lapidem 1 Opublikowano 28 Maja 2015 Udostępnij Opublikowano 28 Maja 2015 (edytowane) Auto jak auto nic szczególnego jeszcze. Jedna z pierwszych fotek I nadeszła pora na kilka aktualnych zdjęć W moim posiadaniu od 2014.10W Polsce od 2011.Przebieg przy zakupie to jakieś 240 tkm Audi Akoya Silver Metallic - LY7H Wyposażenie:0G1 Gearshift lever0GG Emission standard eu40JH Weight category front axle weight range 80YK Weight range 10 installation control only, no requirement forecast1BA Standard suspension/shock absorption1KD Disc brakes, rear1LB Disc brakes, front1MR Leather steering wheel1N1 Power steering1SA Without additional engine guard1SA Without additional front underbody guard2K1 Reinforced bumpers3FA Without roof insert (standard roof)3L3 Manual height adjustment for front seats3NZ Rear seat bench unsplit, backrest split folding3Y0 Without roll-up sun screen4GH Windshield in heat-insulating glass with sunshield4K4 Radio remote controlled central locking4KC Side and rear windows in heat-insulatingglass4R5 Power windows with comfort operation andcircuit breaker, mechanical window regulators rear4UE Air bag for driver and front seat passenger4X3 Side air bag front with curtain air bag5D1 Carrier frequency 433.92 mhz-434.42 mhz5MA Decorative inserts5RU Right exterior mirror: convex (large viewing field)5SL Left exterior mirror: aspherical6XD Exterior mirrors: electrically adjustable/heated7A0 Without cd changer/cd player7K0 Without tire pressure warning light7Q9 Navigation system7X0 Without park distance control8GU Alternator 140 a8JH Ellipsoidal headlight for driving on the right8Q1 Headlight-range adjustment9Q4 Multi-function display/on-board computerwith check controlCR7 Steel wheels 6.5j x 15E0A No special editionF0A No special purpose vehicle, standard equipmentJ1D Battery 380 a (72 ah)M3L 4-cyl. turbo diesel engine 1.9 l/85 kw tdi with pump-jet injection system base engine is t4n/td0Q1A Standard front seatsTD0 4-cylinder diesel engine 1.9 l unit 03g.5U2A Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometerX2C National sales program the netherlandsznalazłem zestaw głośnomówiący bluetooth Naprawy/zmiany/modyfikacje-nowy termostat Wahler + 3l koncentratu Febi G12+ 3l wody destylowanej ;]-wymiana modułu od zegara radiowego-profilaktyczne czyszczenie EGRPlany do wymiany/zrobienia -plastiki podszybia 8E1819447 - podszybie + 8E1819422A - klapka akumulatora - zrobione-nowe pióra wycieraczek Bosch lub Valeo 4B0998002 - założone Valeo, ale chyba zmienie na Boscha-felgi 17" S-Line na lato - zakupione 5K0601025F + Bridgestone Potenza 050 + nowe 4 X OPONY DUNLOP SPORT MAXX RT 225/45R17 2015 ROK-Led w podświetlenie tablicy z Audi A5 - zrobione-podgrzewane spryski mgiełkowe - zrobione-podświetlane dekory - zrobione -ciemne szyby cały tył zrobione 2014.11.18 Wymiana 4B0919145A na nowy moduł 8K0919145A z A4 B8 rozwiązała problem braku palemki od zegara sterowanego radiowo w 15 minut. Moduł kupiony na allegro za 35 zł z przesyłką i gwarancją :> Dodam że na sprawnym module napięcie na kabelkach wynosi 5V, a na uszkodzonym było ok 4VStary moduł po rozebraniu wyglądał tragicznie - elementy z płytki się utleniły zardzewiały - generalnie rozsypał się ;]2014.12.03Profilaktyczne czyszczenie EGR :> Nie było tragicznie ale jest lepiej Sezon 2015 ;]Felunek 17" kontra 15" Edytowane 1 Czerwca 2016 przez lapidem Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
andr3i 1 Opublikowano 28 Maja 2015 Udostępnij Opublikowano 28 Maja 2015 fotki wnetrza poprosimy Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
lapidem 1 Opublikowano 5 Czerwca 2015 Autor Udostępnij Opublikowano 5 Czerwca 2015 (edytowane) zdjęcia środka będą dopiero po praniu tapicerki po poprzednim właścicielu ... czekam własnie na dystanse 25mm i 20mm , jak przyjdą będzie małe sesyjka i pojawi się kilka fotek Edytowane 7 Lutego 2016 przez lapidem Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
muunv 80 Opublikowano 13 Czerwca 2015 Udostępnij Opublikowano 13 Czerwca 2015 Ciekawy projekt się szykuje Powodzenia i czekam na foty Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
