Kodowanie pompy ABS i ESP
Cześć. Próbuję drugi dzień zakodować po wymianie kierownicy na multifunkcje pompę ABS. Na FIS wyświetla duży komunikat brakes. Próbuję robić to co znalazłem na forum i to co pisał ross-tech. Pacjent Audi a4 b7 1.9tdi skrzynia manual. Vcds mówi że to pompa bosh 8.0. Bez problemu jak podaje wartość w security wchodzę ale jak próbuje coś kodować mam error w grupach 069 i 010. Jak na zrzucie. Czujnik ESP wykrywa ruchy kierownicy poprawnie. Możecie mi jakoś pomóc? Nie wiem już co mam robić :( info z ross tech.
Dodam. Że zmieniłem moduł na Q z AUDI A4 B7 2.0 TDI i taśmę zwijak kierownicy z AUDI A8 D3 4E0953541A
Audi A4 (8E) Brake Electronics (Bosch 8.0)
Jump to:navigation, search
Contents
1Coding
2Basic Setting
2.1Sensor for Steering Angle (G85)
2.2ESP-Sensor Unit (G419)
3Replacement
Coding
If the old Control Module is still accessible read/copy it's Coding to the new Module. In case this is not possible please contact us directly and we will assist you with the Coding Process.
Every inquiry on this topic has to include a full Auto-Scan as well as which parts have been replaced and why, also make sure the Auto-Scan includes the complete VIN of the vehicle in question.
Basic Setting
[Select]
[03 - ABS Brakes]
[Fault Codes - 02]
[Done, Go Back]
Start Engine (session still running).
Turn steering wheel at least 30 ° left and back straight ahead.
[Meas. Blocks - 08]
Group 005 Field 1 (Steering Angle Sensor -G85-)
Specification: 0.0 °
Tolerance (when straight): ±5.0 °
[Done, Go Back]
[Security Access - 16]
Enter 40168
[Do It!]
[Basic Settings - 04]
Group 001
[Go!]
[Done, Go Back]
[Fault Codes - 02]
All fault codes should have disappeared.
[Done, Go Back]
[Close Controller, Go Back - 06]
[Select]
[03 - ABS Brakes]
Enter 40168
[Do It!]
Group 069
[Go!]
Field 2 should show OK after a successful Calibration.
[Done, Go Back]
[Meas. Blocks - 08]
Group 010 Field 1/2 (Longitudinal Acceleration Sensor (G251))
Specification: ±1.25 m/s²
[Done, Go Back]
[Fault Codes - 02]
[Done, Go Back]
*Trzeba czytać do czego dany dział jest: "Manuale - DIY - zrób to sam - W tym dziale znajdziesz poradniki, dzięki którym sam dokonasz napraw lub modyfikacji w swoim aucie." - wątek przeniesiony
po walkach z kodowaniem pompy abs mam teraz dwa błędy
00778 - Steerig Angle Senson (G85)
00493 ESP-SENSOR UNIT (G419)
i świeci mi się ABS i ESP
wchodziłem w kodowanie ABS podając wartość 0004401. jak próbuje wejść w kalibrację w grupę 069 to błąd jak wyzej. Nie mogę także zrobić adaptacji.
nieaktualne, po przejechaniu kikunastu metrów problem zniknął.
