Rozkodowanie błędu 1.8t
mikus933
Witam serdecznie.
Mógłbym prosić o napisanie co za błędy męczą moje auto? Z googli doczytałem, że coś z cewką lub świecą. Mogę o dokładne informacje?
VCDS-Lite Version: Release 1.2
Tuesday, 10 July 2018, 16:12:42:0
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine       Labels: Redir Fail!
   Controller: 8E0 909 518 AA
   Component: 1.8L R4/5VT         0004
   Coding: 0011501
   Shop #: WSC 63351
   VCID: 6F9150BF3E85
10 Faults Found:
17698 -  Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
            P1290 - 002 -  Lower Limit Exceeded - Intermittent
18080 - Shareware Version. To Decode all DTCs
            P1672 - 004 - Please Register/Activate - Intermittent
17705 - Shareware Version. To Decode all DTCs
            P1297 - 001 - Please Register/Activate - Intermittent
17072 -  ECM Power Relay Load Circuit: (J271): Open Circuit
            P0688 - 004 -  No Signal/Communication - Intermittent
16684 - Shareware Version. To Decode all DTCs
            P0300 - 008 - Please Register/Activate - Intermittent
16685 - Shareware Version. To Decode all DTCs
            P0301 - 008 - Please Register/Activate - Intermittent
16686 -  Cylinder 2: Misfire Detected
            P0302 - 008 -  Implausible Signal - Intermittent
18010 - Shareware Version. To Decode all DTCs
            P1602 - 002 - Please Register/Activate - Intermittent
17544 - Shareware Version. To Decode all DTCs
            P1136 - 001 - Please Register/Activate
16891 -  Idle Control System RPM: Higher than Expected.
            P0507 - 001 -  Upper Limit Exceeded - Intermittent
Readiness: 0000 1000
Address 03: ABS Brakes       Labels: 8E0-614-517.LBL
   Controller: 8E0 614 517
   Component: ABS/ESP front       1729
   Coding: 04475
   Shop #: WSC 06435
   VCID: E5BDB2976C79
1 Fault Found:
01826 -  Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            35-10 -   - - Intermittent
Address 08: Auto HVAC       Labels: 8E0-820-043.LBL
   Controller: 8E0 820 043 J
   Component:   A4 Klimaautomat   1116
   Coding: 00000
   Shop #: WSC 63351
   VCID: 28237BA3DBEB
3 Faults Found:
00727 -  Potentiometer in Positioning Motor for Defrost Flap (G135)
            30-10 -  Open or Short to Plus - Intermittent
00601 -  Potentiometer On Positioning Motor for Central Flap (G112)
            09-00 -  Adaptation Limit Surpassed
01809 -  Actuating Motor for Temperature Flap; Left (V158)
            41-10 -  Blocked or No Voltage - Intermittent
Address 09: Cent. Elect.       Labels: 8E0-907-279-8E2.LBL
   Controller: 8E0 907 279 C
   Component: int. Lastmodul  RDW 0203
   Coding: 00001
   Shop #: WSC 63351
   VCID: 321799CBED37
No fault code found.
Address 15: Airbags       Labels: 8E0-959-655-84.LBL
   Controller: 8E0 959 655 B
   Component: Airbag 8.4EP        2000
   Coding: 0010702
   Shop #: WSC 63351
   VCID: 361FA5DB015F
Address 16: Steering wheel       Labels: 8E0-953-549.LBL
   Controller: 8E0 953 549 F
   Component: Lenksáulenmodul     0308
   Coding: 00001
   Shop #: WSC 63351
   VCID: 361FA5DB015F
Address 17: Instruments       Labels: 8E0-920-9xx-8E2.LBL
   Controller: 8E0 920 900 L
   Component: KOMBI+WEGFAHRS. RB4 D36
   Coding: 00000
   Shop #: WSC 10603
   VCID: 2D2D8AB7F409
   WAUZZZ8E23A262499     AUZ6Z0B0380154
3 Faults Found:
00779 -  Outside Air Temp Sensor (G17)
01176 -  Key
            07-10 -  Signal too Low - Intermittent
00668 -  Supply Voltage Terminal 30
            53-10 -  Supply Voltage Too Low - Intermittent
Address 46: Central Conv.       Labels: 8E0-959-433-MIN.LBL
   Controller: 8E0 959 433 AR
   Component: Komfortgerát T85    1310
   Coding: 06720
   Shop #: WSC 63351
   VCID: 817586079811
5 Faults Found:
00955 -  Key 1
00956 -  Key 2
00957 -  Key 3
01559 -  Drivers Door
            60-10 -  Won't Safe - Intermittent
01331 -  Door Control Module; Driver Side (J386)
Address 56: Radio       Labels: 8E0-035-1xx-56.LBL
   Controller: 8E0 035 186
   Component: concert II  GRO    0008
   Coding: 01001
   Shop #: WSC 63351
   VCID: E4BBAF936743
2 Faults Found:
01317 -  Control Module in Instrument Cluster (J285)
            49-10 -  No Communications - Intermittent
00858 -  Connection; Radio ZF Output to Antenna Amplifier
            36-00 -  Open Circuit
End   --------------------------------------------------------------------------------------------------
Edytowane przez mikus933
1. Ściągnij wersje z forum - jest zarejestrowana to nie będziesz widział "Shareware Version. To Decode all DTCs"
2. Próbowałeś usunąć wszystkie błędy ? Czy te wszystkie powróciły po usunięciu?
Dziś dopiero dostałem kabel. Błąd usunąłem pojeżdżę i zobaczę czy pojawi się znowu. Zauważyłem też, że jak stoi na biegu jałowym bez dodawania gazu lekko trzęsie autem.
Witam.
Po usunięciu błędu Engine dziś znowu się pojawił. Co ten błąd sygnalizuje?
1 godzinę temu, mikus933 napisał:
Witam.
wszystko praktycznie ;) bez zczytania bledow mozna wrozyc
Po usunięciu błędów pojawia mi się tylko ten:
Sunday, 15 July 2018, 12:25:18:0
Address 01: Engine       Labels: 06B-906-018-AVJ.LBL
   Coding: 0011501
   Shop #: WSC 63351
   VCID: 6F9150BF3E85
1 Fault Found:
17544 -  Fuel Trim: Bank 1 (Add): System too Lean
            P1136 - 001 -  Upper Limit Exceeded
Readiness: 0000 1001
Co może oznaczać? Możliwe, że przepływomierz?
Oczywiscie, ze moze byc przeplywka, ale jest tez pare innych rzeczy, ktore moga powodowac taki problem
