Proszę o analizę błędów.
Witam,
Bardzo proszę o wyjaśnienie tych błędów.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76,77
Address 01: Engine       Labels: Redir Fail!
   Controller: 038 906 018 S
   Component:  1,9l R4 EDC   00SG  1630
   Coding: 00002
   Shop #: WSC 06325
   VCID: 263F759BD1FF
1 Fault Found:
17978 -  Engine Start Blocked by Immobilizer
            P1570 - 35-00 -   -
Readiness: N/A
Address 03: ABS Brakes       Labels: 8E0-614-111-ABS.LBL
   Controller: 8E0 614 111 AB
   Component: ABS 5.3 FRONT       D00
   Coding: 0273004281
   Shop #: BB 24548
   VCID: 5ECF1D7BC92F
No fault code found.
Address 08: Auto HVAC       Labels: 8E0-614-111-ABS.LBL
   Controller: 8L0 820 043 D
   VCID: 29257EA7C0E1
   Note: Excessive Comm Errors
Address 15: Airbags       Labels: 8D0-959-655-AI7.LBL
   Controller: 8D0 959 655 L
   Component: Airbag 7 Audi      0503
   Coding: 00106
   Shop #: WSC 06325
   VCID: 3FF1C0FF2E65
Address 17: Instruments       Labels: 8D0-919-xxx-17.LBL
   Controller: 8D0 919 861 A
   Component: B5-KOMBIINSTR.UN4   D06
   Coding: 00040
   Shop #: WSC 00186
   VCID: 2F1190BFFE05
   IMMO-IDENTNR: AUZ8Z0W9070021
1 Fault Found:
01176 -  Key
            07-10 -  Signal too Low - Intermittent
Address 25: Immobilizer       Labels: None
   Controller: Bit teA dre ssw
   Component: e 17 eingeben
   VCID: D1D5764708F1
No Faults Found
  or DTCs not supported by controller
  or a communication error ocurred
Address 35: Centr. Locks       Labels: 8D0-862-257.LBL
   Controller: 8L0 862 257 L
   Component: ZV-Pumpe            D10
   Coding: 00000
   Shop #: WSC 06325
   VCID: 3E0FBDFB296F
4 Faults Found:
01367 -  Central Locking Pump Run Time Exceeded (Likely Leak)
            35-00 -   -
01361 -  Switch for Anti-Theft Alarm; Close
            29-00 -  Short to Ground
01365 -  Lock/Unlock Switch; Interior
00991 -  Interior Lights
            28-00 -  Short to Plus
Address 56: Radio       Labels: 8D0-035-1xx-56.LBL
   Controller: 4B0 035 186 E
   Component:  Radio             0001
   Coding: 00201
   Shop #: WSC 06335
   VCID: 2237698BBDD7
2 Faults Found:
00856 -  Radio Antenna
            36-00 -  Open Circuit
00852 -  Loudspeaker(s); Front
czy oprócz zapisanych błędów coś jest nie tak z autem, odpala??? Po ich wykasowaniu błędy powracają???
Mniemam, że błąd dotyczący radia raczej nie wymaga tłumaczenia.
Auto pali i jeździ prawidłowo, błędy wykasowane, za jakiś czas sprawdzę czy powracają. Jedyne co mi dokucza to nie zawsze trybi centralny zamek z pilota. Czasami nie otwiera drzwi i muszę to zrobić kluczykiem.
a baterie w pilocie wymieniałeś??
