Brak dzwięku , ochrona komponentu
Witam w moim a4 B8 nagle wyskoczył komunikat , wszystko działa ale nie ma dzwieku
reset ami nic nie dał , odłaczenie aku też
nic nie dokładane . oryg mmi 3g+  z audi sound system
błedy
Saturday,23,January,2021,16:28:42:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: WAUZZZ8K6EN009929   License Plate:
Chassis Type: 8K (8R0)
Scan: 01 03 05 08 09 15 16 17 19 20 42 44 46 52 53 56 5F 62 72
VIN: WAUZZZ8K6EN009929   Mileage: 138200km-85873miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: Not registered 0001
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Not registered 0011
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CJEB)       Labels: None
   Part No SW: 8K0     HW: 8K0 906 264
   Component: 1.8H09 0003
   Revision: --H09---
   Coding: 0A190032232401022000
   ASAM Dataset: Unkonwn 001003
   ROD: N/A
   VCID: 3362C48E9AAE28DA71-8066
No ASAM data for: "Unkonwn" (AU48)
No fault code found.
Readiness: 0110 0001
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CE    HW: 8K0 907 379 CE
   Component: ESP8 front    H09 0050
   Revision: --------    Serial number: --------------
   Coding: 031DCC01
   Shop #: WSC 02391 785 00200
   VCID: 7EF425BAE96C35B2CE-802A
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 GD    HW: 8K0 907 064 FD
   Component: BCM2 2.0      H12 0633
   Revision: 00002001
   Coding: 03A14040000000000000
   VCID: 78F833A2CB480B8284-802C
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Component: FBSAUDIB8 IDG  H71 0083
   Serial number: 0813000097654014
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Component: J764 ELV MLB  H40 0046
   Serial number: 2313000137907005
Address 08: Auto HVAC (J255)       Labels: Redir Fail!
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Component: KLIMA 3 ZONEN H04 0121
   Revision: C1000000    Serial number: 01150720130367
   Coding: 642002C000
   VCID: 397EF6A6B0C2D28ABB-806C
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Component: BCM1 1.0      H16 0103
   Revision: 08016001    Serial number: 00000649311202
   Coding: 260000108174AFC00081400300001D0D4F1C020826090201000008004400020100000020000000
   Shop #: WSC 12345 123 61029
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA020713  H18 0461
   Serial number: 13062707012030
   Coding: 004577
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0002
   Serial number: 21535128
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001007134520
   Subsystem 4 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0003
   Serial number: FE68CAB6000000000001
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KFDB0WT1
   Coding: 30514435363030303030554A304C384B3053
   Shop #: WSC 13686 002 1048576
   ASAM Dataset: EV_AirbaECUVWAUDI010 003010
   ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
   VCID: 48988362F328BB0234-801C
   Crash sensor for side airbag: driver side:
   Serial number: 6334MSME7B626659P
   Crash sensor for side airbag: front passenger side:
   Serial number: 6344MSME7A15206CH
   Crash sensor for side airbag: rear: driver side:
   Serial number: 6352QSME01421470$
   Crash sensor for side airbag: rear: passenger side:
   Serial number: 6362QSME7131056CD
   Crash sensor for front airbag: driver side:
   Serial number: 63732SME42333764V
   Crash sensor for front airbag: front passenger side:
   Serial number: 63832SME48480450X
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862MGG000AS
   Coding: 000016
   VCID: 48988362FB28BB0234-801C
   Component: E221 - MFL  H03 0004
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 931 T    HW: 8K0 920 931 T
   Component: KOMBIINSTR.   H35 0563
   Revision: 00500000    Serial number: WWA66DF7E
   Coding: 03AD080003010008000002
   VCID: 3F8A98BEAEE6FCBA85-806A
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0056
   Revision: 1Z110028    Serial number: 2841Z137020112
   Coding: 80CF07FF00
   VCID: 4C90BF72EF50572210-8018
   Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
   Component: J367-BDMHella  H03 8041
   Serial number: 2687280803
   Subsystem 2 - Part No SW: 8K0 959 663     HW: 8K0 959 663
   Component: J532_DCDCStab  H17 0042
   Serial number: 13189001260021200181
4 Faults Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 238
                    Mileage: 138209 km
                    Time Indication: 0
