Adr3k Opublikowano 28 Lutego 2012 Opublikowano 28 Lutego 2012 Witam mam pytanko co 2-3 dni nie mogę z rana odpalić autka poniżej logi co z tym zrobić z tym immo i reszta błędów VAG-COM Version: Release 311.2-N 1o9lo0m-n6r12p-o9ko4x-kkjahh-568f Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: 038 906 019 AN Component: 1,9l R4 EDC G000SG 1301 Coding: 00002 Shop #: WSC 63351 2 Faults Found: 18058 - Powertrain Data Bus: Missing Message from Instrument Cluster P1650 - 35-10 - - - Intermittent 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8D0 907 389 D Component: ABS/ESP front D56 Coding: 04255 Shop #: WSC 06325 No fault code found. Address 08 ------------------------------------------------------- Controller: 8D0 820 043 Q Component: A4 KLIMAAUTOMAT D58 Coding: 00043 Shop #: WSC 63351 No fault code found. Address 15 ------------------------------------------------------- Controller: 8D0 959 655 J Component: Airbag Front+Seite 1001 Coding: 00106 Shop #: WSC 63351 No fault code found. Address 17 ------------------------------------------------------- Controller: 8D0 920 931 Component: B5-KOMBIINSTR. VDO D07 Coding: 00040 Shop #: WSC 05311 ˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙ AUZ7Z0X1196943 1 Fault Found: 01176 - Key 07-10 - Signal to Low - Intermittent Address 25 ------------------------------------------------------- Controller: Bitte Adress Component: e 17 eingeben No Faults Found or DTCs not supported by controller or a communication error ocurred Address 35 ------------------------------------------------------- Controller: 8D0 862 257 Component: ZV-Pumpe, DWA, Funk D16 Coding: 14913 Shop #: WSC 27341 No fault code found. Address 56 ------------------------------------------------------- Controller: 8D0 035 195 Component: Radio D00 Coding: 00204 Shop #: WSC 05311 1 Fault Found: 65535 - Internal Control Module Memory Error 00-00 - -
machina Opublikowano 28 Lutego 2012 Opublikowano 28 Lutego 2012 Wygląda na to że pętla zamontowana na stacyjce nie wyłapuje sygnału z pastylki w kluczyku i raczej w tym kierunku szukałbym problemu. Sprawdzałeś na innych kluczach?
Adr3k Opublikowano 28 Lutego 2012 Autor Opublikowano 28 Lutego 2012 na drugim kluczu tak samo ok zajrze pod kiere w wekeend i zobacze co i jak a co z resztą błędów ???
machina Opublikowano 28 Lutego 2012 Opublikowano 28 Lutego 2012 Błędy w adresie 01 oraz 17 to właśnie immo, a błąd w adresie 56 to coś z radiem. Więcej błędów nie masz:)
Adr3k Opublikowano 16 Marca 2012 Autor Opublikowano 16 Marca 2012 Witam ponownie sprawdziłem pod kierą wszystko wygląda ok ale co zaobserwowałem błąd immo powraca jak autka nie używam np 1 dzień jak codziennie używam to jest ok wystarczy 1 dzień przerwy i problem powraca Proszę o jakieś sugestie Dziękuję
machina Opublikowano 16 Marca 2012 Opublikowano 16 Marca 2012 Co prawda nie słyszałem jeszcze o takim przypadku, ale może ma to związek z akumulatorem, może już niedomaga przy odpalaniu i brakuje prądu dla elektroniki immo. Czy rozpinałeś połączenia od modułu immo przy stacyjce? może coś nie łączy.
Adr3k Opublikowano 17 Marca 2012 Autor Opublikowano 17 Marca 2012 dzisiaj juz niestety nie odpala pojechałem do rodziców i musiałęm dzwonić po szwagra zeby z lapkiem podjechał ale lapkiem nic nie mogłem zdiałać pomogło odpięcie klemy na min nie wiem o co biega ktoś pomoze ???? po 1 min migania immo zaczyna tez migać kontrolka świec też dziwne
