sandall Opublikowano 11 Lipca 2018 Opublikowano 11 Lipca 2018 (edytowane) Witam, jakis czas temu podlczylem pod kompa auto i mam 3 takie bledy, czy ktos jest w stanie mi powiedziec co to i jak usunac usterke? z tlumaczenia rozumiem tyle, ze cos z powietrzem, alarmem i glosnikiem z gory dziekuje! VCDS-Lite Windows Based VAG/VAS Emulator Version: Release 1.2 www.Ross-Tech.com Workshop Code: 000 00000 Self-Diagnosis Log Saturday, 30 June 2018, 13:20:11:0 VIN Number: License Plate: Mileage: Repair Order: Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Controller: 3B0 907 551 T Component: 2.8L V6/5V G 0001 Coding: 05701 Shop #: WSC 06435 VCID: 341B9FD31723 1 Fault Found: 17840 - Secondary Air Injection Solenoid Valve (N112): Open Circuit P1432 - 35-00 - - Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8D0-907-389.LBL Controller: 8D0 907 389 A Component: ABS/ESP allrad D05 Coding: 04295 Shop #: WSC 06435 VCID: 311596C7E831 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8D0-820-043-1D.LBL Controller: 8D0 820 043 N Component: A4 KLIMAAUTOMAT D53 Coding: 00060 Shop #: WSC 06435 VCID: 2B2984AFCA1D No Faults Found or DTCs not supported by controller or a communication error ocurred ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8D0-959-655-AI8.LBL Controller: 8D0 959 655 J Component: Airbag Front+Seite 0001 Coding: 00104 Shop #: WSC 06435 VCID: 3D0DBAF72469 No fault code found. ------------------------------------------------------------------------------- VCDS-Lite Self-Diagnosis Log Saturday, 30 June 2018, 13:20:11:0 Page 2 VIN Number: License Plate: Address 17: Instruments Labels: 8D0-919-xxx-17.LBL Controller: 8D0 919 881 J Component: B5-KOMBIINSTR. VDO D15 Coding: 04062 Shop #: WSC 00000 VCID: 3A07B1EB3547 IMMO-IDENTNR: AUZ7Z0W0771714 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: None Controller: Bit teA dre ssv Component: e 17 eingeben VCID: D0D3734303FB No Faults Found or DTCs not supported by controller or a communication error ocurred ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.LBL Controller: 8D0 862 257 Component: ZV-Pumpe, DWA, Funk D12 Coding: 13131 Shop #: WSC 06435 VCID: EAA7C1AB8567 1 Fault Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.LBL Controller: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00001 Shop #: WSC 06325 VCID: E0B3A383735B No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8D0-035-1xx-56.LBL Controller: 4B0 035 186 C Component: Radio 0001 Coding: 00201 Shop #: WSC 01059 VCID: 20336383B3DB 1 Fault Found: 00852 - Loudspeaker(s); Front 36-00 - Open Circuit End -------------------------------------------------------------------------------------------------- Edytowane 11 Lipca 2018 przez sandall
soulmaster3m Opublikowano 11 Lipca 2018 Opublikowano 11 Lipca 2018 (edytowane) 17840 - Secondary Air Injection Solenoid Valve (N112): Open Circuit P1432 - 35-00 - - Prawdopodobnie przerwany przewód do elektrozaworu spod kolektora choć i może pompa SAI nie działa. http://wiki.ross-tech.com/wiki/index.php/17840/P1432/005170 01370 - Alarm triggered by Interior Monitoring 35-00 - - Czujnik ruchu wyzwolił alarm. Taka aktywacja alarmu nie znika z pompki po wyłączeniu alarmu. http://wiki.ross-tech.com/wiki/index.php/01370 00852 - Loudspeaker(s); Front 36-00 - Open Circuit Prawdopodobnie przerwany przewód/y głośników z przodu. http://wiki.ross-tech.com/wiki/index.php/00852 Nie wiem czego tutaj nie rozumieć? Przecież to nawet translator powie o co chodzi jeśli nie ablasz inglese. Edytowane 11 Lipca 2018 przez soulmaster3m
sandall Opublikowano 11 Lipca 2018 Autor Opublikowano 11 Lipca 2018 Dziekuje za info. Jak pozbyc sie bledu alarmu? Bo kasowanie go nic nie daje, ciagle jest. Blad glosnika przod hmm one dzialaja wiec nie wiem co tu sprawdzac. Z tym powietrzem bede musial zobaczyc.
soulmaster3m Opublikowano 11 Lipca 2018 Opublikowano 11 Lipca 2018 Skoro usuwasz błąd związany z alarmem a wraca to znaczy, że nie wynikł z wyzwolenia alarmu czujnikami ruchu a z problemu z ich sterownikiem lub przewodami. Głośniki może i grają, jednak skądś błąd jest. Może masz inne wstawione i impedancja nie odpowiada. Może to, może tamto.
