Silus Opublikowano 16 Lutego 2021 Opublikowano 16 Lutego 2021 Witam. Wyskoczyl mi blad wiec podlaczylem VCDSa i odczytalem bledy. Problem w tym ze po angielsku i nie moge za bardo sie polapac o co chodzi. Dodam ze bledy usunalem lecz na drugi dzien znowu to wyskoczylo. Moglby ktos pomoc? Dzieki za odpowiedzi. Cytat -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: 03L-906-019-CAG.clb Control Module Part Number: 03L 906 022 NN HW: 03L 906 019 AL Component and/or Version: R4 2.0l TDI X21 9980 Software Coding: 12194012232403080000 Work Shop Code: WSC 26214 051 00000 ASAM Dataset: EV_ECM20TDI03L906022NN A02016 (AU48) ROD: EV_ECM20TDI03L906022NN.rod VCID: 7EF348F9E1F772BAA7-802A 7 Faults Found: 4695 - Function Restriction due to Faults in Other Modules U1113 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 7 Mileage: 217612 km Date: 2020.11.01 Time: 12:20:06 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 60 °C Intake air temperature: 31 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.920 V Unlearning counter according OBD: 28 Cruise Control System (CCS): switch position-Bits 0-7: 129 CCS status-Bits 0-7: 40 Cr Ctl st Sh Off Irv Lst-Bits 0-7: 255 Cr Ctl st Sh Off Rv Lst-Bits 0-7: 255 Cr Ctl v Des Dspl: 0.00 km/h Sig Reset Env x Id-Bits 0-7: 0 Sig Reset Env x Id-Bits 0-7: 0 Cr Ctl st Shut Offirev-Bits 0-7: 0 4698 - Function Restriction due to Faults in Other Modules U1113 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 7 Mileage: 217612 km Date: 2020.11.01 Time: 12:20:06 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 60 °C Intake air temperature: 31 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.920 V Unlearning counter according OBD: 28 Cruise Control System (CCS): switch position-Bits 0-7: 129 CCS status-Bits 0-7: 40 Cr Ctl st Sh Off Irv Lst-Bits 0-7: 255 Cr Ctl st Sh Off Rv Lst-Bits 0-7: 255 Cr Ctl v Des Dspl: 0.00 km/h Sig Reset Env x Id-Bits 0-7: 0 Sig Reset Env x Id-Bits 0-7: 0 Cr Ctl st Shut Offirev-Bits 0-7: 0 4699 - Function Restriction due to Faults in Other Modules U1113 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 7 Mileage: 217612 km Date: 2020.11.01 Time: 12:20:06 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 60 °C Intake air temperature: 31 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.920 V Unlearning counter according OBD: 28 Cruise Control System (CCS): switch position-Bits 0-7: 129 CCS status-Bits 0-7: 40 Cr Ctl st Sh Off Irv Lst-Bits 0-7: 255 Cr Ctl st Sh Off Rv Lst-Bits 0-7: 255 Cr Ctl v Des Dspl: 0.00 km/h Sig Reset Env x Id-Bits 0-7: 0 Sig Reset Env x Id-Bits 0-7: 0 Cr Ctl st Shut Offirev-Bits 0-7: 0 5231 - Fuel Rail/System Pressure P0087 00 [032] - Too Low Intermittent - Not Confirmed - Tested Since Memory Clear 5555 - Exhaust Gas Temperature Sensor 4 Bank 1 P246F 00 [068] - Implausible Signal Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 0 Mileage: 213385 km Date: 2000.00.00 Time: 00:00:00 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 255 km/h Coolant temperature: 83 °C Intake air temperature: 30 °C Ambient air pressure: 990 mbar Voltage terminal 30: 12.580 V Unlearning counter according OBD: 40 Accelerator position: 0.00 % Coolant temperature at radiator outlet: actual value: 78.1 °C Ct T t Diff Radiator: -273.1 °C Ambient temperature: 22.0 °C Fl Sys dvol Fl Cons All Tot: 0.00 l/h Fuel temperature: 48.9 °C Engine oil temperature: 99.9 °C 7859 - Intake Manifold Flap Position Sensor (Bank 1) P2015 00 [168] - Implausible Signal MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 4 Mileage: 222172 km Date: 2021.02.05 Time: 14:07:44 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 31 °C Intake air temperature: 4 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 13.080 V Unlearning counter according OBD: 40 Actual air mass: 0.0 mg/stroke Intake manifold Runner Control (IMRC): activation: 100.00 % Intake manifold Runner Control (IMRC): acknowledgment: 100.51 % V Sw Vlv r Drft Clsd mp: 4.80 % V Sw Vlv r Drft Opn mp: 11.55 % V Sw Vlv st Mon-Bits 0-7: 55 V Sw Vlv st Mon-Bits 0-7: 0 V Sw Vlv st Mon-Bits 0-7: 2 V Sw Vlv st Mon-Bits 0-7: 0 V Sw Vlv u Raw: 0.0 mV 4629 - ECM Power Relay Load Circuit P068A 00 [032] - Opens Too Early Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 9 Mileage: 0 km Date: 2000.00.00 Time: 00:00:00 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: -40 °C Intake air temperature: -40 °C Ambient air pressure: 0 mbar Voltage terminal 30: 0.000 V Unlearning counter according OBD: 40 Accelerator position: 0.00 % Starter control: Interlock- or P/N-signal-Bits 0-7: 0 Co Eng st: COENG_STANDBY Co Eng st-Test_Program_Co Eng st COMPU VERB UBYTE: 0 Readiness: 1 1 0 0 0
Muskel1 Opublikowano 16 Lutego 2021 Opublikowano 16 Lutego 2021 Wrzuć pełny autoscan ze wszystkich sterowników. W sterowniku silnika jest informacja, żeby odczytać błędy z innych sterowników.
