troche błedów po modyfikacjach
Panowie po paru modyfikacjach mianowicie
-zmiana radia z nieoryginalnego na Ori BNS plus zmieniarka do tego kiera multi
-ostatnio pakiet światło w boczki
naszło mnie na skanowanie całego auta i taki oto wynik:
Sunday,07,June,2015,12:56:54:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ8E05A573321 License Plate:
Mileage: 237170km-147370mi Repair Order:
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E05A573321 Mileage: 237170km/147370miles
Address 01: Engine Labels: 03G-906-016-BKE.lbl
Part No SW: 03G 906 016 FE HW: 028 101 212 7
Component: R4 1,9L EDC G000SG 9820
Revision: 12345678 Serial number: AUX6Z0E0074076
Coding: 0000071
Shop #: WSC 60925 124 07124
VCID: 6BD5212749702B46511-5000
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 09555
VCID: 264310139112D62ECEF-8073
1 Fault Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 13
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0002
Hex Value: 0x00FF
Hex Value: 0xFF99
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AK
Component: A4 Klimaautomat 2831
Coding: 00000
Shop #: WSC 00000
VCID: 6ADB2423168A324E2A7-5000
3 Faults Found:
01172 - Temperature Sensor; Driver's Heated Seat (G59)
30-00 - Open or Short to Plus
01171 - Temperature Sensor; Passenger Side Heated Seat (G60)
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0504
Coding: 10001
Shop #: WSC 06325
VCID: 3B75D16729907BC6811-4A3A
1 Fault Found:
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M004ME2U
Coding: 0033622
Shop #: WSC 06325 000 00000
VCID: 3B75D1677A907BC6811-806E
Subsystem 1 - Serial number: 6332DRB4015D8C8D0
Subsystem 2 - Serial number: 6342DRB4018945A8T
Subsystem 3 - Serial number: 6352ARB40064D039H
Subsystem 4 - Serial number: 6362ARB400605E46I
Subsystem 5 - Serial number: 63729RB4006A73A7Q
Subsystem 6 - Serial number: 63829RB4006A6D0FY
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 02042
Shop #: WSC 06335
VCID: 4189A38F4B7C1116DBD-4A3A
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 900 P HW: 8E0 920 900 P
Component: KOMBI+WFS 3 H12 0030
Revision: 0030 Serial number: AUX6Z0E0074076
Coding: 0006101
Shop #: WSC 80093 222 69422
VCID: 3169F34FABDC81962BD-5072
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006101
VCID: 3169F34FABDC81962BD-5000
1 Fault Found:
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BP
Component: Komfortgerát T85 3332
Coding: 07024
Shop #: WSC 06325
VCID: 800FE68B80F6581E143-4A3A
Subsystem 1 - Part No: 8E1959801H
Component: Tőrsteuer.FS BRM 0406
Subsystem 2 - Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 0205
4 Faults Found:
00957 - Key 3
35-10 - - - Intermittent
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
End ---------------------------------------------------------------------
Bład wgrupu 8 Auto HVAC 01171 i 01172 jest dlatego ze nie zamontowalem jeszce wazki na grzane fotele co sie niebawem stanie
najbardziej interesuja mnie błedy z ABS -wywala kontrolke ABS i ESP na konsoli oraz IMO od jakiegos czasu mi pokazuje 00470
jak pozbyć się błedów
sprawdz adapatcje KOMFORTU :
Kodowanie modułu komfortu
Wybieramy opcję CODING 07 (aby aktywować dane funkcje dodajemy do siebie poniższe wartości i ich sumę zapisujemy jako kodowanie sterownika):
