Witam interpretacja logow PROSZE O POMOC
Witam
Po wymianie spalonej instalacji silnik na uzywana vcds widzi takie blędy.
Prosze o pomoc w interpretacji.
012292 - Relay for Low-Output Preheating of Coolant (J359)
               P3004 - 000 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 255354 km
                    Time Indication: 0
012294 - Relay for High-Output Preheating of Coolant (J360)
               P3006 - 000 - Open or Short to Ground
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 255354 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.31 V
                    Bin. Bits: 00000000
                    Load: 0.0 %
                    Bin. Bits: 11011100
001681 - Fan 1 Control Circuit
               P0691 - 000 - Short to GND
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 255354 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.31 V
                    Bin. Bits: 00000000
                    Temperature: 21.6°C
                    Duty Cycle: 9.7 %
Readiness: 0 0 1 1 1
