dawid.bary Opublikowano 29 Sierpnia 2013 Opublikowano 29 Sierpnia 2013 Audi A4 B6 19TDI 131KM VAGLOG - wklej logi z VCDS/VAG-COM VAGLOG - wklej logi z VCDS/VAG-COM VAGLOG - wklej logi z VCDS/VAG-COM VAGLOG - wklej logi z VCDS/VAG-COM VAGLOG - wklej logi z VCDS/VAG-COM VAGLOG - wklej logi z VCDS/VAG-COM VAGLOG - wklej logi z VCDS/VAG-COM VAGLOG - wklej logi z VCDS/VAG-COM VAGLOG - wklej logi z VCDS/VAG-COM Oraz sprawdzenie błędów: VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 LJ Component: 1,9l R4 EDC 0000SG 4910 Coding: 00002 Shop #: WSC 63251 No fault code found. Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 3429 Coding: 04255 Shop #: WSC 79014 No fault code found. Address 08 ------------------------------------------------------- Controller: 8E0 820 043 AC Component: A4 Klimaautomat 1319 Coding: 00000 Shop #: WSC 63251 No fault code found. Address 09 ------------------------------------------------------- Controller: 8E0 907 279 F Component: int. Lastmodul RDW 0517 Coding: 00111 Shop #: WSC 00012 No fault code found. Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 S Component: Lenksáulenmodul 0611 Coding: 01012 Shop #: WSC 63251 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 930 R Component: KOMBI+WEGFAHRS. RB4 D38 Coding: 00000 Shop #: WSC 65535 WAUZZZ8E64A122957 AUZ6Z0C0348655 No fault code found. Address 37 ------------------------------------------------------- Controller: Note: Excessive Comm Errors Address 46 ------------------------------------------------------- Controller: 8E0 959 433 BA Component: Komfortgerát TA7 1310 Coding: 06976 Shop #: WSC 63251 No fault code found. Address 55 ------------------------------------------------------- Controller: 4Z7 907 357 Component: dynamische LWR D09 Coding: 00060 Shop #: WSC 63251 No fault code found. Address 56 ------------------------------------------------------- Controller: Note: Excessive Comm Errors End -------------------------------------------------------
ganjaq Opublikowano 29 Sierpnia 2013 Opublikowano 29 Sierpnia 2013 Vag nie znajduje żadnych błędów co by mogło wskazywać na to że raczej wszystko z Twoją b6 w porządku, powiedz na jakiej podstawie podajesz logi, co się dzieje z autem że testujesz je Vagiem? Na kanale 37 masz Error bo nie masz nawigacji a na 56 nie wiem dlaczego, być może masz niestandardowe radio
dawid.bary Opublikowano 29 Sierpnia 2013 Autor Opublikowano 29 Sierpnia 2013 silnik się dosyć mocno kołysze i coś czasami stuka na postoju, poza tym chciałem sprawdzić czy wszystko w porządku, co do błędów to pewnie dlatego że wymieniałem nawigację w samochodzie z RNS-D na RNS-E nie wiem czy mam to jakoś zaadoptować wagiem wymianę czy wystarczy skasować błędy, dzięki za pomoc