Silus Opublikowano 16 Lutego 2021 Autor Opublikowano 16 Lutego 2021 Cytat -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8K-AU48 (8T0) Scan: 01 03 05 08 09 10 15 16 17 19 20 3C 42 46 52 53 55 56 5F 62 72 VIN: WAUZZZ8K3AA087280 Mileage: 222260km-138105miles 01-Engine -- Status: Malfunction 1010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 20-High Beam Assist. -- Status: OK 0000 3C-Lane Change -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAGA) Labels:. 03L-906-019-CAG.clb Part No SW: 03L 906 022 NN HW: 03L 906 019 AL Component: R4 2.0l TDI X21 9980 Revision: 25X21--- Coding: 12194012232403080000 Shop #: WSC 26214 051 00000 ASAM Dataset: EV_ECM20TDI03L906022NN A02016 ROD: EV_ECM20TDI03L906022NN.rod VCID: 7EF348F9E1F772BAA7-802A 7 Faults Found: 4695 - Function Restriction due to Faults in Other Modules U1113 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 7 Mileage: 217612 km Date: 2020.11.01 Time: 12:20:06 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 60 °C Intake air temperature: 31 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.920 V Unlearning counter according OBD: 28 Cruise Control System (CCS): switch position-Bits 0-7: 129 CCS status-Bits 0-7: 40 Cr Ctl st Sh Off Irv Lst-Bits 0-7: 255 Cr Ctl st Sh Off Rv Lst-Bits 0-7: 255 Cr Ctl v Des Dspl: 0.00 km/h Sig Reset Env x Id-Bits 0-7: 0 Sig Reset Env x Id-Bits 0-7: 0 Cr Ctl st Shut Offirev-Bits 0-7: 0 4698 - Function Restriction due to Faults in Other Modules U1113 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 7 Mileage: 217612 km Date: 2020.11.01 Time: 12:20:06 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 60 °C Intake air temperature: 31 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.920 V Unlearning counter according OBD: 28 Cruise Control System (CCS): switch position-Bits 0-7: 129 CCS status-Bits 0-7: 40 Cr Ctl st Sh Off Irv Lst-Bits 0-7: 255 Cr Ctl st Sh Off Rv Lst-Bits 0-7: 255 Cr Ctl v Des Dspl: 0.00 km/h Sig Reset Env x Id-Bits 0-7: 0 Sig Reset Env x Id-Bits 0-7: 0 Cr Ctl st Shut Offirev-Bits 0-7: 0 4699 - Function Restriction due to Faults in Other Modules U1113 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 7 Mileage: 217612 km Date: 2020.11.01 Time: 12:20:06 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 60 °C Intake air temperature: 31 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 11.920 V Unlearning counter according OBD: 28 Cruise Control System (CCS): switch position-Bits 0-7: 129 CCS status-Bits 0-7: 40 Cr Ctl st Sh Off Irv Lst-Bits 0-7: 255 Cr Ctl st Sh Off Rv Lst-Bits 0-7: 255 Cr Ctl v Des Dspl: 0.00 km/h Sig Reset Env x Id-Bits 0-7: 0 Sig Reset Env x Id-Bits 0-7: 0 Cr Ctl st Shut Offirev-Bits 0-7: 0 5231 - Fuel Rail/System Pressure P0087 00 [032] - Too Low Intermittent - Not Confirmed - Tested Since Memory Clear 5555 - Exhaust Gas Temperature Sensor 4 Bank 1 P246F 00 [068] - Implausible Signal Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 0 Mileage: 213385 km Date: 2000.00.00 Time: 00:00:00 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 255 km/h Coolant temperature: 83 °C Intake air temperature: 30 °C Ambient air pressure: 990 mbar Voltage terminal 30: 12.580 V Unlearning counter according OBD: 40 Accelerator position: 0.00 % Coolant temperature at radiator outlet: actual value: 78.1 °C Ct T t Diff Radiator: -273.1 °C Ambient temperature: 22.0 °C Fl Sys dvol Fl Cons All Tot: 0.00 l/h Fuel temperature: 48.9 °C Engine oil temperature: 99.9 °C 7859 - Intake Manifold Flap Position Sensor (Bank 1) P2015 00 [172] - Implausible Signal MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 4 Mileage: 222172 km Date: 2021.02.05 Time: 14:07:44 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 31 °C Intake air temperature: 4 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 13.080 V Unlearning counter according OBD: 