Błędy znalezione VCDSem w moim AVF
Witajcie!
Sylwestrowo pytam co oznaczają te błędy?
Z góry powiem ze mam mape na 170hp oraz turbotimer
Z góry dziękuję za pomoc :)
VCDS-Lite Version: Release 1.2
Saturday, 31 December 2016, 15:42:32:0
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine Labels: 038-906-019-AJM.LBL
Controller: 038 906 019 JL
Component: 1,9l R4 EDC 0000SG 1519
Coding: 00002
Shop #: WSC 63351
VCID: 6AA741AB0567
WAUZZZ8E83A017349 AUZ6Z0B0093923
1 Fault Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
VCID: E5BDB2976C79
1 Fault Found:
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043 N
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
VCID: 2C2B87B3CF13
3 Faults Found:
01592 - Air Quality Sensor (G238)
00474 - Control Module for Immobilizer
49-10 - No Communications - Intermittent
27-10 - Implausible Signal - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
VCID: 341B9FD31723
1 Fault Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Controller: 8E0 959 655
Component: Airbag 8.4E 5001
Coding: 0011602
Shop #: WSC 63351
VCID: F49BDFD3D7A3
No fault code found.
Address 16: Steering wheel Labels: 8E0-959-655-84.LBL
Controller:
Note: Excessive Comm Errors
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 00000
Shop #: WSC 11111
VCID: 28237BA3DBEB
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 46: Central Conv. Labels: 8E0-959-433-MIN.LBL
Controller: 8E0 959 433 AG
Component: Komfortgerát T87 0316
Coding: 06720
Shop #: WSC 63351
VCID: 769F65DB41DF
End --------------------------
Pierwszy błąd to przeładowanie turbiny. Łapie tryby awaryjne?
Drugi ten od świateł stopu, masz stopa?
O co chodzi z tym przeładowaniem turbiny?
Nie zwracałem uwagi na stopa, ale sprawdzę...
przeladowanie wystepuje wtedy gdy turbina napompuje wiekszego ciśnienia niż oczekuje sterownik silnika.
Jak będzie przeładowywać i łapać tryby awaryjne to będziesz o tym wiedział. Po prostu odetnie Ci moc i dopiero ponowne uruchomienie silnika sprawi, że auto odzyska moc.
Jest jeszcze opcja, że Twoje turbo nie przeładowywuje, tylko kiedyś przeładowywało, usterka została usunięta, ale błędu nikt nie wykasował i dalej go widać.
Edytowane przez lukasz51237
