[ALL B5] Kody wyposażenia - prośba o przetłumaczenie
ja tez poprosze o przetlumaczenie ;d
E0A = No special edition
7A2 = CD changer
4UE = Air bag for driver and front seat passenger
6XD = Exterior mirrors: electrically adjustable/heated
5SL = Left exterior mirror: aspherical
5RU = Right exterior mirror: convex (large viewing field)
1BE = Sports suspension/shock absorption
1LB = Disc brakes, front
J0R = Battery 380 A (80 Ah)
1KD = Disc brakes, rear
3FA = Without roof insert (standard roof)
F0A = No special purpose vehicle, standard equipment
T9J = 4-cylinder diesel engine 1.9 L unit 038.K
2PV = Leather trimmed sports steering wheel
7Q2 = Navigation system with color screen
3L3 = Manual height adjustment for front seats
15A = code not found :-(
C1W = Forged alloy wheels 7J x 15 type 1, offset 39
3ND = Rear seat bench/backrest, unfolding
5TD = Decorative aluminum inserts
8GU = Alternator 140 A
0G1 = Gearshift lever
8JG = Headlight with gas discharge lamp for driving on the right
U2A = Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
7Q4 = Preparation for navigation system
7K0 = Without tire pressure warning light
4X3 = Side air bag front with curtain air bag
4KC = Side and rear windows in heat-insulatingglass
3Y0 = Without roll-up sun screen
0GE = Emission standard EU3
Q1D = Sports front seats
7X1 = Park distance control
4R4 = Power windows with comfort operation andcircuit breaker
0YG = Weight range 7 installation control only, no requirement forecast
0JG = Weight category front axle weight range 7
X0A = National sales program Germany
1N1 = Power steering
8Z5 = Not hot country
D3E = 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J
2K1 = Reinforced bumpers
6R2 = Leather gearshift boot
4K4 = Radio remote controlled central locking
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
4GH = Windshield in heat-insulating glass with sunshield
Dziekuje z góry:)
spiidy sprawdziłeś ? przecież parę stron wcześniej są prawie wszystkie kody potłumaczone :wink4: wszyscy na łatwiznę ...
0JZ - tego oznaczenie nie mogę nigdzie znaleźć :(
wpisałem w google - drugi link: :mysli:
0JZ - Without determination of weight category for front axle (Bez Ustalonej Klasy Wagowej-oś Przednia)
0JZ - Without determination of weight category for front axle (Bez Ustalonej Klasy Wagowej-oś Tylna)
Jesteś pewien, że tylnej, a nie przedniej?
Pozdrawiam.
Sławek
przednia. mój błąd.
Witam, większośc juz znalałem w wątku ale pozostały mi jeszcze te:
prosze o pomoc w przetłumaczeniu
6XJ = Exterior mirrors: automatically dimming,electrically adjustable/heated
1JR = Rear shock absorption
5MF = Decorative aluminum inserts
T6T = 6-cylinder diesel engine 2.5 L unit 059.A
8G2 = Sliding headlight range control
3L1 = Manual height adjustment for left front seat
0JL = Weight category front axle weight range 11
M5V = 6-cyl. turbo diesel engine 2.5 L/110 kW catalytic converter and EGR, MVEG 2 base engine is T6T
1GA = Front shock absorption, basic design 1
1SL = Underbody stone guard
0YF = Weight range 6 installation control only, no requirement forecast
spoko, dzieki, juz przetłumaczone
X0A = National sales program germany - wyprodukowany na niemcy
B0A = Poj. bez szczególnych krajowych wymogów techn.
C0V = Felga stalowa 6 jx15h2 et45 5/112
G0C = Manualna 5-biegowa skrzynia b. (przelozenia sport.)
H6S = Opony 195/65 r 15 v
J0R = Akumulator
M6N = 4-cylindrowy silnik z wtryskiem paliwa 1,9 l litera kodowa
Q1A = Siedzenia normalne
1AC = System przeciwblokujĄcy -abs-
1Q2 = Kierownica z masĄ równ.drgania
2PG = Kierownica do inst.pod.powietrz.
