[B6 BAU] quattro kombi po czyszczeniu -NEW PHOTO :notworthy:
Witam Panowie.. I Panie :wink4:
Zdjęcia sa z ogłoszenia to tez sorry za jakość
Jutro sobota - zrobię nowe.
Silnik BAU 2.5 TDi 180km Tip i quattro
Wyposazenie
W0A = Summer campaign a/c u.k.
7A2 = CD changer
4UE = airbag for driver and front seat passenger
6XD = outer rear view mirrors: powered, heated
5SL = outer left rear view mirror: non-spherical
5RU = outer right rear view mirror: convex (large viewing field)
1KP = disc brakes, rear
J1T = battery 300 A (66 Ah)
1BE = sports suspension/shock absorption
3FA = without roof insert (standard roof)
5TD = decorative aluminum inserts
7X1 = ultrasonic park distance control
4R4 = power windows with comfort operation andcircuit breaker
F0A = no special purpose vehicle, standard equipment
8GU = alternator 140A
0G7 = Tiptronic
0YK = weight category rear axle weight range 10
0JK = weight category front axle weight range 10
T1K = components for, base engine, unit 059.E
3NZ = rear seat bench unsplit, backrest split folding
8EB = twin headlamp, for driving on the right (gas discharge) with integrated high beam (US design)
U2A = instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
X0A = national sales program Germany
1N1 = power steering
2PV = leather trimmed sports steering wheel
8Q3 = automatic headlight-range adjustment dynamic (self-adjusting while driving)
9Q4 = multi-function indicator/on-board computer with check control
8Z5 = engine cooling system, type 1
MR1 = 6-cylinder diesel engine 2.5 L/132 kW 24V TDI with fuel distributor injection pump, base engine is T1K/T5T
7Q9 = navigation system
CD0 = alloy wheels 7 1/2J x 17 Alu-5, offset 45
7K0 = without tire pressure warning light
4X3 = side airbag front with curtain airbag
VJ1 = reinforced bumpers
6R0 = selector lever cover
3L3 = manual height adjustment for front seats
4KC = side and rear windows tinted
3Y0 = without roll-up sun screen
4K4 = radio remote controlled central locking operated from inside and separate trunk release
5D1 = carrier frequency 433.92 MHz
1SA = without additional engine guard
0GZ = emissions concept EU 3
Q1D = sports front seats
4GH = windshield tinted with windshield sunshield
ja nic nie widzę - żadnych zdjęć :gwizdanie:
no, bida, zadnych rycin nie widac ... :mysli: :mysli: :mysli:
Juz poprawione;) :good:
Auto ładne, ale tego byka w tytule wątku to mógłbys poprawić :facepalm:
LOL Dzieki Majkiel :notworthy:
Jako ze jestem pełen podziwy dla tego rodzaju napędu pozostanie tak jak jest. Czyli z wielkiej :naughty: :>
Niepoprawnie.
Pełen bedziesz po zimie :)
jak gdzies zawiśniesz to Ci przejdzie... :polew: :polew: :polew: :polew:
Niepoprawnie.
Hahah
To nawet nie wchodzi w gre :D:evil: :evil: :> :>
wystarczy zaspa....
Nie no pewnie . Lepiej w zime w domu zostac.
A tak na serio jest ktoś z Warszawy z Vagiem ? Chciałbym zmienić język w Fis na angielski :hi:
Jest. Pisz na PW :)
Z chęcią przejadę się tipem :naughty: [nigdy jeszcze nie miałem okazji] :decayed:
Nowe photo
Jest. Pisz na PW :)
Ja smigalem w 2.5TDI tylko w b5 i odstaje toto od manuala :thumbdown:
Furmanka bardzo ladna :good: W tym silniku tez sie sypie hydraulika??
Hydraulika w 2,5tdi B** (poza BFC) to konstrukcyjnie takie samo rozwiązanie jak 3,0tdi
Hydraulika w 2,5tdi B** (poza BFC) to konstrukcyjnie takie same rozwiązanie jak 3,0tdi
czy aby na pewno?? Myslalem ze wlasnie BFC ma "rolki" jak w 3.0TDI :mysli: Musze sie chyba doksztalcic :wink4:
  • 5 tygodni później...
Andy dobrze mowi :naughty:
V. ROCZNIKI MODELOWE 2004 oraz 2005
W produkcji RM'2004 znalazły się cztery dotychczas niespotykane, wręcz "rewolucyjne" jednostki silnikowe:
1. BCZ i BAU - spełniające normę spalin EURO3
2. BDG i BDH - spełniajace warunki normy spalin EURO4
Najważniejszą wspólną cechą wyrózniają wwym. silniki jest zupełnie nowa, inna konstrukcja "lekkich", wieloelementowych wałków rozrządu oraz ułożyskowanych dźwigni zaworowych.
W następstwie wprowadzonych zmian:
- wyeliminowano zupełnie problemy wadliwych rozrządów (wycierające się krzywki, spadające dźwignie zaworowe, etc. odeszły w niepamięć)
- uzyskano o ok. połowę mniejsze opory wewnętrzne silnika (mniejsze zużycie paliwa, inna łagodniejsza akustyka, mniejsze obciążenie paska rozrządu)
Przy okazji warto zauważyć, że nowy rodzaj wałków rozrządu wraz ze zmodernizowanym osprzętem (dźwignie, hydropopychacze) – praktycznie już bez kolejnych ulepszeń – przeniesiono do jeszcze nowszych silników (czyli do 2.7TDi, 3.0TDi, 4.0TDi oraz 4,2TDi) i praktycznie w niezmienionej formie są produkowane do dnia dzisiejszego ... .
BFC to jak by nie patrzec AYM
Dla silników 155PS AYM bardzo podobnie do AKE również nie nastąpiła żadna zmiana konstrukcyjna, lecz dotychczasową moc 155PSów i płaski moment obrotowy 310 Nm - podniesiono odpowiednio do 163 PSów z zachowaniem dotychczasowych 310 Nm momentu obrotowego, dostępnego w przedziale od 1400 do aż 3600 obr/min.
Wczesniejszy kod silnika AYM zastąpiono kodem BFC. [br]Dopisany: 25 Lipiec 2011, 13:15_________________________________________________Po czyszczeniu felg wygląda znacznie lepiej ;)
