witjacrf Opublikowano 26 Października 2012 Opublikowano 26 Października 2012 Witam jest to mój pierwszy post i pierwszy scan auta jeśli chodzi o VAG,proszę o wyrozumiałość i czy o tych logach możecie coś powiedzieć co nie tak? Friday,26,October,2012,10:24:15:46862 VCDS Version: Release 10.6.0 Data version: 20100630 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E52A287847 Mileage: 196730km/122242miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-019-AVF.lbl Part No: 038 906 019 JL Component: 1,9l R4 EDC G000SG 1519 Coding: 00002 Shop #: WSC 63351 VCID: 6AD0C0F67A25FF4C WAUZZZ8E52A287847 AUZ6Z0B0060898 No fault code found. Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04255 Shop #: WSC 06435 VCID: E5CA33CA133B5034 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 J Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 00000 VCID: 2854FAFEA4A90D5C 2 Faults Found 00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 30-10 - Open or Short to Plus - Intermittent 00825 - Drivers Seat Heating Element (Z6) 31-10 - Open or Short to Ground - Intermittent ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00011 Shop #: WSC 63351 VCID: 346C1E8E686179BC No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 Component: Airbag 8.4E 5001 Coding: 0010602 Shop #: WSC 63351 000 00000 VCID: F4EC5E8EA8E1B9BC No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 L Component: Lenksáulenmodul 0308 Coding: 00042 Shop #: WSC 63351 VCID: 3C7C36AE4031B1FC No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 900 G Component: KOMBI+WEGFAHRS. RB4 D26 Coding: 00000 Shop #: WSC 19411 VCID: 2854FAFEA4A90D5C WAUZZZ8E52A287847 AUZ6Z0B0060898 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl Part No: 8E0 959 433 AD Component: Komfortgerát T85 0316 Coding: 06976 Shop #: WSC 63351 VCID: 73EEDD922DEF3E84 Part No: 8E1959801 Component: Tőrsteuer.FS BRM 0002 Part No: 8E1959802E Component: Tőrsteuer.BF BRM 0002 1 Fault Found 01561 - Left Rear Door 61-10 - Won't De-Safe - Intermittent ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D07 Coding: 00060 Shop #: WSC 63351 VCID: 040C8E4E7841093C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 186 Component: concert II GRO 0008 Coding: 00201 Shop #: WSC 63351 VCID: E4CC2ECE1801293C No fault code found. End ---------------------------------------------------------------------
grejf Opublikowano 26 Października 2012 Opublikowano 26 Października 2012 kody blędów http://a4-klub.pl/diagnostyka-vag-32/kody-vag-update-2012-05-30-a-1134/
witjacrf Opublikowano 26 Października 2012 Autor Opublikowano 26 Października 2012 30-10 takiego kodu np nie mogę znaleźć.
spanky Opublikowano 26 Października 2012 Opublikowano 26 Października 2012 30-10 takiego kodu np nie mogę znaleźć. bo to nie jest numer kodu tylko charakter usterki
witjacrf Opublikowano 26 Października 2012 Autor Opublikowano 26 Października 2012 Jak ten błąd tłumaczyć albo co to i do czego służy: Nr błędu: 00604 Tłumaczenie: VCDS / VAG-COM: uitleg - tips - trics
pakotomasz Opublikowano 26 Października 2012 Opublikowano 26 Października 2012 Mi sporadycznie także pojawia się błąd 01561 w 46-Moduł komfortu. Raz jest raz go nie ma podczas scanowania. Problemu z drzwiami, sygnalizacją na wyświetlaczu nie mam, więc jak na razie się tym nie przejmuję. Kasuję błąd i jeżdżę dalej;)
