prosze o pomoc
Witam, mam problem zeby okreslic dokladnie co boli moje autko
po skanowaniu pokazuje mi taki blad
Control Module Part Number: 8E0 909 518 AA
Component and/or Version: 1.8L R4/5VT G 0004
Software Coding: 0011701
Work Shop Code: WSC 63351
1 Fault Found:
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded - Intermittent
wiki mówi tak:
[h=2]16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached[/h] [h=4]Possible Symptoms[/h]
  • Reduced Power Output
  • Limp Mode
[h=4]Possible Causes[/h]
  • Hoses/Pipes incorrect connected, disconnected or leaking
  • Charger Pressure Control defective
  • Turbocharger faulty
  • Diverter Valve faulty
[h=4]Possible Solutions[/h]
  • Check Hoses/Pipes to/between Components
  • Check / Clean / Replace Charge Pressure Control
  • Check Turbocharger
  • Check Diverter Valve
[h=4]Special Notes[/h]
  • When found in 2.0l TFSI:
    • Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06H-145-710-D (or newer).
      • RoW vehicles see: TPI 2016331 for details.
      • NAR vehicles see: TSB 01-07-70 or 2013392 for details.
      [*] When stored in conjunction with misfire codes and/or fuel trim faults see the notes associated with the following faults regarding PCV failure: Crankcase Breather Valve
    [*] If the Turbocharger is faulty due to mechanical / internal problems or the exhaust system is restricted (typically the Catalyst) this fault may be the end result.
    [*] When found in VW Golf/Jetta (1K): 2.0l CR-TDI (CBEA/CJAA):
    • Verify the mechanical part of the Exhaust Valve Control Module (J883) is not siezed or binding
nie wiem czy znasz ta strone czy nie ale przynajmniej spróbowałem :hi:
turbina nie osiąga zadanego cisnienia doładowania
problem z doładowaniem, za niskie
dziura, WG, DV, N75, odma,
@amaradaar a po polskiemu nie masz ??
@devastation
moze mi wyjasnisz podane przez Ciebie terminy i gdzie ich szukac ??
obrazki by wiele pomogly :)
a wujek Google nie działa ?
zadzwon do mnie jutro to powiem Ci co i jak
nr ponizej
Zrób logi dynamiczne 2,115,118
Też miałem ten błąd, wszystko sprawdzane szczelne, DV wymieniony
Dopiero jak przeczyściłem zawór N75 pomogło i nie ma błędów
a logi dynamiczne to jak sie robi dla mojego silniczka 1.8T ?
znalazlem info ze 3 bieg i zakres od 1500-6000 obrotow - dobrze mysle ?
Tak, pedał w podłogę na 3 biegu
ok, zrobie :)
oto logi
Log (6 - 002,115,118)
przecież gdybym miał to specjalnie na złość nie wstawiałbym po angielsku :P
trza by chyba uzyć translatora :P
:kox::hi:
hiehie probowalem to przetlumaczyc i wychodzi cos na kształt "Kali kochać, Kali skrócic" :)
dzieki za dobre checi:)
ok, zrobie :)
oto logi
Auto po programie i dośc ostrym
Ile masz przebiegu.
Turbina późno wstaje może jakaś nieszczelnośc
ciśnienie zadane osiągnięte dopiero przy 3600obr u mnie około 2700 ale pewnie katalizator trzyma
dobrze ci się zbiera od dołu? pewnie trochę muł
od 5000obr wtryski zapętlają
zrób logi kanału 20 pewnie bedzie cofać zapłony
masz LPG? logi na PB?
Porównuje ze swoimi logami auto też mam po programie
przebieg 180k tyle licznik pokazuje
jezdze na benzynce
poprzedni wlascicle twierdzi ze autko po programie, ale nie ma na to papieru
Jakie lekarstwo na to ?
pierwsze sprawdź szczelność sprężarką, jak szczelne to pewnie kat tłumi.jak nie chcesz kata wycinać to trzeba zmienić program bo dość ostry.
Zamulone auto niskich obrotach?
Co z tego że jest 185 koni jak mulasty od dołu do 3500obr tak wygląda
na niskich obrotach idzie jak niemiecki czolg,
takie autko kupilem ja nie czuje roznicy miedzy 160 a 185 kucy
jak sprawdzic szczelnosc sprezarka ? i do jakiego cisnienia dobic ?
Ciśnienie 1,5bara wystarczy
w tym 1 filmiku podajemy cisnienie na wlocie turbiny po stronie powietrza ?
co do wyciecia katalizatora, czy jak wytne to nie bedzie bledow na lamdzie ?
Kata zostaw w spokoju. sprawdź zawór odcinający DV, szczelność układu. Jeśli nie pomoże to podmień zawór N75.
jak sprawdzic poprawnosc zaworu DV?
trzeba go wymontowac i zapodac ciśnienie
i podciśnienie :wink:
przez N75 trzeba zapodac ciśnieni i sprawdzic czy szczelny
żeby wyeliminowac uszkodzenie klapy WG wystarczy zdjąc węzyk od aktuatora, zaslepic go i sie przejechac
jak auto dostało "kopa" turbo jest oki
ale ostrożnie aby nie przesadzic bo mozna je uszkodzic
---------- Post dopisany at 17:31 ---------- Poprzedni post napisany at 17:20 ----------
0.75 bara
