koscielny Opublikowano 7 Października 2014 Opublikowano 7 Października 2014 hej,Prośba o pomoc w analizie błędów: 7 Faults Found: 18057 - Powertrain Data Bus P1649 - 008 - Missing Message from ABS Controller - Intermittent 16805 - Warm Up Catalyst; Bank 1 P0421 - 001 - Efficiency Below Threshold 17537 - Fuel Trim; Bank 2 (Mult) P1129 - 002 - System too Rich - Intermittent - MIL ON 17546 - Fuel Trim: Bank 2 (Add) P1138 - 001 - System too Lean 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - - Intermittent 16685 - Cylinder 1 P0301 - 001 - Misfire Detected - Intermittent 16725 - Camshaft Position Sensor (G40) P0341 - 004 - Implausible Signal - Intermittent Readiness: 0000 0001 1 Fault Found: 65535 - Internal Control Module Memory Error 00-00 - - 00-00 - - 4 Faults Found: 01561 - Left Rear Door 59-10 - Can't Unlock - Intermittent 01561 - Left Rear Door 61-00 - Won't De-Safe 01562 - Right Rear Door 59-10 - Can't Unlock - Intermittent 01562 - Right Rear Door 61-00 - Won't De-Safe 61-00 - Won't De-Safe dziękuję z góry! Pozdrawiam,