40 Actual air mass: 0.0 mg/stroke Intake manifold Runner Control (IMRC): activation: 100.00 % Intake manifold Runner Control (IMRC): acknowledgment: 100.51 % V Sw Vlv r Drft Clsd mp: 4.80 % V Sw Vlv r Drft Opn mp: 11.55 % V Sw Vlv st Mon-Bits 0-7: 55 V Sw Vlv st Mon-Bits 0-7: 0 V Sw Vlv st Mon-Bits 0-7: 2 V Sw Vlv st Mon-Bits 0-7: 0 V Sw Vlv u Raw: 0.0 mV 4629 - ECM Power Relay Load Circuit P068A 00 [032] - Opens Too Early Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 9 Mileage: 0 km Date: 2000.00.00 Time: 00:00:00 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: -40 °C Intake air temperature: -40 °C Ambient air pressure: 0 mbar Voltage terminal 30: 0.000 V Unlearning counter according OBD: 40 Accelerator position: 0.00 % Starter control: Interlock- or P/N-signal-Bits 0-7: 0 Co Eng st: COENG_STANDBY Co Eng st-Test_Program_Co Eng st COMPU VERB UBYTE: 0 Readiness: 1 1 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 AK HW: 8K0 907 379 AK Component: ESP8 front H04 0070 Revision: -------- Serial number: -------------- Coding: 160504 Shop #: WSC 06325 000 00000 VCID: 020B3C099D0F165AC3-8056 2 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 53 Reset counter: 109 Mileage: 213443 km Time Indication: 0 Date: 2020.08.31 Time: 11:21:58 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0782 Hex Value: 0x0027 Hex Value: 0xB999 Hex Value: 0x00FF 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 50 Reset counter: 109 Mileage: 213443 km Time Indication: 0 Date: 2020.08.31 Time: 11:21:58 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x2782 Hex Value: 0x002E Hex Value: 0x0299 Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0326 Revision: 00002001 Coding: 032200 Shop #: WSC 06325 000 00000 VCID: 0109330598090D42DA-8054 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Serial number: 0509000064325009 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 Serial number: 0209000084477008 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 57 Reset counter: 109 Mileage: 222242 km Time Indication: 0 Date: 2021.02.09 Time: 14:05:42 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AH HW: 8T1 820 043 AH Component: KLIMA 1 ZONE H08 0171 Revision: A1000000 Serial number: 01051120090835 Coding: 34300000 Shop #: WSC 06325 000 00000 VCID: 77FD5DDDC6CD43F2E4-8022 2 Faults Found: 03220 - Stop Valve for Coolant for Climatronic (N422) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 107 Mileage: 222058 km Time Indication: 0 Date: 2021.02.02 Time: 13:42:46 01314 - Engine Control Module 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 107 Mileage: 222058 km Time Indication: 0 Date: 2021.02.02 Time: 13:42:46 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 P HW: 8K0 907 063 P Component: BCM1 1.0 H25 0380 Revision: 10025001 Serial number: 00000000385060 Coding: 260050904174AF000001000300001D0D0F1C070804010101000000 Shop #: WSC 06325 123 12345 VCID: 3C7782F1BF6BA0AAC9-8068 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 021109 H06 0070 Serial number: SWF09110025714 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 10665430 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL Component: E1 - LDS H08 0090 Serial number: 00000000002810090570 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb Part No SW: 8K0 919 475 J HW: 8K0 919 475 A Component: PARKHILFE 8K H06 0050 Revision: 11001001 Serial number: 39840931406032 Coding: 100203 Shop #: WSC 06325 000 00000 VCID: 408FF601D383C44A95-8014 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 12 Reset counter: 100 Mileage: 218526 km Time Indication: 0 Date: 2020.11.30 Time: 17:54:11 Freeze Frame: Temperature: 6.0°C ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8K0-959-655.clb Part No SW: 8K0 959 655 G HW: 8K0 959 655 G Component: AirbagVW-AU10 H39 0560 Serial number: 003EFD0740P Coding: 