Przemysław Jankowski Opublikowano 9 Września 2017 Opublikowano 9 Września 2017 witam wczoraj zapalila mi sie kontrolka silnika tak wiec dzisiaj podpinam kompa no i blad oto taki 1 Fault Found: 5253 - Exhaust Pressure Sensor 1 (G450) P0473 00 [175] - Signal too High MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 213648 km Date: 2017.09.08 Time: 12:03:47 Readiness: 1 1 0 0 0 po usunieciu znikla kontrolka,czujnik roznicy cisnien walniety? Ale postanowilem sprawdzic dpf-a,wyszly mi oto takie wartosci ktore mi zupelnie nic nie mowia,moglby ktos przetlumaczyc to? i jakie sa normy? i czy jak cos zle czy to wina czujnika? 072 Particle filter; difference pressure 16 hPa 073 Particle filter; field regeneration lock status 0 074 Particle filter; fuel consumption since last regeneration 31.72 l 075 Particle filter; kilometers since last regeneration 523311 m 076 Particle filter; offset for differential press. 3 hPa 077 Particle filter; oil ash volume 0.16 l 078 Particle filter; soot mass calculated 14.33 g 079 Particle filter; soot mass measured 14.24 g 080 Particle filter; time since last regeneration 46389 s
