Prośba o analizę błędów
Tak jak w temacie. Z góry dziękuję.
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76,77 Address 01 ------------------------------------------------------- Controller: 038 906 018 S Component: 1,9l R4 EDC 10SG 1621 Coding: 00002 Shop #: WSC 30022 4 Faults Found: 17978 - Engine Start Blocked by Immobilizer P1570 - 35-00 - - 00522 - Engine Coolant Temperature Sensor (G62) 30-10 - Open or Short to B+ - Intermittent 00539 - Fuel Temperature Sensor (G81) 29-10 - Short to Ground - Intermittent 00575 - Intake Manifold Pressure 17-10 - Control Difference - Intermittent Readiness: N/A
Address 03 ------------------------------------------------------- Controller: 8E0 614 111 AB Component: ABS 5.3 FRONT D00 Coding: 0273004281 Shop #: BB 24548 No fault code found.
Address 08 ------------------------------------------------------- Controller: 8L0 820 043 D Component: A4 KLIMAVOLLAUTOMAT_D75 Coding: 04143 Shop #: WSC 06325 1 Fault Found: 00792 - A/C Pressure Switch (F129) 31-00 - Open or Short to Ground
Address 15 ------------------------------------------------------- Controller: 8D0 959 655 L Component: Airbag 7 Audi 0503 Coding: 00106 Shop #: WSC 06325 1 Fault Found: 01222 - Crash Sensor Side Airbag: Passenger Side (G180) 36-00 - Open Circuit
Address 17 ------------------------------------------------------- Controller: 8D0 919 861 A Component: B5-KOMBIINSTR.UN4 D05 Coding: 00040 Shop #: WSC 42641 IMMO-IDENTNR: AUZ8Z0W2060585 No fault code found.
Address 25 ------------------------------------------------------- Controller: Bitte Adress Component: e 17 eingeben No Faults Found or DTCs not supported by controller or a communication error ocurred
Address 56 ------------------------------------------------------- Controller: 4B0 035 186 Component: Radio D02 Coding: 00203 Shop #: WSC 02325 1 Fault Found: 00855 - Connection to CD changer 49-00 - No Communications
End -------------------------------------------------------
