[B5 ARG] Skanowanie modulow-prosze o analize znalezionych bledow
Witam.
Oto co znalazł VAG. Proszę o analizę znalezionych błędów.
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 906 018 D
Component: 1.8l R4/5V MOTR 0005
Coding: 05001
Shop #: WSC 06335
2 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 N
Coding: 00040
Shop #: WSC 06335
7 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-00 - Blocked or No Voltage
01272 - Positioning Motor for Central Flap (V70)
01271 - Positioning Motor for Temperature Flap (V68)
01274 - Air Flow Flap Positioning Motor (V71)
00602 - Potentiometer On Positioning Motor for Footwell/Defroster Flap (G114)
09-00 - Adaptation Limit Surpassed
00600 - Potentiometer On Positioning Motor for Temperature Flap (G92)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 881 J
Component: B5-KOMBIINSTR. VDO D15
Coding: 05042
Shop #: WSC 24171
IMMO-IDENTNR: AUZ7Z0X0876397
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 B
Component: ZV-Pumpe, Funk D12
Coding: 12865
Shop #: WSC 06335
1 Fault Found:
00955 - Key 1
Address 56 -------------------------------------------------------
Controller: 4B0 035 186
Component: Radio 0001
Coding: 00205
Shop #: WSC 06335
2 Faults Found:
00854 - Radio Display Output in dash Panel insert
49-10 - No Communications - Intermittent
65535 - Internal Control Module Memory Error
00-00 - -
End -------------------------------------------------------
Z klimatyzacją walczę w oddzielnym temacie, bo oprócz ogrzewania nie działa mi nic.[br]Dopisany: 05 Październik 2008, 16:32_________________________________________________Odświeżę trochę temat.
Z klimą już sobie poradziłem. Wymieniłem sterownik klimatronika i hula aż miło.
natomiast niepokoją mnie dalej te błędy:
Control Module Part Number: 8D0 906 018 D
Component and/or Version: 1.8l R4/5V MOTR 0005
Software Coding: 05001
Work Shop Code: WSC 06335
3 Faults Found:
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-10 - - - Intermittent
Jakieś pomysły co może być nie tak ?
Dzięki za odpowiedź.
W sumie to tyle znalazłem na forum. Bardziej by mnie interesowało, gdzie może leżeć problem.
Do wymiany jest na pewno czujnik, ale co powoduje problem z mieszanką ?
Na forum znalazłem, że może być przepływka do wymiany, ale jakie testy zrobić, żeby się upewnić, że to ona
zawala wszystko ?
17536 - Długoterminowa adaptacja składu mieszanki 1- mieszanka uboga (weak mixture)
00603 - Silnik klapy nawiewu / odmrażania (V85)
01272 - Nastawnik klapy centralnej (V70)
01271 - Nastawnik klapy nawiewu regulacji temperatury (V68)
01274 - Nastawnik klapy spiętrzającej (V71)
00602 - Potencjometr w V85 (G114)
00604 - Potencjometr w V71 (G113)
00600 - Potencjometr w V68 (G92)
00955 - Key 1: Adaptation Limit Surpassed
Possible Symptoms
* Remote control not working.
Possible Causes
* Key not matched.
* Key operated more than 200 times while out of range.
Possible Solutions
* See vehicle specific page for synchronisation/adaptation procedures.
Jeżeli chodzi o kluczyk poszukaj na forum jak się synchronizuje w B5 ja miałem problem z jednym kluczykiem w B6 i problem rozwiązywało się tak : przytrzymujesz jakiś przycisk w kluczyku, przekręcasz w pozycje 2 trzymając kluczyk chwilę potem puszczasz i wyciągasz kluczyk u mnie to pomogło.
00854 - Wyjście do wyświetlacza radiowego w konsoli
65535 - Uszkodzony sterownik ECM
17545 - Długoterminowa adaptacja składu mieszanki 1- mieszanka bogata - b.jałowy
Polecam : http://wiki.ross-tech.com i opcję Szukaj
