Lista modułów komfortu 46 w Audi A4 B6 i B7 z opisem funkcji
No niestety - ten typ tak ma. W sumie to pika a nie wyje ;)
  • Odpowiedzi 2,3 tys.
  • Wyświetleń 783,7 tys.
Hello
At first, sorry, that I am speaking english, but I am from Czech Republic and I dont speak polish.
Can I ask you, which B6 Control Module allows el. folding mirrors?
Hi mate.
Try BC or BD - it will work with folding for sure...
As I can remember, BA will also fit :good:
Hi mate.
Great, many thanks ...
And do you know how to coding it in VAG?
U don't have to code Convenience module - the function will just work.
Folding function depends also on front door modules - only versions I've listed below will work with folding:
8E1 959 801 / 802
8E1 959 801E / 802E
8E1 959 801F / 802F
8E1 959 801G / 802G
These drivers comparing to other models have all pins settled at 4 connector slots. After changing it - U just run fold function with turning joystick 180 degrees back (of course U also have to buy proper joy - with 4th, folding position). There is no need to work with wires - only swap drive module and joy and it will work.
Hello
Yes, yes I know.
I mean:
If I press lock button on remote for 3 seconds, the mirrors closes automatically (like window, which closes). It is possible?
Nope, not at this chassis. Further models like B8 perhaps, but as far as I know - B6 and B7 don't have this function... (and it's kind of pity, my frend have Renault Laguna '03 and his mirrors are folding when he closes the door with remote - it's a shame Audi didn't develop this kind of stuff too).
Using remote control U can close (or open) doors, windows and sunroof pressing the lock (open) button for 3 seconds. Convenience driver enables this functions.
Dzięki jeszcze jedno pytanie
jesli są dodane litery na koncu CC ,CB itd to tez pasuje?
CC i CB to modele z B7 - nie wiem czy będą pasowały do B6.
Witam,poszukuję modułu komfortu z końcówką CG i nie moge nigdzie go dostać.Czy moge go zastąpić BL BT CP?
Tych modułów jeszcze nikt nie opisywał więc niestety nie umiem Ci pomóc :confused4:
U mnie moduł AR
- korby tył
- brak podświetlenia nóg
- 433 Mhz
- brak fabr. alarmu
Sprawdzał może ktoś kodowanie na tym module ? Jeśli nie to jutro sprawdzę.[br]Dopisany: 06 Wrzesień 2010, 04:41_________________________________________________Modułu AR nie da się zaprogramować na 2 i 3 wyskakuje error.
Dzięki Mirek - o takie info chodzi :good:
No problem. jaki moduł będzie zastępował AR żeby działało podświetlenie nóg. Nie bardzo rozumiem ten schemat.
BA zastępuje AR i już innego nie założę ?
Na schemat nie patrz bo on póki co nic nie mówi poza tym co wychodziło jako kolejne - pakiet oświetlenie w Twoim przypadku obsłuży moduł AT (a także BA, BC i BB).
:hi: czy bez vaga znajdę na module symbole? i gdzie on jest?
mam alarm i pełną elektrykę ale bez pakietu oświetlenia.trochę mi go brakuję.jak go miałem to nie doceniałem.
a czy instalacja będzie czy trzeba ją stworzyć?
znalazłem niebieska wtyczkę z dwoma kabelkami nad kolanem za radiem ale jest martwa.Natomiast u pasażera chyba powinna być inna wiązka do oświetlenia.Dochodzą cztery a wychodzą dwa.Małe lutowanie i po problemie tylko że też reszta jest martwa bez napięcia.Pozdro
Moduł! jest pod podłogą pasażera, musisz zdjąć tapicerkę, jest oznaczenie na module
jeszcze nie rozbierałem drzwi .Ciekaw jestem czy jest tam coś przygotowane pod oświetlenie.Ciemno w mojej uliczce jak w d*p... .Powalczył bym tylko nich ktoś podpowie czy jest taka możliwość.
Oświetlenie podłogi podłącze pod lampę sufitową.Ostatnio u kolegi podłączyliśmy vaga i uaktywniłem oświetlenie wokół samochodu na 20sek.Zero reakcji.W sumie to prosty układ elektroniczny a tak trudno to załatwić w audi.Jutro sprawdzę symbol na module alarmu tylko czy to ten sam co comfort?Dzięki za odpowiedź
O boże co ja napisałem, nie alarm tylko moduł komfortu, sorry.
jutro pruję podłogę i boczki.Temat comfortu już tak mnie wkurza że muszę coś z tym zrobić.
Miałem podświetlane wszystko w A6 i w ogóle tego nie doceniałem a tu brakuje mi głupich dwóch diod świecących na gałke lewarka za to mam w podłokietniku.Powinni tak zrobić żeby było można wszystko dołożyć.[br]Dopisany: 11 Wrzesień 2010, 22:38_________________________________________________Nie wiem czy to ten moduł u pasażera pod nogami a mój ma symbol 8P0862335H oraz typ 8E6359.
Moduł jest z bluetooth i firmy harman/beckers. rok produkcji listopad 06 w dowodzie mam 06 a w winie 07.Samochód kupiony w salonie do leasingu.
Może to nie po tej stronie i trzeba pruć stronę kierowcy?
