szakal222 Opublikowano 21 Czerwca 2014 Opublikowano 21 Czerwca 2014 witam czy ktorys z szanownych forumowiczow ,moglby mi powiedz za co odpowiadaj te bledy,wyskoczyla mi dzisiaj czykita i stwierdzilem ze nie lapie o co biega ,auto pali normalnie jezdzi mi sie wydaje tez ,co trzeba naprawic wymienic ? Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 8E0 906 018 B Component: 1.8L R4/5VT 0004 Coding: 11701 Shop #: WSC 63351 AUZ6Z0A0155115 2 Faults Found: 17964 - Charge Pressure Control: Negative Deviation P1556 - 35-10 - - - Intermittent 16804 - Catalyst System: Bank 1: Efficiency Below Threshold P0420 - 35-00 - - Readiness: 0000 0000 Address 03 ------------------------------------------------------- Controller: 8E0 614 517 A Component: ABS/ESP allrad 1326 Coding: 04275 Shop #: WSC 00070 No fault code found. Address 08 ------------------------------------------------------- Controller: 8E0 820 043 A Component: A4 Klimaautomat 0711 Coding: 00000 Shop #: WSC 63351 5 Faults Found: 00710 - Defroster Flap Positioning Motor (V107) 41-10 - Blocked or No Voltage - Intermittent 00601 - Potentiometer On Positioning Motor for Central Flap (G112) 30-10 - Open or Short to B+ - Intermittent 01841 - Potentiometer/Actuator for Temperature Flap: Left (G220) 30-00 - Open or Short to B+ 00716 - Air recirculation Flap Positioning Motor (V113) 41-10 - Blocked or No Voltage - Intermittent 00819 - High Pressure Sensor (G65) 30-00 - Open or Short to B+ Address 09 ------------------------------------------------------- Controller: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00001 Shop #: WSC 63351 No fault code found. Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenksáulenmodul 0304 Coding: 00011 Shop #: WSC 63351 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 950 G Component: KOMBI+WEGFAHRS. RB4 D21 Coding: 01000 Shop #: WSC 00000 WAUZZZ8E42A045499 AUZ6Z0A0155115 1 Fault Found: 01304 - Radio 49-00 - No Communications Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AF Component: Komfortgerát T03 0315 Coding: 06720 Shop #: WSC 63351 6 Faults Found: 01702 - Footwell Lighting: Left (W9) 29-10 - Short to Ground - Intermittent 01703 - Footwell Lighting: Right (W10) 29-00 - Short to Ground 01697 - Footwell Lighting: Rear Right (W46) 29-00 - Short to Ground 01802 - Door Warning Lamp: Pass Side (W36) 57-10 - Electric Circuit Failure - Intermittent 01561 - Left Rear Door 61-00 - Won't De-Safe 01334 - Door Control Module: Rear Right (J398) 80-00 - Single-Wire Operation End -------------------------------------------------------
edekxp Opublikowano 21 Czerwca 2014 Opublikowano 21 Czerwca 2014 Pewnie check bo katalizator już lupny.Wstaw emulator.Dodatkowo masz coś, z ciśnieniem doładowania - nie osiągnięta górna granica. Sprawdź szczelność i zrób logi 02,20,33,115,118.Reszta błędów to klimatronik,elektryka + radio Jakieś zwarcia żarówej oświetlenia nóg przód lewy i prawy oraz tył lewy.Oświetlenie drzwi pasażera Zamek tylny lewy Skasuj błędy i zobacz które powrócą
szakal222 Opublikowano 21 Czerwca 2014 Autor Opublikowano 21 Czerwca 2014 ok dzieki wielkie bede mial co robic czyli kata wyciac ?a co do doladowania ,moze byc winna dv ,bo dziwnie chodzila ,jakby parskala