5RQ = Lusterko na wysięgniku (konvex) str. prawa
5SL = Lusterko na wysięgniku (konvex) 1f52
T1R = Silnik 4-cylindrowy wysokoprężny turbo 1,9 l litera kodowa
3S0 = Bez poręczy dachowych
4UE = Lewo/prawo - nie wiem co to
0G1 = Przedłużenie okresu przeglądu
8AD = Radio gamma
8GL = Alternator
8RN = Eight speakers (active) 8 głośników czyli masz w tylnych drzwiach
1LB = Faustsattelbremse przod - tez nie wiem co to
3FA = Bez wkładu dachu (dach pełny)
1BA = Pakiet zawiesz. komfortowe
[br]Dopisany: 12 Marzec 2010, 11:45_________________________________________________a to niżej co tam masz to nie wiem.. te kody, nigdy się nad nimi nie zastanawiałem nawet...
fajnie by było żeby spalanie :tongue4:
no faktycznie 7.2 to trochę dużo ;) mi wychodzi 5.5-6 na zimówkach... ale niech ktoś się wypowie co to jest to niżej :naughty:[br]Dopisany: 12 Marzec 2010, 12:02_________________________________________________aha - to "prawo/lewo to jest airbag dla kierowcy i pasażera
Witam, czy może miktoś te kody rozszyfrować? szukałem na forum jakiegoś tematu gdzie są może podane wszystkie, ale niestety nie moglem znaleźć :kwasny: z góry wielkie dzięki
A8S Standard equipment
B0A Component parts set without
country-specific design requirement
B99 Type approval EC
C05 Operating permit, alteration
C0W Alloy wheels 9J x 18
E0A No special edition
F0A No special purpose vehicle, standard
equipment
FA0 Control of standard production
G0C 5-speed manual transmission
H6R Tires 195/65 R15 T
J0R Battery 380 A (80 Ah)
K8D Station Wagon Variant/Avant
L0L Left-hand drive vehicle
M0T 4-cyl. turbo diesel engine 1.9 L/66 kW
direct injection
base engine is T0T
N4A Fabric seat covering
Q1A Standard front seats
T0T 4-cylinder diesel engine 1.9 L
unit 028.M
U1A Instrument insert with km/h speedometer,
0DY Installation differentiation for build
status of vehicle class B5 (AUDI)
unit components
0G1 Gearshift lever
0JZ Without determination of weight category
for front axle
0K0 Without alternative drive module
0LU Special plates/stickers/
safety certificates for Belgium
0ST Labels/plates in German and French
0TC Front floor mats
0XN Information kit in French and Dutch
0YZ Without determination of weight category
for rear axle
1AC Anti-lock brake system (ABS)
1BA Standard suspension/shock absorption
1C1 Antifreeze up to -25 degree celsius
tolerance up to -30 degree C
1D0 Without trailer hitch
1E0 Without activated charcoal canister
1EX Special identification plate for EC
for M1 passenger vehicle
1G3 Alloy spare wheel with original
equipment tires
1LZ Front disc brakes, standard ventilation
1MR Leather steering wheel
1PC Wheel bolts with anti-theft protection
(unlockable)
1SA Without additional engine guard
1T2 Warning triangle
1VG Installation parts for four-cylinder
engine
1WD Transmission shaft for tripod joints
1X0 Front wheel drive
1YA Without transmission shafts f. rear axle
1Z1 Increase in initial standard fuel
filling
2A5 Delivery equipment (transit coating)
with thin seat cover
2B1 Additional exterior noise suppression
2G0 Without insert for the filling up of
fuel
2K1 Reinforced bumpers
2WA Without additional tires
2Z1 Type sign at rear
and "Quattro" nameplates respectively
3B0 Without additional child seat anchor
3C3 Lap belt with retractor
for the center rear seat
3CA Without partition
3FA Without roof insert (standard roof)
3L1 Manual height adjustment for left front
seat
3NZ Rear seat bench unsplit, backrest split
folding
3S2 Black roof rails
3X0 Without load-through provision
3Y0 Without roll-up sun screen