+1 – aktywacja alarmu (wersja dla UK i Irlandii)
+2 – potwierdzenie aktywacji/deaktywacji alarmu przez odpowiednią sygnalizację diody w drzwiach kierowcy
+4 – selektywny centralny zamek (podczas otwierania auta z pilota, jedno naciśnięcie przycisku otworzy tylko drzwi kierowcy, klapkę wlewu paliwa i wyłączy funkcję SAFE - drugie naciśnięcie otworzy pozostałe drzwi oraz odblokuje zamki maski i bagażnika)
+8 – aktywacja alarmu
+16 – blokada zamka klapy bagażnika po przekroczeniu 5km/h (zamek odblokuje się automatycznie po zwolnieniu poniżej 5km/h)
+32 – blokada zamków wszystkich drzwi po przekroczeniu 10km/h (zamki zostają otwarte dopiero po wyjęciu kluczyka z zapłonu, bądź przez manualne otworzenie drzwi przy pomocy przycisków zamka centralnego w tapicerce drzwi kierowcy)
+64 – aktywacja dodatkowych funkcji modułu komfortu (możliwość otwierania/zamykania szyb oraz szyberdachu przy pomocy zamka w drzwiach i pilota)
+128 – pojazd z kierownicą po prawej stronie
+256 – aktywacja czujników zbicia tylnych bocznych szyb (tylko dla nadwozia Avant wyposażonego w fabryczny alarm)
+512 – potwierdzenie udanego zamknięcia wszystkich zamków przy pomocy pilota przez pojedyncze mrugnięcie kierunkowskazami
+1024 – dodatkowe potwierdzenie aktywacji alarmu przez pojedynczy sygnał dźwiękowy z syreny alarmu
+2048 – zasady dot. zasilania podnośników szyb (po wyłączeniu zapłonu i wyjęciu kluczyka ze stacyjki podnośniki szyb będą zasilane jeszcze przez 10 minut lub do czasu aż nie zostaną otwarte drzwi)
+4096 – dodatkowe funkcje przeciwwłamaniowe W przypadku otwierania auta kluczykiem zostaną odblokowane tylko drzwi kierowcy, pozostałe drzwi i zamki zostaną odblokowane po włączeniu zapłonu. W przypadku gdy auto posiada fabryczny alarm po otwarciu drzwi kierowcy kluczykiem – zapłon musi zostać włączony w ciągu 15 sekund (w przeciwnym przypadku nastąpi wyzwolenie alarmu).
+8192 – wyłączenie funkcji SAFE (tylko dla USA i Kanada – wersje samochodów przeznaczone na ten rynek mają tylko jeden silnik w zamku, pozostałe auta mają dwa – jeden zamyka zamek a drugi aktywuje funkcję SAFE czyli brak możliwości odblokowania auta z wewnątrz - włącznik w tapicerce drzwi kierowcy - po zamknięciu samochodu pilotem lub kluczykiem)
+16384 – informacja dla silników szyb o zamontowanych szybach dwuwarstwowych
Adaptacja modułu komfortu
Wariant modułu komfortu – ADAPTATION 10, kanał 61:
0 – bez dodatkowego oświetlenia przestrzeni stóp, szyby tylnych drzwi w elektryce
1 – bez dodatkowego oświetlenia przestrzeni stóp, szyby tylnych drzwi w korbach
2 – dodatkowe oświetlenie stóp, szyby tylnych drzwi w elektryce
3 – dodatkowe oświetlenie stóp, szyby tylnych drzwi w korbach
Aktywacje poszczególnych opcji komfortu – ADAPTATION 10, kanał 62:
+1 – Komfortowe zamykanie szyb pilotem
+2 – Komfortowe otwieranie szyb pilotem
+4 – Komfortowe zamykanie szyb kluczykiem
+8 – Komfortowe otwieranie szyb kluczykiem
+16 – Komfortowe zamykanie szyberdachu pilotem
+32 – Komfortowe otwieranie szyberdachu pilotem
+64 – Komfortowe zamykanie szyberdachu kluczykiem
+128 – Komfortowe otwieranie szyberdachu kluczykiem
adaptacja 61- wartosc 1 z tylu korby 62- wartosc 95 auto tylko przod elektro bez szyber
