Jakie tłoki odprężające 2.0 tfsi bgb
Witam, planuje w swojej maszynce 500+ może 550km, ktoś doradzi jakie tłoki? W sensie ile zejść z Cr? Turbinka to gtx3076
Ile masz na to pieniędzy  ?
Kolego Makaronku,
Na 550-600 PS niewiele trzeba...
Poniżej przepis z UK:
Audi A4 DTM Quattro BUL Engine 2.0TFSI.  (600BHP 510ft\lb)
ENGINE
* Ported/gas flowed head
* Full Supertech valve train, including springs & titanium retainers
* Mk6 Golf R Inlet & Exhaust camshafts
* IE Valve guides and valve stem seals
* AKS Tuning HPFP Roller conversion
* ‪VIS High pressure fuel pump‬
* Nostrum Energy Injectors
* R8 Coil packs
* BKR7EIX Spark plugs
* 155 Bar FPRV
* 200 Bar fuel rail pressure sensor
* IE Inlet manifold port matched to throttle body & cylinder head
* 76mm Throttle body
* Custom billet alloy cam cover/PCV delete
* Cometic head gasket
* Wossner 83.5mm 9.2:1CR
* IE Rifle drilled con rods
* Fluidampr engine damper
* ACL Race rod & main bearings
* Owen Developments GBT6982 turbo Zircotec ceramic coated, Funk Motorsport turbo jacket
* Custom Inconnel tubular exhaust manifold, with 3.5” custom oval stainless exhaust, wrapped in Funk Motorsport heat wrap
* 3 Bar map sensor
* IE Dowel pinned timing gear
* IE Girdle kit
* BAR TEK, 1.8t Race oil pump
* 1.8t oil filter housing with IE adaptor plate
* Nuke Performance competition catch can
* Mocal external oil cooler with thermostatic sandwich plate
* BAR TEK Metal race water pump
* 034 Motorsport Light weight single mass flywheel
* Southbend stage 3 clutch
* 034 Motorsport metal clutch release bearing
* AWE Tuning intercooler/power steering cooler
* TIAL MVR 44mm external wastegate
* TIAL QR 50mm Diverter valve
* ITG JC66/90 foam 4” inlet filter
* ‪034 Motorsport street density engine & gearbox mounts‬
* 034 Motorsport (track) snub mount & bracket
* FULL ARP Bolts/studs throughout entire engine
* RS4 B7 Low pressure fuel pump  Controller
* Metal clutch slave cylinder with braided hose
HANDLING
* BC Racing fully adjustable coilovers
* 034 Motorsport density line strut top mounts
* 034 Motorsport front/rear billet adjustable upper arms
* 034 Motorsport density line lower front arms
* 034 Motorsport heavy duty tie-rod ends
* 034 Motorsport front billet drop links
* 034 Motorsport rear adjustable drop links
* Eibach front & rear anti roll bars
* 034 Motorsport billet rear differential mount inserts
* Rear solid subframe mounts and fully poly bused rear end
* RS4 B7 8pot Brembo callipers & Reyland motorsport discs (Front)
* RS4 B7 Calipers & Reyland motorsport discs (Rear)
* HEL Braided brake lines (front/back)
* Fully poly bushed rear subframe, hubs & arms, solid subframe mounts JHM shortshifter                                Pozdrawiam
1 minutę temu, black4 napisał:
Kolego Makaronku,
ENGINE
* R8 Coil packs
* 155 Bar FPRV
* 3 Bar map sensor
* IE Girdle kit
HANDLING
Wrzuc mu jeszcze cyfry, jak znam te tematy  to dostanie jąkania...
Dev
Nie ma co chłopa stresować.
Wrzuciłem, żeby na przyszłość ludzie wiedzieli ile tam trzeba usprawnić pod taki setup.
Pozdrowienia ?
siana potrzeba jak na drugie B7 w igła stanie z opłatami na 500 km to seryjne tłoki ze sworzniami się zesrają sworznie albo pokrzywi albo pękną , pułki pewnie też się poobrywają itp , więc zostaje kucizna lub tłoki z nowych 2.0 TFSI z których na seryjnym dole można 500 km uzyskać w sensie że wytrzyma
Spokojnie, co do ceny to jestem przygotowany, już z 20tysi poszło, ołtarzyk z gratami w garażu zrobiony a jakoś auto nie jedzie szybciej ??
Spokojnie, co do ceny to jestem przygotowany, już z 20tysi poszło, ołtarzyk z gratami w garażu zrobiony a jakoś auto nie jedzie szybciej ?? a seryjnie w bgb nie jest średnica 82.5? Tłoki pakować 83.5?
Raczej będzie problem jak średnica cylka to 82.5 a tłok o mm wiekssy?
2.0 tsi ma średnice tłoka w nominale 82.5
we podpisie masz 1.8T ? co przerabiasz 1.8 T na 2.0 ?
tłok o 1mm większy , nie powinno być problemu blok tłoki oddać do obróbki i powinno być git
ja bym celował CR pomiędzy 8:0 a 8:7 czym niższe tym sprawność silnika mniejsza gdy turbo nie dmucha ale przyjmie większe doładowanie i wyższą moc wynikającą z doładowania turbiny
Edytowane przez hopek03
Miałem 1.8t teraz zmieniłem na 2.0t, muszę zmienić podpis
Hopek, i chyba później wstaje im niższe Cr mam rację?
tak dokładnie
