spiidy Opublikowano 4 Października 2009 Opublikowano 4 Października 2009 1 Fault Found: 17965 - Charge Pressure Control: Positive Deviation P1557 - 35-00 - - VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 CG Component: 1,9l R4 EDC 0700SG 1366 Coding: 00002 Shop #: WSC 19999 No fault code found. Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front D620 Coding: 04255 Shop #: WSC 00062 No fault code found. Address 08 ------------------------------------------------------- Controller: 8E0 820 043 C Component: A4 Klimaautomat 0711 Coding: 00000 Shop #: WSC 05311 No fault code found. Address 09 ------------------------------------------------------- Controller: 8E0 907 279 B Component: int. Lastmodul RDW 1512 Coding: 00001 Shop #: WSC 00000 3 Faults Found: 01331 - Door Control Module: Driver Side (J386) 49-00 - No Communications 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - 00526 - Brake Light Switch-F 28-10 - Short to B+ - Intermittent Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenksáulenmodul 0302 Coding: 00011 Shop #: WSC 63351 3 Faults Found: 01794 - Control Module Incorrect Chassis (VIN) Number 35-00 - - 01331 - Door Control Module: Driver Side (J386) 49-10 - No Communications - Intermittent 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent Address 17 ------------------------------------------------------- Controller: 8E0 920 930 GX Component: KOMBI+WEGFAHRS. RB4 D14 Coding: 00000 Shop #: WSC 00000 29387 AUZ6Z0A0009016 3 Faults Found: 01331 - Door Control Module: Driver Side (J386) 49-10 - No Communications - Intermittent 01304 - Radio 49-00 - No Communications 01300 - Control Module for Navigation with CD-Rom (J401) 49-00 - No Communications Address 46 ------------------------------------------------------- Controller: 8E0 959 433 L Component: Komfortgerát T03 0112 Coding: 06720 Shop #: WSC 63351 8 Faults Found: 01331 - Door Control Module: Driver Side (J386) 49-10 - No Communications - Intermittent 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 01320 - Control Module for Climatronic (J255) 49-10 - No Communications - Intermittent 01331 - Door Control Module: Driver Side (J386) 80-00 - Single-Wire Operation 00912 - Window Regulator Switch: Front Left (E40) 27-10 - Implausible Signal - Intermittent 00932 - Electric Window Motor: Drivers Side (V147) 62-10 - No or Incorrect Adjustment - Intermittent 01803 - Door Warning Lamp: Rear Left (W37) 57-10 - Electric Circuit Failure - Intermittent 01333 - Door Control Module: Rear Left (J388) 49-10 - No Communications - Intermittent Address 55 ------------------------------------------------------- Controller: 4B0 907 357 C Component: dynamische LWR D05 Coding: 00060 Shop #: WSC 63351 No fault code found. Address 76 ------------------------------------------------------- Controller: 8Z0 919 283 A Component: Parkingsyst. A4 RDW D05 Coding: 00104 Shop #: WSC 63351 No fault code found. End
proton2 Opublikowano 9 Października 2009 Opublikowano 9 Października 2009 Wygląda na to, że ktoś wymieniał moduł centralnej elektryki i moduł pod kierownicą. Nie mają przyuczonych VIN-ów. Próbowałeś kasować te błędy ? Wszystkie wracają ? Jak przyuczyć moduł centralnej elektryki było niedawno tu - http://www.a4-klub.pl/smf/all_b6_jak_nauczyc_moje_auto_vinu-t97231.0.html Moduł kierownicy uczy się podobnie - wchodzi w adaptację, kanał 081 wpisuje wartość 00111 daje test i save.
