koscielny Opublikowano 8 Kwietnia 2014 Opublikowano 8 Kwietnia 2014 Witam, Jak w temacie, proszę o pomoc w analizie błędów: Monday,24,March,2014,21:40:29:10074 VCDS Version: Release 10.6.4 (x64) Address 01: Engine Labels: None Control Module Part Number: 8E0 909 552 HW: 8E0 909 052 Component and/or Version: 2.4L V6/5V 0004 Software Coding: 0011501 Work Shop Code: WSC 63351 000 00000 VCID: EBD1439FB315 1 Fault Found: 16502 - Engine Coolant Temp. Sensor (G62): Signal too High P0118 - 002 - Lower Limit Exceeded - MIL ON Readiness: 0010 1001 VCDS Version: Release 10.6.4 (x64) Data version: 20110418 Monday,24,March,2014,21:48:47:10074 Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E02A199711 Mileage: 227360km/141274miles ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 8E0 909 552 HW: 8E0 909 052 Component: 2.4L V6/5V 0004 Coding: 0011501 Shop #: WSC 63351 000 00000 VCID: EBD1439FB315 No fault code found. Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04395 Shop #: WSC 00000 VCID: E5C535A755F1 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 A Component: A4 Klimaautomat 0712 Coding: 00000 Shop #: WSC 63351 VCID: 1F49E74FB72D 1 Fault Found: 00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 30-10 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 E Component: int. Lastmodul NDL 0305 Coding: 00002 Shop #: WSC 63351 VCID: 346318E32EAB No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 Component: Airbag 8.4E 4001 Coding: 0011602 Shop #: WSC 63351 000 00000 VCID: F4E358E3EE2B No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 F Component: Lenksáulenmodul 0308 Coding: 00001 Shop #: WSC 63351 VCID: 366722EB38D7 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 900 H Component: KOMBI+WEGFAHRS. RB4 D26 Coding: 00100 Shop #: WSC 19411 VCID: 295DF997F969 WAUZZZ8E02A199711 AUZ6Z0A0328326 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl Part No: 8E0 959 433 AG Component: Komfortgerát T87 0315 Coding: 06720 Shop #: WSC 63351 VCID: 76E7E2EB7857 Part No: 8E1959801B Component: Tőrsteuer.FS BRM 0002 Part No: 8E1959802B Component: Tőrsteuer.BF BRM 0002 4 Faults Found: 01561 - Left Rear Door 59-00 - Can't Unlock 01561 - Left Rear Door 61-00 - Won't De-Safe 01562 - Right Rear Door 59-10 - Can't Unlock - Intermittent 01562 - Right Rear Door 61-10 - Won't De-Safe - Intermittent End --------------------------------------------------------------------- Pozdrawiam,
czarownik3 Opublikowano 8 Kwietnia 2014 Opublikowano 8 Kwietnia 2014 Nic poważnego, Takie same jak u mnie : 1.Czujnik G62 płynu chłodniczego kup w serwisie, bo jak kupiłem na aledrogo i 1.5 roku znowu mu odwala , objaw padnietego czujnika to wentylatory chodzą na maksa zaraz po odpaleniu. 2. Silniczek klapy w klimatroniku - naprawa zdemontować schowek , zlokalizować padnięty silniczek będzie słychać dłuższą prace od pozostalych. Zdemontować na smarować klapę i przekręcić to kółeczko w miejsce nie wytarte i będzie czasach. 3. Nie otwieranie się drzwi mam wypadało by rozebrac wyczyścić , czytałem że padają krancowki , olałem. Silnik nie terkocze przy odpalaniu ? Zrób logi dynamiczne przeplywki i zmiennych faz rozrządu.
koscielny Opublikowano 29 Kwietnia 2014 Autor Opublikowano 29 Kwietnia 2014 wentylatory póki co nie świrują ale check engine mnie denerwuje; tym bardziej, że nie dawno jeszcze tego nie było (zauważyłem ten błąd po powrocie autka po regulacji u gazownika); może coś zmajstrował przypadkiem :/ z pozostałymi tematami muszę zająć się dopiero po świętach jak wrócę z delegacji :/ wówczas zaktualizuję posta dzięki póki co ---------- Post dopisany 29-04-2014 at 21:32 ---------- Poprzedni post napisany 09-04-2014 at 02:36 ---------- Witam ponownie i ponawiam prośbę o analizę nowych/starych błędów: chcę dodać, że wymieniłem ostatnio czujnik g62, po czym pokasowałem błędy; przejechałem ponad 300km łącznie i zaświeciła mi się kontrolka air baga poniżej wszystkie błędy, które odczytałem: 17546 - Fuel Trim: Bank 2 (Add): System too Lean P1138 - 001 - Upper Limit Exceeded - Intermittent Readiness: 0000 0000 1 Fault Found: 01316 - ABS Control Module 49-10 - No Communications - Intermittent 49-10 - No Communications - Intermittent 1 Fault Found: 01217 - Side Airbag Igniter; Driver Side (N199) 007 - Short to Ground - MIL ON 007 - Short to Ground - MIL ON 5 Faults Found: 01561 - Left Rear Door 59-00 - Can't Unlock 01561 - Left Rear Door 61-00 - Won't De-Safe 01562 - Right Rear Door 59-10 - Can't Unlock - Intermittent 01562 - Right Rear Door 61-10 - Won't De-Safe - Intermittent 01804 - Door Warning Lamp; Rear Right (W38) 28-10 - Short to Plus - Intermittent 28-10 - Short to Plus - Intermittent 1 Fault Found: 00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 30-10 - Open or Short to Plus - Intermittent 30-10 - Open or Short to Plus - Intermittent 1 Fault Found: 01494 - Bulb for Parking Lamps; Left (M1) 57-00 - Electric Circuit Failure 57-00 - Electric Circuit Failure Błedu z lampą oraz z poduszką powietrzną po wykasowaniu pojawiają się od razu z powrotem; Proszę o pomoc w powyższym temacie, w czwartek szykuje mi się znów dłuższa trasa i pytanie czy mogę bez większych (przynajmniej) obaw wyjechać moją A4 Chciałem przy okazji zapytać czy ktoś się spotkał z podobnym problemem odnośnie kabla VCDS; zakupiłem ostatnio takowy, działał mi bez problemu zaraz po wymianie wspomnianego wcześniej czujnika, czy to ma moim autku, czy na znajomego A4; dziś jednak nie mogłem się za chol... usb OK; Interface: not found pożyczyłem kabel od kolegi i śmiga, mój nie; możliwe, że go trafiło? zauważyłem różnicę, że na dobrym kablu kontrolka (dioda) na kablu zapala się dopiero po wpięciu kabla do gniazda; na moim pali się bez tego od razu jest szansa coś z tym zrobić, reanimować kabel? z góry dzieki za wszelaką odpowiedź, szczególnie odnośnie mojej obawy nt mozliwości czwartkowego wyjazdu z powyższymi błedami
