Odp: [B5 AJM] Prośba o diagnozę
Moge podpiac sie pod temat i poprosic o analize kodow?
Logi wykonane na AJM z wlaczonym zaplonem, bez zapalania motoru.
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 AN
Component: 1,9l R4 EDC 0000SG 1301
Coding: 00002
Shop #: WSC 63251
4 Faults Found:
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-00 - -
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
P1156 - 35-10 - - - Intermittent
17569 - Manifold Temp Sensor (G72): Open or Short to Plus
P1161 - 35-00 - -
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00012
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D58
Coding: 00044
Shop #: WSC 63251
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 980 J
Component: B5-KOMBIINSTR. VDO D12
Coding: 00440
Shop #: WSC 10001
XXXXXXXXXXXXXXXXX AUZ7Z0Y1646232
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 63251
11 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00991 - Interior Lights
28-00 - Short to B+
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 63251
6 Faults Found:
01403 - Glass-Break Sensors: Rear
36-10 - Open Circuit - Intermittent
01380 - Alarm triggered by Anti-Theft Sensor: Rear Left
35-00 - -
01381 - Alarm triggered by Anti-Theft Sensor: Rear Right
35-00 - -
01382 - Alarm triggered by Anti-Theft Sensor: Front Left
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor: Front Right
35-00 - -
01384 - Alarm triggered by Glass Breakage Sensor
35-00 - -
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 E
Component: Radio 0001
Coding: 00201
Shop #: WSC 63251
End -------------------------------------------------------
Dzieki
AVE
16706 temu nie odpala
Znalazlem na forum informacje ze ten blad zawsze jest wyswietlany przy nie uruchomionym motorze.
Mysle ze ma to sens.
Kolo rozrzadu nie kreci sie, wiec nie moze wyslac zadnego impulsu czujnikowi.
Czy sie myle?
mylisz sie
Wydzieliłem wątek bo się bałagan robi...
Dzieki za wydzielenie watku i za informacje;)
Co teraz?
Kasowac bledy, sprawdzic polaczenia wszystkich wywalonych czujnikow i skarowac jeszcze raz?
blad od halla pojawial sie zawsze w starych sterownikach od benzyn, nie dotyczy to diesli
spradz kabelkologie od halla a jak jest ok, wymien czujnik
auto wogole odpala ?
Błędy w sterowniku silnika wskazują na to, że ktoś odpinał wtyczki od czujników i jeśli błędy nie dają się skasować to pewnie wtyczki wiszą luźno z G71/72 i G62 a G28 albo uszkodzony albo wisi sobie na wiązce w komorze silnika wykręcony z bloku albo kuna zrobiła sobie trochę miejsca na legowisko wygryzając wiązki.
A no to podstawą jest je skasować zanim zamieści się temat bo trzeba najpierw zobaczyć czy się dadzą skasować wszystkie czy któreś zostaną a jeśli zostaną to które i wtedy pisać prośbę o pomoc a wcześniej jeszcze użyć wyszukiwarki google wpisując interesujący kod błędu i czytać co należy w takim przypadku sprawdzić.
Przyjme 200 :gwizdanie: za swa niefrasobliwosc i brak wiedzy :kox:
Bledy dalo sie bez problemu skasowac. Nic nie wraca, niestety auta nadal nie moge odpalic;(
PS. Motor zapala na samostarcie pryskanym bezposrednio w dolot.
Wydaje mi sie ze problem tkwi w zasilaniu paliwa.
Wtryski sprawdzone i wymyte w profesjonalnym warsztacie.
Ustawione wg schematu:
Dla nowego typu wtyczki:
Cylinder Wymiar „a“
1. 333,0 ± 0,8 mm
2. 245,0 ± 0,8 mm
3. 153,6 ± 0,8 mm
4. 65,6 ± 0,8 mm
Wykrecone o 225
Organoleptycznie sprawdzono pompe paliwa (ta w baku) tzn podlaczylem bezposrednio + pod stopke bezpiecznika nr 28.
Ps2. Jak sprawdzic czy przy odpalaniu listwa wtryskow zasilana jest paliwem?
Np. zmierzyć ciśnienie paliwa na pompie tandem - jest w niej specjalne przyłącze do manometru, podać paliwo na pompę tandem z oddzielnego źródła z pominięciem filtra paliwa itd.
pryskasz i jak odpali to normalnie chodzi na ropie juz ? czy jak zabierzesz samostart to gasnie ?
do sprawdzenia rozrzad i pompa tandemowa :)[br]Dopisany: 01 Grudzień 2011, 21:25_________________________________________________i sprawdz w logach czy jak krecisz rozrusznikiem czy liczy obroty
Pytanie;
1. Gdzie wkrecamy manometr zeby sprawdzic pompe tandemowa i jakie cisnienie powinna osiagnac?
2. Gdzie pokaze sie info w VAGu ze komp liczy obroty?
3. Czy moge przeleciec VAGiem silnik podczas gdy motor bedzie chodzil zasilany samostartem?
Pytam bo slyszalem ze nie jest wskazana dlugotrwala praca silnika na samostarcie.
Dzieki za wskazowki.
PS. Rozrzad zalozony tak samo jak przed naprawa- 100% pewnosci bo sam robilem.
no na samostarcie lepiej by nie chodzil zrob taK;
zaplon on, polacz sie z silnikiek, bloki poom, grupa 01 go i w 1 polu masz obr, patrz na nie i krec rozrusznikiem, zobacz czy liczy obr
Zgadza sie.
Przyskrzynilem kabel od czujnika i dlatego nie bylo sygnalu.
Czujnik wymieniony, autko odpalilo za pierwszym razem.
Zdaje mi sie ze nawet ciszej chodzi -wtryski wykrecone o 225
PS. Sa dwa czujniki - dolny polozenia walu pod filtrem paliwa i Hella w glowicy.
:good:
Złoża ropy za stodoła teraz moge zyczyc :polew:
