A6 c6 2.0tdi
Kolega ma problem kontrolka check engine. Ma takie błedy:
Friday,15,November,2019,21:05:53:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WAUZZZ4F57N035062   License Plate:
                Address 01: Engine       Labels: Redir Fail!
Control Module Part Number: 03G 906 016 GC    HW: 03G 906 016 GC
  Component and/or Version: R4 2,0L EDC G000CG  9887
           Software Coding: 0000076
            Work Shop Code: WSC 25712 136 85175
                      VCID: 6ADC19EA45E4A91157-803E
3 Faults Found:
012546 - Motor for Intake Manifold Flap (V157)
               P3102 - 000 - No Signal - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 1
                    Fault Frequency: 24
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Bin. Bits: 00101000
                    Torque: 0.0 Nm
                    Torque: 300.1 Nm
012545 - Motor for Intake Manifold Flap (V157)
               P3101 - 000 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 24
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 250804 km
                    Time Indication: 0
                    Date: 2019.11.09
                    Time: 14:14:39
             Freeze Frame:
                    RPM: 1134 /min
                    Speed: 43.0 km/h
                    Load: 0.0 %
                    Voltage: 13.76 V
                    Bin. Bits: 00101000
                    Torque: 156.2 Nm
                    Torque: 0.0 Nm
Readiness: 1 1 0 0 0
Problem z klapą gaszącą albo sama w sobie jest uszkodzona albo jej połączenie z ecu. Do sprawdzenia wiązka i bezpiecznik.
