W221 Opublikowano 20 Lutego 2015 Opublikowano 20 Lutego 2015 Witam, wykonałem pełną diagnostykę a oto co wyrzuciło: VAG-COM Version: Release 409.1-S Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 ------------------------------------------------------------------------------- Address 01: Engine Controller: 8E0 907 401 C Component: 2.5L V6 TDI G000SG 0004 Coding: 02015 Shop #: WSC 60089 00001059 130 106LC150_1.V77591464185 No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Controller: 8E0 614 517 A Component: ABS/ESP allrad 1326 Coding: 04455 Shop #: WSC 06435 2 Faults Found: 01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30 35-10 - - - Intermittent 65535 - Internal Control Module Memory Error 00-00 - - ------------------------------------------------------------------------------- Address 08: Auto HVAC Controller: 8E0 820 043 C Component: A4 Klimaautomat 0711 Coding: 00000 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Controller: 8E0 907 279 B Component: int. Lastmodul RDW 1512 Coding: 00011 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Skipping Address 15-Airbags ------------------------------------------------------------------------------- Address 16: Steering wheel Controller: 8E0 953 549 L Component: Lenksáulenmodul 0306 Coding: 02041 Shop #: WSC 63351 2 Faults Found: 01330 - Central Control Module for Central Convenience (J393) 49-10 - No Communications - Intermittent 01304 - Radio 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Controller: 8E0 920 930 JX Component: KOMBI+WEGFAHRS. RB4 D29 Coding: 01000 Shop #: WSC 00054 WAUZZZ8E02A040817 AUZ6Z0A0153859 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Controller: 8E0 035 192 Component: RNS 4.1 H06 BNO 0102 No fault code found. ------------------------------------------------------------------------------- Address 45: Inter. Monitor Controller: 8E0 951 177 Component: Innenraumueberw. 0504 Coding: 00001 Shop #: WSC 00000 1 Fault Found: 01463 - Alarm triggered by Sensor for anti-theft alarm System 43-00 - Closed ------------------------------------------------------------------------------- Address 46: Central Conv. Controller: 8E0 959 433 AJ Component: Komfortgerát T9F 0619 Coding: 06734 Shop #: WSC 51039 14 Faults Found: 01134 - Alarm Horn (H12) 49-00 - No Communications 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01561 - Left Rear Door 59-00 - Can't Unlock 01561 - Left Rear Door 61-00 - Won't De-Safe 01562 - Right Rear Door 59-00 - Can't Unlock 01562 - Right Rear Door 61-00 - Won't De-Safe 01331 - Door Control Module: Driver Side (J386) 49-10 - No Communications - Intermittent 01705 - Selection Switch for Mirror-Adjust (E48) 27-10 - Implausible Signal - Intermittent 00932 - Electric Window Motor: Drivers Side (V147) 62-10 - No or Incorrect Adjustment - Intermittent 01559 - Drivers Door 59-10 - Can't Unlock - Intermittent 01332 - Door Control Module: Passenger Side (J387) 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 55: Xenon Range Controller: 4B0 907 357 C Component: dynamische LWR D06 Coding: 00060 Shop #: WSC 30011 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Controller: 8E0 035 192 Component: Radio BNO 0001 Coding: 00017 Shop #: WSC 63351 No fault code found. End -------------------------------------------------------------------------------------------------- Ogólnie to centralny zamek działa jak by nie mógł dokładniej otwierają się bez problemów drzwi kierowcy i wlew paliwa (standard) z pilota a pozostałe dopiero po dodatkowych 3-4 kliknięciach. Zaś z kluczyka mogę tylko otworzyć drzwi kierowcy, ale zamykają się już wszystkie. A alarm po prostu jak by nie działa. Dokładniej włącza się prawidłowo, gdy się go "specjalnie" uaktywni to mruga tylko dioda w drzwiach (inaczej niż gdy stoi spokojnie). Nie ma dźwięku ani nic innego. W teście alarmu w VAG'u po za mrugającą lampką jeszcze mrugają kierunkowskazy ale nadal nie ma dźwięku Z Kierownicą wszystko OK - przyciski wykonują swoje funkcje, jedynie tempomat nie daje znaku życia. Wszystkie błędy powracają po skasowaniu. Proszę o pomoc gdzie szukać problemów z tym jak i z resztą (wszystko w logu) o której nawet nie mam zielonego pojęcia.
