[B6 AVF] Proszę o pomoc w diagnozie vag
Witam mam problem z moim samochodzikiem wyskoczyło mi kilka błędów po diagnozie wagiem wyciągałem wszystkie bezpieczniki i pewnie cos sie porobilo a czemu je wyciagalem bo szukalem przyczyne nie pracujacej tylnej wycieraczki oczywiscie nie znalazlem dlaczego sie popsula. Prosze o pomoc w dwoch sprawach
1) odczyt z VAG
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 JT
Component: 1,9l R4 EDC G000SG 1572
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E53A196336 AUZ6Z0B0231302
2 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
3 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
01810 - Actuating Motor for Temperature Flap: Right (V159)
01274 - Air Flow Flap Positioning Motor (V71)
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
01312 - Powertrain Data Bus
79-10 - Please Check Fault Codes - Intermittent
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00042
Shop #: WSC 63351
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 00100
Shop #: WSC 30011
2 Faults Found:
01316 - ABS Control Module
01300 - Control Module for Navigation with CD-Rom (J401)
Address 37 -------------------------------------------------------
Controller: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0008
No fault code found.
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AR
Component: Komfortgerát T85 1310
Coding: 06976
Shop #: WSC 63351
Address 56 -------------------------------------------------------
Controller: 8E0 035 152
Component: chorus II GRO 0008
Coding: 01010
Shop #: WSC 63351
1 Fault Found:
End -------------------------------------------------------
2) czemu nie pracuje tylna wycieraczka w moim Audi A4 kombi 11.2002 r. zaznaczam że spryskiwacz działa poprawnie jak to naprawić? :wallbash:
Dziekuję za pomoc.
AD 1
tu masz kody błędów i opis co oznaczają, poza tym skoro masz VAGa i zczytałeś błędy, to możesz je również wykasować...
http://www.a4-klub.pl/smf/kody_vag_v20061114-t1913.0.html
AD 2
sprawdź czy dochodzi napięcie do silniczka wycieraczki
  • 2 lata później...
U mnie błędy:
00283 - Front Left ABS Wheel Speed Sensor (G47)
27-10 - Implausible Signal - Intermittent
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
wyskoczyły jak się zakopałem tej zimy. Po skasowaniu błędów nic więcej nie wyskoczyło.
