[B5 AFN] Proszę o analizę błędów
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 028 906 021 GN
Component: 1,9l R4 EDC 00SG 1422
Coding: 00002
Shop #: WSC 06325
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 111
Component: ABS 5.3 FRONT D11
Coding: 0273004132
Shop #: BB 24303
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 034 E
Component: B5-KOMBIINSTRUMENT__D12
Coding: 00040
Shop #: WSC 75256
Address 25 -------------------------------------------------------
Controller: 4A0 953 234 F
Component: IMMO AUZ9Z0V3137674 D77
Coding: 00000
Shop #: WSC 00000
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 E
Component: ZV-Pumpe
Coding: 00000
Shop #: WSC 65535
16 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01389 - Tailgate Open Switch (F124)
29-00 - Short to Ground
22307 - Unknown Error Code
Unknown - 70-10 - Cylinder 3 - Intermittent
23331 - Unknown Error Code
Unknown - 02-00 - Signal Shorted to Ground
23587 - Unknown Error Code
Unknown - 103-10 - Unknown Error Elaboration - Intermittent
24099 - Unknown Error Code
Unknown - 39-00 - Output won't Switch or Short to Ground
23075 - Unknown Error Code
Unknown - 01-00 - Signal Shorted to B+
22819 - Unknown Error Code
Unknown - 01-10 - Signal Shorted to B+ - Intermittent
22563 - Unknown Error Code
Unknown - 38-10 - Output won't Switch or Short to B+ - Intermittent
End -------------------------------------------------------
opisz usterkę :przebiegly: bo może tylko wystarczy błędy skasować i po bólu :gwizdanie:
skasuj i zobacz czy wroca ...
