Prośba o analize błędów
Thursday,28,November,2013,19:31:12:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8T0
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 56 5F 62 72
VIN: WAUZZZ8K7BN000555
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAGB) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 019 C HW: 03L 906 019 AL
Component: R4 2,0L EDC H25 8428
Revision: 25H25---
Coding: 0A194012232403080000
Shop #: WSC 00317 211 182561
ASAM Dataset: EV_ECM20TDI03L906019C A02006
ROD: EV_ECM20TDI03L906019C.rod
VCID: 2B5F1975421E111
2 Faults Found:
5456 - Starter Will Not Turn
P3054 00 [096] - Jammed or Electrical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
4113 - Camshaft Position Sensor (G40)
P0341 00 [096] - Implausible Signal
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
Component: ESP8 front H04 0030
Revision: -------- Serial number: --------------
Coding: 160504
Shop #: WSC 02391 823 56573
VCID: 7EF9E021E9EC549
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CC HW: 8K0 907 064 CC
Component: BCM2 2.0 H04 0430
Revision: 00002001
Coding: 032100
Shop #: WSC 02399 823 56573
VCID: 73EFC115D2AE091
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H50 0070
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AG HW: 8T1 820 043 AG
Component: KLIMA 1 ZONE H08 0180
Revision: A0000000 Serial number: 01110520101626
Coding: 34380000
VCID: 76E9F801C1DC1C9
1 Fault Found:
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 93
Mileage: 183619 km
Time Indication: 0
Date: 2013.11.25
Time: 22:26:32
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 K HW: 8K0 907 063 K
Component: BCM1 1.0 H29 0380
Revision: 06029001 Serial number: 00000000672703
Coding: 690040B10134A7000001000000005F5F001C020806000101000000
VCID: 377735058656A51
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 190510 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
1 Fault Found:
00978 - Lamp for Low Beam; Left (M29)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 183446 km
Time Indication: 0
Date: 2013.11.21
Time: 19:19:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51241013011708
Coding: 100003
VCID: 479745C5F6B6D51
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 J HW: 8K0 959 655 J
Component: AirbagVW-AU10 H41 0610
Serial number: 003GKD0GAE8E
Coding: 30343435363030303030554A304C384B3053
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 448D52C9CF80FE9
Crash sensor for side airbag; driver side:
Serial number: 6334MSME5311553D9
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME53017330$
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME01614A0A9
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME2B540B26J
Crash sensor for front airbag; driver side:
Serial number: 63732SME7A5E0A28C
Crash sensor for front airbag; passenger side:
Serial number: 63832SME005F0900T
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304JEC00085
Coding: 000016
Shop #: WSC 00317 211 88755
VCID: 3D7B272DA46A8F1
Component: E221 - MFL H02 0010
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E1051200F1
Coding: 00CF07
VCID: 830F11D5020EB91
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H16 0038
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 N HW: 8T0 959 793 B
Component: TSG FA H07 1401
Coding: 011002204000410001
VCID: 54AD628937E06E9
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0130517054
Coding: 011E062000B904408320013680000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 75
Reset counter: 135
Mileage: 183401 km
Time Indication: 0
Date: 2013.11.20
Time: 16:57:57
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 N HW: 8T0 959 792 B
Component: TSG BF H07 1401
VCID: 53AF619532EE691
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000643857
Shop #: WSC 00000 000 00000
VCID: 346D020997204E9
Address 56: Radio ® Labels: Redir Fail!
Part No SW: 4G0 035 056 HW: 4G0 035 056
Component: Radio U STD H51 0051
Revision: AB001007 Serial number: 469DZ0A7501059
Coding: 010003020100000001
VCID: DEB900A1C92C349
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 666 F HW: 8T1 035 666 E
Component: H-BN-EU H49 0107
Revision: -------- Serial number: 483E 0A7627191
Coding: 010100000106C3ED01000F0D000000030001
Subsystem 1 - Part No: 8R0 060 884 R
Component: EUR 2010 1107
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 93
Mileage: 183618 km
Time Indication: 0
Date: 2013.11.25
Time: 21:29:41
Freeze Frame:
Bin. Bits: 00000001 00000000
Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1401
Coding: 010002204000210001
VCID: 56A99881211C7C9
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H06 1401
End ---------------------------------------------------------------------
Dziękować :hi:
