[B5 ADR] Logi lambda - analiza
Panowie
Prośba aby ktoś kto zna sie na tych cyferkach powiedział mi coś na temat sondy LAMBDA.
Logi robiłem w grupie 7, 8 i 9, na wolnych obrotach, rozgrzanym silniku i na LPG.
(od razu przepraszam za ta formę wklejenia logów, ale bardziej czytelnie nie potrafię :()
Pozdr
Group A:,'007
Lambda Voltage Duty Cycle (no units)
STAM %, V %
1.09 -0.8 0.685 16.8 0.96
2.75 0.8 0.235 17.2 0.96
4.46 -0.8 0.710 16.8 0.96
6.13 -3.1 0.595 16.8 0.96
7.76 0.0 0.210 18.0 0.95
9.48 1.6 0.695 18.8 0.96
11.18 -1.6 0.600 18.8 0.96
12.84 0.0 0.725 19.1 0.96
14.47 -1.6 0.235 19.1 0.96
16.20 1.6 0.505 19.5 0.96
17.88 0.8 0.215 19.5 0.96
19.55 0.8 0.725 19.9 0.96
21.21 1.6 0.230 19.9 0.97
22.93 3.1 0.755 21.1 0.98
24.62 0.0 0.695 20.7 0.98
26.27 1.6 0.460 21.1 0.98
28.03 -2.3 0.580 21.1 0.98
29.60 0.8 0.215 21.5 0.98
31.18 0.8 0.715 21.9 0.98
32.84 0.0 0.200 21.9 0.98
34.58 1.6 0.610 22.7 0.99
36.20 -1.6 0.630 22.7 0.99
37.80 0.0 0.200 23.0 0.99
39.54 1.6 0.735 23.8 1.00
41.27 1.6 0.200 23.8 1.00
42.90 3.1 0.695 24.6 1.01
44.58 3.1 0.255 24.6 1.02
46.30 -0.8 0.690 24.6 1.02
47.93 -3.1 0.540 24.6 1.02
49.61 0.0 0.215 25.4 1.02
Group B:,'008
Time Lambd Lambda
STAMP ms % % -
0.00 2.64 -13.3 21.1 TankVent ON
1.63 2.46 -13.3 21.1 TankVent ON
3.34 2.55 -13.3 21.1 TankVent ON
4.98 2.46 -13.3 21.1 TankVent ON
6.68 2.46 -13.3 21.1 TankVent ON
8.31 2.55 -13.3 21.1 TankVent ON
10.07 2.55 -13.3 21.1 TankVent ON
11.73 2.55 -13.3 21.1 TankVent ON
13.36 2.46 -13.3 21.1 TankVent ON
15.05 2.55 -13.3 21.1 TankVent ON
16.76 2.55 -13.3 21.1 TankVent ON
18.45 2.55 -13.3 21.1 TankVent ON
20.07 2.46 -13.3 21.1 TankVent ON
21.81 2.55 -13.3 21.1 TankVent ON
23.51 2.55 -13.3 21.1 TankVent ON
25.21 2.46 -13.3 21.1 TankVent ON
26.83 2.46 -13.3 21.1 TankVent ON
28.53 2.46 -13.3 21.1, TankVent ON
30.14 2.55 -13.3 21.1 TankVent ON
31.75 2.55 -13.3 21.1 TankVent ON
33.45 2.55 -13.3 21.1 TankVent ON
35.13 2.55 -13.3 21.1 TankVent ON
36.74 2.46 -13.3 21.1 TankVent ON
38.36 2.55 -13.3 21.1 TankVent ON
40.12 2.55 -13.3 21.1 TankVent ON
41.81 2.64 -13.3 21.1 TankVent ON
43.48 2.64 -13.3 21.1 TankVent ON
45.15 2.64 -13.3 21.1 TankVent ON
46.83 2.55 -13.3 21.1 TankVent ON
48.50 2.55 -13.3 21.1 TankVent ON
Group C:,'009
RPM Lambda Voltage Lambda
STAMP min % V %
0.56 870, 0.0 0.730 -13.3
2.21 860, -0.8 0.225 -13.3
3.91 860, 0.8 0.725 -13.3
5.54 860, -2.3 0.695 -13.3
7.22 860, -0.8 0.205 -13.3
8.90 860, 2.3 0.255 -13.3
10.63 870, 0.0 0.710 -13.3
12.29 870, 0.8 0.245 -13.3
13.92 860, -1.6 0.665 -13.3
15.65 870, 0.8 0.245 -13.3
17.31 860, -0.8 0.555 -13.3
19.00 860, 1.6 0.625 -13.3
20.61 860, 0.8 0.210 -13.3
22.39 860, 3.9 0.260 -13.3
24.05 870, 0.8 0.700 -13.3
25.72 860, 0.8 0.220 -13.3
27.43 870, -1.6 0.720 -13.3
29.08 850, 0.0 0.200 -13,3
30.69 860, 1.6 0.610 -13.3
32.28 860, -1.6 0.675 -13.3
34.03 860, 1.6 0.265 -13.3
35.66 850, 0.0 0.670 -13.3
37.27 860, -0.8 0.240 -13.3
38.94 860, 2.3 0.245 -13.3
40.68 860, 0.0 0.355 -13.3
42.35 860, 3.1 0.235 -13.3
44.03 870, 2.3 0.425 -13.3
45.77 860, 0.8 0.730 -13.3
47.38 860, -2.3 0.700 -13.3
49.07 860, -0.8 0.200 -13.3
[br]Dopisany: 11 Listopad 2007, 15:22 _________________________________________________Wiem że tego typu tematów jest wiele i forma w jakiej przedstawiłem logi jest nie najlepsza.
Trochę sam poszukałem i znalazłem link do pliku z parametrami jakie powinny być (zakresy).
I więc:
w grupie 8: - kolumna 3 powinna być w zakresie od -12 do +12% a jest -13,3%
- kolumna 4 powinna być w zakresie od -12 do +12% a jest 21,1%
w grupie 9: - kolumna 4 powinna być w zakresie od +0,1 do +0,3 i od +0,7 do +1 V a jest w niektórych miejscach poza zakresem
Pytanie jest czy to wszystko może być oznaką padniętej sondy i czy przyczyną jest co innego??
Pozdr
Wszystko zależy od tego jaką masz instalację:
- jeżeli II gen. to możesz logi wyrzucić do kosza ze względu na emulację sondy
- jeżeli IV gen. to proponuję porządnie ją wyregulować, ale przynajmniej widać, że sonda działa.
LPG sekwencja stag 300.
Czy logi lepiej robić na Pb czy LPG???
Bo jak robiłem na Pb to w grupie 8 pojawił sie taki znaczek - zakreślony na czerwono poniżej.
Co to jest???
Sunday 11 November 2007 10:33:31
8D0 907 557 S 1.8L R4/5V MOTR HS D03
Group A: '008
Time Lambda Lambda
TIME
STAMP ms % %
5.61 2.89 -15.6 21.1 TankVent ON
6.18 2.89 -15.6 21.1 O2 Adapt.
Zależy na jakie pytanie chcesz uzyskać odpowieć ?
