MOTR HS D03
Coding: 04001
Shop #: WSC 06335
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 111
Component: ABS 5.3 FRONT D11
Coding: 0273004132
Shop #: BB 24303
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 B
Component: A4 KLIMAVOLLAUTOMAT_D72
Coding: 04140
Shop #: WSC 06335
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 034 F
Component: B5-KOMBIINSTRUMENT__D12
Coding: 00042
Shop #: WSC 00000
Address 25 -------------------------------------------------------
Controller: 4A0 953 234
Component: IMMO AUZ9Z0W5254039 D77
Coding: 00000
Shop #: WSC 76619
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 E
Component: ZV-Pumpe
Coding: 00000
Shop #: WSC 65535
16 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm: Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm: Open
01362 - Close Switch for Tailgate/Trunk (F124)
01363 - Switch for Central Locking: Driver's Door (F59)
27-00 - Implausible Signal
01364 - Switch for Central Locking: Passenger Door (F114)
01365 - Lock/Unlock Switch: Interior
28-00 - Short to B+
End -------------------------------------------------------
Coding: 00000
Shop #: WSC 76619
1 Fault Found:
01176 - Key
Problem z immobilizerem, trzeba sprawdzić połączenie kabelków czytnika klucza i modułu
Opis w Warsztacie.
Pozostałe są od centralnego i alarmu