30343435363030303030554A304C384B3053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 4189F305D089CD429A-8014 Crash sensor for side airbag: driver side: Serial number: 6334MSME4B24195FO Crash sensor for side airbag: front passenger side: Serial number: 6344MSME4D0128507 Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME24412F34C Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME31420E2EI Crash sensor for front airbag: driver side: Serial number: 63732SME73422130L Crash sensor for front airbag: front passenger side: Serial number: 63832SME63425014P No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90315IK6000IS Coding: 000017 Shop #: WSC 06325 000 00000 VCID: 3D718FF5A471A9A2FE-8068 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 930 D HW: 8K0 920 930 D Component: KOMBIINSTR. H20 0255 Revision: 00000000 Serial number: CIY75K2C9 Coding: 030D10000A000008000000 Shop #: WSC 06325 123 12345 VCID: 2E53B8B97917423A77-807A 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 44 Reset counter: 107 Mileage: 213443 km Time Indication: 0 Date: 2020.08.31 Time: 11:21:58 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L Component: GW-BEM 5CAN-M H10 0105 Revision: FB900055 Serial number: 5500F09A2600CC Coding: 00CF07 Shop #: WSC 06325 000 00000 VCID: 000F36019303044AD5-8054 Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181 Component: J367-BDM H07 0125 Serial number: 00000000002790767411 Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663 Component: J532_DCDCStab H14 0037 Serial number: 09291000019011200180 2 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 109 Mileage: 213443 km Time Indication: 0 Date: 2020.08.31 Time: 11:21:58 Freeze Frame: Bin. Bits: 00111 Voltage: 12.20 V Count: 6 Bin. Bits: 10000 Time: 0.40 s 01312 - Powertrain Data Bus 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 254 Reset counter: 109 Mileage: 213443 km Time Indication: 0 Date: 2020.08.31 Time: 11:22:03 Freeze Frame: Bin. Bits: 10000 Voltage: 12.10 V Count: 7 Bin. Bits: 10011 ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb Part No SW: 8K0 857 511 E HW: 8K0 857 511 A Component: FLA H04 0004 Revision: AA001002 Coding: 02019164747464545425363E Shop #: WSC 06325 000 00000 VCID: 3365A9CD92356FD218-8066 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: None Part No SW: 8K0 907 566 H HW: 4L0 907 566 B Component: J0769_SWA_MasterH01 0010 Revision: 00H01000 Serial number: 6PZ 009 014-82 Coding: 0000102 Shop #: WSC 06325 000 00000 VCID: 3C7782F17F6BA0AAC9-8068 Subsystem 1 - Part No: 8K0 907 568 H Component: J0770_SWA_Slave_H01 0010 Subsystem 2 - Serial number: 6PZ 009 014-92 Subsystem 3 - Serial number: 5F06.11.0900H010003C320419ÿ Subsystem 4 - Serial number: 320419ÿ 2 Faults Found: 02854 - Warning Lamp for Lane Change Assistance (in right exterior mirror) (K234) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 42 Reset counter: 94 Mileage: 208825 km Time Indication: 0 Date: 2020.06.29 Time: 08:32:29 02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 5 Reset counter: 93 Mileage: 218928 km Time Indication: 0 Date: 2020.12.14 Time: 13:52:26 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 H HW: 8K0 959 793 D Component: TSG FA H11 0306 Revision: Serial number: 0000009602280 Coding: 011C02205000410001 Shop #: WSC 06325 000 00000 VCID: 4581E715CCA1E162A6-8010 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0326 Revision: 00002001 Serial number: 0123582399 Coding: 01000620203904C00220023680000000 Shop #: WSC 06325 123 12345 VCID: 0109330598090D42DA-8054 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 57 Reset counter: 109 Mileage: 222242 km Time Indication: 0 Date: 2021.02.09 Time: 14:05:42 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 H HW: 8K0 959 792 D Component: TSG BF H11 0306 Revision: Serial number: 0000009586004 Coding: 011C02205C00410001 Shop #: WSC 06325 123 12345 VCID: 4487FA11C79BD86AB1-8010 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 10000000361832 Shop #: WSC 00000 000 00000 VCID: 3467AAD1973B68EA01-8060 2 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 60 Reset counter: 109 Mileage: 213443 km Time Indication: 0 Date: 2020.08.31 Time: 11:21:58 Freeze Frame: Voltage: 12.40 V Count: 64 Speed: 0.0 km/h Hex Value: 0x0260 Hex Value: 0x0001 Hex Value: 0x0101 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 109 Mileage: 222242 km Time Indication: 0 Date: 2021.02.09 Time: 14:05:43 Freeze Frame: Voltage: 13.30 V Count: 58 Speed: 0.0 km/h Hex Value: 0x0270 Hex Value: 0x0001 Hex Value: 0x0102 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8T0-907-357.clb Part No SW: 8H0 907 357 B HW: 8H0 907 357 B Component: AFS 1 H01 0030 Revision: 00000001 Serial number: Coding: 0000019 Shop #: WSC 06324 000 00000 VCID: 3169A3C5A8295DC26A-8064 Subsystem 1 - Part No: 8K0 941 329 Component: AFS-Modul links H02 S001 Subsystem 2 - Part No: 8K0 941 329 Component: AFS-Modul rechtsH02 S001 3 Faults Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 40 Mileage: 198581 km Time Indication: 0 Date: 2020.02.01 Time: 15:32:32 02071 - Local Databus 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 40 Mileage: 188746 km Time Indication: 0 Date: 2019.08.14 Time: 11:40:44 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 40 Mileage: 219183 km Time Indication: 0 Date: 2020.12.22 Time: 00:49:15 ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4F0 035 056 B HW: 4F0 035 056 Component: Radio U STD H45 0020 Revision: AB001007 Serial number: 342KR097720412 Coding: 010003020100000001 Shop #: WSC 06325 000 00000 VCID: 1F4D557D0EBDDBB2CC-804A No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8T1 035 652 D HW: 8T1 035 652 D Component: B-BN-EU H52 0048 Revision: -------- Serial number: 323K0097536991 Coding: 01010001000681ED11000F0E000000030001 Shop #: WSC 06325 000 00000 VCID: 366390D981477AFA3F-8062 Subsystem 1 - Part No: 4G0 919 884 F Component: EUR 2010 1005 Subsystem 2 - Part No SW: 4L0 919 604 HW: 4L0 919 604 Component: DU6 Basic H43 0306 Serial number: 9355KS091046414 Subsystem 3 - Part No SW: 8T0 919 609 HW: 8T0 919 609 Component: E0380 Bedient H08 0100 Serial number: 00000000398760 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HL H10 0306 Revision: Serial number: 0000102240418 Coding: 010C02204000210001 Shop #: WSC 06325 000 00000 VCID: 428BFC09DD8FD65A83-8016 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HR H10 0306 Revision: Serial number: 0000102240447 Coding: 010C02204000210001 Shop #: WSC 06325 000 00000 VCID: 428BFC09DD8FD65A83-8016 No fault code found. End-------------------------(Elapsed Time: 03:28)--------------------------
Muskel1 Opublikowano 16 Lutego 2021 Opublikowano 16 Lutego 2021 Robiłeś coś przy aucie? Dokładałeś coś lub wgrywałeś softa (chip)?
Silus Opublikowano 16 Lutego 2021 Autor Opublikowano 16 Lutego 2021 (edytowane) Tak, chip był robiony prawie dwa lata temu. 2L 143 na 177 km Edytowane 17 Lutego 2021 przez Silus
Muskel1 Opublikowano 18 Lutego 2021 Opublikowano 18 Lutego 2021 Dokładałeś coś przy elektryce ostatnio?
Silus Opublikowano 18 Lutego 2021 Autor Opublikowano 18 Lutego 2021 Hmm.. nie. Ale akumulator jakieś dwa miesiące temu wymieniałem na nowy. Kodowany też był.
Muskel1 Opublikowano 18 Lutego 2021 Opublikowano 18 Lutego 2021 Jest kilka błędów: Błędy świadczące o niezrozumiałym sygnale, który odbiera sterownik silnika to 4695, 4698, 4699. Jakieś urządzenie podaje niwełaściwe, niezrozumiałe dane do sterownika. Błąd za niskiego ciśnienia paliwa na szynie rail to 5231. Błąd czujnika temperatury spalin 5555 podaje niezrozumiały sygnał) Błąd klapek w kolektorze ssącym 7859 (niezrozumiały sygnał) Błąd przekaźnika 4629 błąd przekaźnika J271 odpowiedzialnego za sterownik silnika.
