[B5 ADR] Blędy vag-com jakie to blędy
witam
Sprawdzilem vagiem przez automat czy sa jakies bledy i wyskoczylo mi to .. nieznam angielskiego ani niemieckiego wiec prosil bym o tlumaczenie i ewentualna informacje jak naprawic.. czesc znalazlem ale nei wiem dokladnie czy to to ..
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 558 B
Component: 1,8L R4/5V MOTR HS D03
Coding: 04001
Shop #: WSC 06325
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 D
Coding: 04140
Shop #: WSC 06325
Note: Excessive Comm Errors
Skipping Address 15-Airbags tutaj cos
Address 17 -------------------------------------------------------
Controller: 8D0 919 861 C
Component: B5-KOMBIINSTR. VDO D02
Coding: 00042
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0W0423686
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 L
Component: ZV-Pumpe D05
Coding: 00000
Shop #: WSC 06325
2 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
00991 - Interior Lights
28-00 - Short to B+
Address 56 -------------------------------------------------------
Controller: 4B0 035 186
Component: Radio 0001
Coding: 00401
Shop #: WSC 00000
2 Faults Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
01044 - Control Module Incorrectly Coded
35-00 - -
End -------------------------------------------------------
[br]Dopisany: 17 Sierpień 2010, 12:05_________________________________________________lipa cisza
