[ALL Audi] Akcje serwisowe - spis.
Witam,
We wnęce koła zapasowego w swoim A4 mam wlepkę o wykonanej akcji serwisowej o numerze 23B2 zastanawiałem się czego ona dotyczyła :mysli:
W sieci znalazłem taki spis akcji:
(czcionką pogrubioną oznaczyłem te które dotyczą A4)
WORKSHOP ACTIONS
Camp no Type Vehicles Description TOTAL Launch
AU 17C1 W 8E Oil pump drive bolt 28 08/01/2005
AU 21B2 W 4E Turbo charger linkage 529 27/02/2005
AU 72B6 W 8P Seat anchor pins 3088 04/03/2005
AU 34D1 W 8E, 4E Gearbox shield 34611 13/05/2005
AU 15D3 W 4F 8E Cylinder head sealing plugs 484 13/10/2005
AU 57C3 W 8E Remote control keys 9753 22/11/2005
AU 23A1 W 4F Tdi Engine ECU update 1546 20/12/2005
AU 72A1 W 8N RECARO seats 436 07/01/2006
AU 20L6 W 8E Accelerator pedal module 231 18/01/2006
AU 19E4 W 4E Cooling system scaling 3080 06/02/2006
AU 19E6 W 8P Retaining clips for radiator 8507 23/03/2006
AU 46E6 W 4E Software update for EPB 2660 22/04/2006
AU 13D3 W 4F Vibration damper 25 09/07/2006
AU 13C8 W 4F Belt tensioner - 2.7 Tdi 815 09/07/2006
AU 40G1 W 4E Front suspension mounting 832 19/07/2006
AU 20J8 W 8E 4B Replacement of fuel pump 670 11/08/2006
AU 20L9 W 8E 8H 4F Replacement of hose holder 2520 11/08/2006
AU 19E3 W 8P O-ring for coolant adapter 1078 23/08/2006
AU 55E2 W 8J (TT) Bonnet sealing plugs 487 13/09/2006
AU 40G8 W 8J TT Front suspension 372 15/09/2006
AU 92B5 W 4F5 Rear washer pipe 1639 10/10/2006
AU 37D1 W 4F, 8E, 8H ECU update 2.7l TDI 556 07/10/2006
AU 43A7 W 4F Update ECU self levelling suspension 474 07/10/2006
AU 37C9 W 8E 8H 4F Software update for Multitronic gearbox 2007 07/10/2006
AU 21A1 W 4F 8E Turbocharger 2.7l TDI 917 07/10/2006
AU 55D7 W 4E Bootlid drive motor 1393 09/10/2006
AU 55D8 W 4E Bootlid hinges 963 09/10/2006
AU 97L2 W 4E (S Radiator fan wiring 125 10/10/2006
AU 48H6 W 4F 4L Software update FBS 22787 30/11/2006
AU 44G4 W 4L Update owner’s handbook 7 30/11/2006
AU 23B2 W 8E 8H 8P Update ECU (DPF) 1175 30/11/2006
AU 66C1 W 8J (TT) Rear spoiler 2323 14/12/2006
AU 13D4 W 3.0 ltr TDI Vibration damper 490 02/01/2007
AU 87B2 W 8J 8P Blower motor ECU 488 02/01/2007
AU 28E3 W 8P Glowplug glow timing relay 1158 01/02/2007
AU 42C9 S 8N Rear axle ball joints 5395 11/10/2001
AU 45B3 S 8L ABS control unit 99 12/07/2002
AU 69E1 S AUDI Driver's airbag 544 26/10/2002
AU 47J4 S 8L Brake vacuum pipe 21709 21/08/2003
AU 47J6 S A3 8P Rear left brake pipe 821 17/03/2004
AU 20L1 S 8E 4E Tandem fuel pump 14820 16/12/2004
AU 94C3 S 8H Headlight reflectors 1079 10/05/2005
AU 69F7 S 4F Airbag ECU update 5767 21/10/2005
AU 44G1 S 4D 4E Michelin Pilot Sport 255/35ZR20 97Y 414 10/01/2006
AU 13C7 S 8P Twin-mass flywheel 8586 24/02/2006
AU 69G3 S 8P Replacing curtain airbags 90 06/09/2006
AU 69B2 S 4E Replacement of driver's airbag 1727 09/10/2006
może komuś też się przyda :)
przydatny wątek. Może podpiąć go wyżej?? :cool1:
co prawda dopiero po założeniu tego wątku udało mi się znaleźć drugi praktycznie taki sam
wrazie czego niech mod go skasuje
Gdzie mogę znaleźć wyjasnienie tej akcji serwisowej:
EDIT
Znalazłem wyjasnienie w drugim bliźniaczym temacie. Tu link -> http://www.a4-klub.pl/smf/index.php?topic=66085.0;highlight=akcje+serwisowe :hi:
  • 2 lata później...
A ja bym się chciał dowiedzieć coś bliżej o tej akcji
Czego ona dotyczyła, co nowego wnosiła i czy po usunięciu DPFa ktoś kto zmieniał soft w sterowniku to musiał ten update wywalić? Wydaje mi się że silnik co jakieś 300-400 km lekko telepie właśnie tak jak podczas wypalania filtra. Czy jest możliwe że ta poprawka nie została wywalona ze sterownika i dalej on zmienia kąt wtrysku jak podczas wypalania filtra.
pozdrawiam
