mardock81 Opublikowano 2 Listopada 2016 Opublikowano 2 Listopada 2016 Witam.Przestał działać mi hamulec ręczny,zacina się roleta od szklanego dachu i nie działa zamykanie,otwieranie szyb z pilota.Pewnie coś jeszcze patrząc na ilość błędów.Pozdrawiam Address 03: ABS Brakes (J104) Labels: 8R0-907-379.clb Part No SW: 8R0 907 379 H HW: 8R0 907 379 H Component: ESP8 quattro H06 0110 Revision: -------- Serial number: -------------- Coding: 121D18 Shop #: WSC 06335 000 00000 VCID: 4581B79FCC543D36E75-80101 Fault Found:00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 60 Mileage: 112362 km Time Indication: 0 Date: 2016.11.02 Time: 17:58:09 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x07A2 Hex Value: 0x0016 Hex Value: 0x0996 Hex Value: 0x00FFAddress 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 P HW: 8K0 907 063 P Component: BCM1 1.0 H30 0392 Revision: 10030001 Serial number: 00000000926216 Coding: 26001091073CAF010000000300001D0D0F1C460802010161000000 Shop #: WSC 06335 123 12345 VCID: 3C77D27BBF9E7CFE88B-8069 Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB Component: WWS416 110111 H11 0050 Coding: 01DD13 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Coding: 024D25 Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 00311 Fault Found:02258 - Door Opener Transmitter 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 60 Mileage: 112362 km Time Indication: 0 Date: 2016.11.02 Time: 17:56:00Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 CS HW: 8K0 907 064 CS Component: BCM2 2.0 H05 0435 Revision: 00002001 Serial number: 0142466955 Coding: 0126063A20FA749484B0053200000000 Shop #: WSC 06335 123 12345 VCID: 8305E98702E04306091-80D6 Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719 Component: GTO BF H01 0070 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J245EE20SKB13 H02 0220 Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J394EE20SKB13 H02 02201 Fault Found:02907 - Control Module for Roof Shade (J394) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 60 Mileage: 112362 km Time Indication: 0 Date: 2016.11.02 Time: 17:56:21Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 10000000714210 Shop #: WSC 00000 000 00000 VCID: 3467FA5B97CEB4BE40B-80613 Faults Found:03200 - Switch for Electric Parking Brake (E538) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 2 Fault Frequency: 9 Reset counter: 60 Mileage: 112362 km Time Indication: 0 Date: 2016.11.02 Time: 17:56:16 Freeze Frame: Voltage: 12.10 V Count: 36 Speed: 0.0 km/h Hex Value: 0x0263 Hex Value: 0x0001 Hex Value: 0x040401321 - Control Module for Airbags (J234) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 100 Mileage: 112362 km Time Indication: 0 Date: 2016.11.02 Time: 17:56:16 Freeze Frame: Voltage: 12.10 V Count: 80 Speed: 0.0 km/h Hex Value: 0x0270 Hex Value: 0x0001 Hex Value: 0x040416365 - Control Module - Electrical Error; CPU 2 008 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11101000 Fault Priority: 1 Fault Frequency: 7 Reset counter: 60 Mileage: 112362 km Time Indication: 0 Date: 2016.11.02 Time: 18:18:33 Freeze Frame: Voltage: 12.30 V Count: 35 Speed: 0.0 km/h Hex Value: 0x0173 Hex Value: 0x0008 Hex Value: 0x0404Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb Part No SW: 8T1 035 664 F HW: 8T1 035 664 B Component: H-BN-NA H51 0187 Revision: -------- Serial number: 490BN0B7603303 Coding: 010100060005E1EF41000F0E000000030000 Shop #: WSC 06335 000 00000 VCID: 3B75D167BA907BC6811-806E Subsystem 1 - Part No: 8R0 060 884 DF Component: EUR 2016 2204 Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604 Component: DU7 High H43 0084 Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F Component: E0380 Bedient H08 0100 Subsystem 4 - Part No: 8R0 060 961 Component: CD-Database 18862 Faults Found:03276 - Please Check Software Version Management 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 60 Mileage: 112362 km Time Indication: 0 Date: 2016.11.02 Time: 17:56:19 Freeze Frame: Voltage: 12.30 V03157 - Functionality limited due to Communications Disruption 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 60 Mileage: 112362 km Time Indication: 0 Date: 2016.11.02 Time: 17:56:22 Freeze Frame: Bin. Bits: 00000001 00000000 Bin. Bits: 00000000 00000000 Bin. Bits: 00000000 00000000 Bin. Bits: 00000000 00000000
wrclaguna Opublikowano 3 Listopada 2016 Opublikowano 3 Listopada 2016 Sprawdz okablowanie od przycisku recznego oraz bezpiecznik 03200 - Switch for Electric Parking Brake (E538) 012 - Electrical Fault in Circuit - MIL ON
mardock81 Opublikowano 3 Listopada 2016 Autor Opublikowano 3 Listopada 2016 (edytowane) Wszystko ogarnięte.Winowajca braku hamulca ręcznego był przycisk za 24zł z przesyłka Edytowane 15 Listopada 2016 przez mardock81