lapidem 1 Opublikowano 18 Września 2015 Autor Udostępnij Opublikowano 18 Września 2015 (edytowane) Mały updejt zakupowy Przy okazji prac nad hamulcami nowe przewody elastyczne na przód i tył od kolegi dzik z forum 2015.09.03 wymiana przewodów i rozrządu przebieg 255tys oraz oryginalny rozrząd również zakupiony u kolegi z forum doszedł do tego jeszcze pasek od osprzętu, ale już kupiony na szybko ;] i kilka zdjęć z prac nad hamulcami stare tarcze jeszcze mają znaczek OOOO :> nowe ferodo/textar Tarcze jeszcze nie były może w stanie tragicznym, ale jak wymieniać to kompleksowo Przy okazji trysnąłem szprajem zaciski po taniości :> i wymieniłem gumeczki i smar. Na pewno nie jest to zrobione tak perfect jak po regeneracji od Dev, ale na chwilę wystarczy Doszły do tego obfotografowane wcześniej przewody hamulcowy. 2015.09.02 wskoczyły mapy PL do navi i spolszczenie - jakby cos ktoś to na pw 2015.09.08 w końcu uzupełnione plastiki w podszybiu - idzie jesień więc w sam raz ochrona przed śmieciami osłona aku tez już na miejscu, a przy okazji czy kółeczka audi na osłonę silnika można gdzieś jakoś dokupić? 2015.09.14 jako że zdarzyło się coś takiego przyszła pora na wymianę żarówek z przodu + postojówki z kompletu wybór padł na Philips White Vision, a na zapas tungsramy +120% (miały bys osramy nightbrekery ale trzeba w końcu coś innego wypróbować dodatkowo zrobiłem porównanie w wyglądzie żarówki osrama i philipsa no i efekt finalny a i przy okazji pochwaliłem się nowymi ramkami klubowymi zakupionymi z pół roku temu obiecane fotki przed i po założeniu dystansów Mam nadzieje ze widać różnice Edytowane 30 Marca 2016 przez lapidem Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
amaradaar 5 Opublikowano 18 Września 2015 Udostępnij Opublikowano 18 Września 2015 Pięknie Panie Pięknie jeszcze daleka droga przed tobą ale widzę kierunek słuszny Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
lapidem 1 Opublikowano 18 Września 2015 Autor Udostępnij Opublikowano 18 Września 2015 (edytowane) droga daleka, ale na początek postanowiłem doprowadzić do ładu pod kątem technicznym Nie mogę się tez do końca zdecydować w jakim kierunku pójść... Na początek na pewno przyciemnianie szyb, a potem może dokładki w kolor i zderzaki sline... sam nie wiem...na razie nie znudziła mi się jeszcze taka jaka jest więc trzeba poczekać Edytowane 18 Września 2015 przez lapidem Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
slawek8621 0 Opublikowano 30 Września 2015 Udostępnij Opublikowano 30 Września 2015 Dokłądnie wszystko w swoim czasie.... Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
lapidem 1 Opublikowano 13 Listopada 2015 Autor Udostępnij Opublikowano 13 Listopada 2015 2015.11.13 259tys przelotu i kolejna wymiana oleju i filtrów + płukanka Milersa :> Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
kufel26 5 Opublikowano 6 Lutego 2016 Udostępnij Opublikowano 6 Lutego 2016 (edytowane) Jakie et maja te felgi i jaki wymiar dystansów dałeś na przód i jaki na tył? Piekny kolor Edytowane 6 Lutego 2016 przez kufel26 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
boguc 13 Opublikowano 6 Lutego 2016 Udostępnij Opublikowano 6 Lutego 2016 Ta płukanka w jakim celu ? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
lapidem 1 Opublikowano 1 Czerwca 2016 Autor Udostępnij Opublikowano 1 Czerwca 2016 Jakie et maja te felgi i jaki wymiar dystansów dałeś na przód i jaki na tył? Piekny kolor Dzięki tez mi się podoba :> Felgi 17'' 7J 17 ET54 z WV 5K0601025F Natomiast dystanse 25mm na tył i 20mm na przód z Dystoma i wg mnie jest optymalnie, chociaż parę milimetrów pewno można byłoby wysunąć, ale szkoda mi było rantu nadkoli Ta płukanka w jakim celu ? Płukanka profilaktycznie - na pewno nie zaszkodziła a mam wrażenie że pomogła 2016.03.17 Brak czasu, ale coś się dzieje - przepłukany układ wspomagania i nowy płyn 2016.03.30 żywota dokonała żaróweczka Philips White Vision czyli jakieś pół roku świecenia i 10tkm 2016.05.27 kolejny plan zrealizowany ciemne szybki na pokładzie boczki folia, tylna oryginalne przyciemniona 2016.06.01 stary czujnik temperatury zaczynał robić psikusy więc wskoczył nowy Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
