rav85 Opublikowano 29 Stycznia 2013 Opublikowano 29 Stycznia 2013 8 Faults Found: 16804 - Catalyst System; Bank 1: Efficiency Below Threshold P0420 - 35-00 - - 17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low P1103 - 35-10 - - - Intermittent 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent 17947 - Clutch Pedal Switch (F36): Implausible Signal P1539 - 35-10 - - - Intermittent 18057 - Powertrain Data Bus: Missing Message from ABS Controller P1649 - 35-10 - - - Intermittent 16795 - Secondary Air Injection System: Incorrect Flow Detected P0411 - 35-10 - - - Intermittent 18043 - Powertrain Data Bus: Missing Message from A/C Controller P1635 - 35-10 - - - Intermittent 18058 - Powertrain Data Bus: Missing Message from Instrument Cluster P1650 - 35-10 - - - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Component: ABS/ESP front 1326 Coding: 04275 Shop #: WSC 00011 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 J Component: A4 Klimaautomat 1116 Coding: 00000 Shop #: WSC 63351 2 Faults Found: 01172 - Temperature Sensor; Driver's Heated Seat (G59) 30-00 - Open or Short to Plus 01171 - Temperature Sensor; Passenger Side Heated Seat (G60) 30-00 - Open or Short to Plus ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 B Component: int. Lastmodul NDL 1512 Coding: 00012 Shop #: WSC 00060 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 Component: Airbag 8.4E 3001 Coding: 0010602 Shop #: WSC 63351 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 F Component: Lenksáulenmodul 0304 Coding: 00011 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 930 L Component: KOMBI+WEGFAHRS. RB4 D36 Coding: 00130 Shop #: WSC 00054 WAUZZZ8E12A039109 AUZ6Z0A0139057 1 Fault Found: 01300 - Control Module for Navigation with CD-Rom (J401) 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 37: Navigation Labels: None Part No SW: 8H0 035 192 T HW: 8H0 035 192 T Component: RNS-E HIGH EU H99 0750 Revision: 02S Serial number: AUZBZ7K0325417 Coding: 0311111 Shop #: WSC 50911 142 52718 1 Fault Found: 02261 - Data Medium 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 5 Fault Frequency: 1 Reset counter: 102 Time Indication: 0 Date: 2012.12.22 Time: 10:47:08 Freeze Frame: Mileage: 655350 km Count: 2212 Clock: 10:57 ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0504 Coding: 00001 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl Part No: 8E0 959 433 AJ Component: Komfortgerát T9F 0619 Coding: 06762 Shop #: WSC 00060 Part No: 8E1959801B Component: Tőrsteuer.FS BRM 4.11 Part No: 8E1959802B Component: Tőrsteuer.BF BRM 4.11 5 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01562 - Right Rear Door 61-10 - Won't De-Safe - Intermittent 01559 - Drivers Door 61-10 - Won't De-Safe - Intermittent 01331 - Door Control Module; Driver Side (J386) 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: None Part No SW: 8H0 035 192 T HW: 8H0 035 192 T Component: RNS-E HIGH EU H99 0750 Revision: 02S Serial number: AUZBZ7K0325417 Coding: 0311111 Shop #: WSC 50911 142 52718 1 Fault Found: 02261 - Data Medium 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 5 Fault Frequency: 1 Reset counter: 102 Time Indication: 0 Date: 2012.12.22 Time: 10:47:08 Freeze Frame: Mileage: 655350 km Count: 2212 Clock: 10:57
siwy2326 Opublikowano 29 Stycznia 2013 Opublikowano 29 Stycznia 2013 Spróbuj na początek wykasowac wszystkie i zobacz jakie zostaną być może te usterki co wrzuciles są naprawione a kody nie wykasowane.
grzes1150 Opublikowano 29 Stycznia 2013 Opublikowano 29 Stycznia 2013 Wykasuj błędy bo większość to błędy sporadyczne. Powoli pada katalizator. Jaki masz przebieg na zegarach?????
rav85 Opublikowano 29 Stycznia 2013 Autor Opublikowano 29 Stycznia 2013 katalizator wymieniłem wiec błędy kata odpadają , czujnik sprzęgła tez , przebieg oryginalny 314tys