                    Date: 2021.01.23
                    Time: 14:45:19
             Freeze Frame:
                    Bin. Bits:    11111
                    Voltage: 14.60 V
                    Count: 6
00463 - Control Module for Digital Sound Package (J525)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 23
                    Mileage: 138209 km
                    Time Indication: 0
                    Date: 2021.01.23
                    Time: 14:53:33
             Freeze Frame:
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
                    Bin. Bits:    10000
02076 - Media Player Position 1 (R118)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 23
                    Mileage: 138209 km
                    Time Indication: 0
                    Date: 2021.01.23
                    Time: 14:55:06
             Freeze Frame:
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 6
                    Bin. Bits:    10000
02230 - Digital Radio (DAB) (R147)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 23
                    Mileage: 138209 km
                    Time Indication: 0
                    Date: 2021.01.23
                    Time: 14:55:06
             Freeze Frame:
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 6
                    Bin. Bits:    10000
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02019164747464545425363E00
   VCID: 7CF02FB2FF7027A2E0-8028
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C02204000410001
   VCID: 56A45D1A219C1DF2B6-8002
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8K0 909 144 F    HW: 8K0 909 144 B
   Component: RCEPS         H38 0507
   Revision: 00001000    Serial number: 0016681356
   Coding: 100000000001
   ASAM Dataset: EV_RCEPSAU48X 008014
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3460C7929FA02FE268-8060
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0310588321
   Coding: 0100062800B900408330013680000047
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   Coding: 011C02204C00410001
   VCID: 55A65A163C9A16EABF-8000
Address 53: Parking Brake (----)       Labels: 8K0-907-801-V2.clb
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 10000000243216
   ASAM Dataset: EV_ParkiBrake 001028
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 397EF6A6B8C2D28ABB-806C
Address 56: Radio (R)       Labels: Redir Fail!
   Part No SW: 4G0 035 056 J    HW: 4G0 035 056
   Component: Radio U STD   H60 0133
   Revision: AB001007    Serial number: 230GO0D2829020
   Coding: 010003020100000001
   VCID: 285823E25B685B02D4-807C
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
   Part No SW: 8R1 035 670 F    HW: 8R1 035 670 C
   Component: H-BNT-EU      H46 0739
   Revision: --------    Serial number: 207G10D7555287
   Coding: 0F0100000006E1ED01808B5E00000403040000000000000000
   VCID: 3664FD9A81DC3DF256-8062
   Subsystem 1 - Part No: 8R0 060 884 BC
   Component: EUR 2013/2014  1603
   Subsystem 2 - Part No SW: 8R0 919 604 A    HW: 8R0 919 604 A
   Component: DU7 High  H42 0104
   Serial number: A130GS0D2783044
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Component: E0380 Bedient  H02 0030
   Serial number: 00000001567135
   Subsystem 4 - Part No: 8R0 060 961 F
   Component: CD-Database  5298
1 Fault Found:
02095 - Component Protection Active
            000 -  -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 238
                    Mileage: 138209 km
                    Time Indication: 0
                    Date: 2021.01.23
                    Time: 14:59:24
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C02204000210001
   VCID: 59BE56265082328A9B-800C
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Component: TSG HR        H07 0305
End-------------------------(Elapsed Time: 02:58)--------------------------
Napięcie aku niskie tylko 11,4 V. Odłączyło audio kosztem ważniejszych funkcji. Podładuj aku wykasuj błędy.
jeżdziłem jeszcze wczoraj autem to aku powinno być podładowane . a błąd dalej jest
to ochrona komponentu się chyba załączyła
Przy tak rozładowanym aku pół godziny jazdy nie wystarczy.
Zmierz sobie napięcie aku. Podładuj aku paré godzin. Wykasuj błędy i zobacz czy powrócą.
nie mam prostownika do agm więc auto chodzi na wolnych obrotach , poźniej jeszcze zrobie trase , ale jak ja mam taki błąd to raczej nic to nie da
