[B5 AFN] Proszę o analizę błędów
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 018 FD
Component: 1,9l R4 EDC G000SG 2137
Coding: 00002
Shop #: WSC 06325
1 Fault Found:
17958 - Charge Pressure: Control Deviation
P1550 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 N
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 881 H
Component: B5-KOMBIINSTR. VDO D15
Coding: 07140
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0X0872777
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 B
Component: ZV-Pumpe, Funk D12
Coding: 12897
Shop #: WSC 06325
2 Faults Found:
01361 - Switch for Anti-Theft Alarm: Close
29-00 - Short to Ground
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 56 -------------------------------------------------------
Controller: 4B0 035 186
Component: Radio 0001
Coding: 00017
Shop #: WSC 06325
1 Fault Found:
00854 - Radio Display Output in dash Panel insert
49-10 - No Communications - Intermittent
End -------------------------------------------------------
Bardzo prosze o komentarz:) Zwłaszcza do: 01361 - Switch for Anti-Theft Alarm: Close 29-00 - Short to Ground.
Błąd przeładowania wynika z większago turbo i braku zmiany softu (będzie na koniec miesiąca)
przełącznik w drzwiach pada albo problem z "okablowaniem"