4A0 Without seat heater
4F1 Central locking system
4GH Windshield in heat-insulating glass
with sunshield
4M6 Cup holder
4R2 Power windows front, mechanical window
regulators rear
4SB Vanity mirror left
4TB Vanity mirror right
4UE Air bag for driver and front seat
passenger
4W0 Without cassette and CD storage unit
4X0 Without side air bag
4ZE Black moldings
5C0 Without special body measures
5D0 Without carrier frequency
5E1 Without sill top with door cover
5K1 Paint preservative (wax)
5MG Decorative inserts, burr-walnut
5RQ Right exterior mirror: convex
5SL Left exterior mirror: aspherical
6E3 Front center armrest
6FB Body-colored exterior mirror housings
6M0 Without tie down straps/net/pocket
6N0 Without mud flaps
6Q2 Leather gearshift knob/handle
6R2 Leather gearshift boot
6U0 Without additional seals outside
6V1 Rear trim panel (ECE)
6W5 Front license plate bracket
6XD Exterior mirrors: electrically
adjustable/heated
7A0 Without CD changer/CD player
7AA Electronic vehicle immobilization device
7CA Without label for radio remote control
7M0 Plastic scuff plates in door apertures
7P0 Without lumbar support
in seat backrests
7Q0 Without navigation device
8AV Radio
8BB Halogen headlight
8CC Speedometer sensor without seal
(electronic speedometer sensor)
8GL Alternator 120 A
8K0 Without special headlight
activation
8KA W/o catalytic converter warning light
8NA Without parking light warning light
8Q1 Headlight-range adjustment
8R1 Center high-mounted stop light
8RM 8 speakers (passive)
8S4 Two reading lights front, two rear
8T0 Without cruise control system (CCS)
8TC Rear fog light for driving on the right
8X0 Without headlight washer system
8Z5 Not hot country
9AK Climatronic with impact pressure
control free of cfc
9P0 Without seat belt reminder
9Q0 Without multi-function display/
on-board computer
9T0 Without heated washer nozzles
9W0 W/o car phone preparation/installation
9X4 Without heated door lock cylinder with
micro switch
9Y1 Outdoor temperature gage
Witam. To i ja się podłącze do tematu. Mianowicie mam takie parę kodów, które po przetłumaczeniu są trochę niejasne jak dla mnie (tak to bywa jak się dosłownie tłumaczy).
C00 - Operation permit, initial registration (dopuszczony do ruchu, wstępnie zarejestrowany?? )
S0C - Introductory volume (ton wprowadzający??)
S61 - Control of deviation permit F 300 SOP (raised chassis) (Kontrola odchylenia?? (podniesione podwozie??))
8NB - Parking light indicator light (kontrolka ręcznego??)
I dwa od ojca:
C01 -Operating permit ,alteration (dopuszczony do ruchu, zmodyfikowany??)
8NA - without parking light warning light (bez kontrolki ręcznego??)
I jeszcze jedno pytanko, bo lekko zbaraniałem... Mianowicie:
3BK - Left exterior mirror:electrically adjusted/heated, electrically loldable, flat (lewe lusterko: elektrycznie ustawiane, podgrzewane, elektrycznie klapowane)
5RD - Reight exterior mirror, aspherical (India)
I teoretycznie wychodzi z tego, że w lewym mem pełną elektrykę, a w prawym nic... DOdam tylko,że oby dwa są sterowane elektrycznie (podgrzewania nie sprawdzałem jeszcze, a składanie muszę zrobić bo nie działą póki co)...
Z góry dzięki za pomoc :)
8VD = Radio-controlled clock
a ten kod?? ktos to moze przetlumaczyc na polski??
ze niby zegarek strowany z pilota ;(
http://www.a4-klub.pl/smf/index.php?topic=10354.msg1258085#msg1258085
Następnym razemużyj :szukaj:
Pozdrawiam.
Sławek
jakos u mnie wyskakuje "Nie znaleziono tematów ani postów pasujących do Twoich kryteriów wyszukiwania" jak uzywam szukaj z tym wlasnie kodem
:confused4:
