reniek Opublikowano 13 Marca 2011 Opublikowano 13 Marca 2011 Sunday,13,March,2011,13:24:51:46862 VCDS Version: Beta 912.0 Address 01: Engine Labels: Redir Fail! Control Module Part Number: 8E0 910 401 P HW: 8E0 907 401 AL Component and/or Version: 3.0L V6TDI G000AG 0050 Software Coding: 0011171 Work Shop Code: WSC 00191 264 15243 1 Fault Found: 008194 - Particulate Trap Bank 1: Efficiency Below Threshold P2002 - 001 - Upper Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 0 Fault Frequency: 1 Mileage: 152737 km Time Indication: 0 Freeze Frame: RPM: 3906 /min (no units): 1193.8 Pressure: 0 mbar (no units): 0.0 Temperature: 324.5°C Absolute Pres.: 0.0 mbar Temperature: 14.4°C Readiness: 1 1 0 0 0 Sunday,13,March,2011,13:28:22:46862 VCDS Version: Beta 912.0 Address 01: Engine Labels: REDIR FAIL! Control Module Part Number: 8E0 910 401 P HW: 8E0 907 401 AL Component and/or Version: 3.0L V6TDI G000AG 0050 Software Coding: 0011171 Work Shop Code: WSC 00191 264 15243 2 Faults Found: 009300 - Diesel Particle Filter; Differential Pressure Sensor: Short to GND P2454 - 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 1 Mileage: 152782 km Time Indication: 0 Freeze Frame: RPM: 3696 /min Torque: 499.2 Nm Speed: 53.8 km/h Temperature: 185.6°C Temperature: 171.1°C (no units): 0.0 Absolute Pres.: 0.0 mbar 008194 - Particulate Trap Bank 1: Efficiency Below Threshold P2002 - 001 - Upper Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 0 Fault Frequency: 1 Mileage: 152782 km Time Indication: 0 Freeze Frame: RPM: 3612 /min (no units): 582.8 Pressure: 0 mbar (no units): 0.0 Temperature: 230.1°C Absolute Pres.: 0.0 mbar Temperature: 15.3°C Readiness: 0 0 1 1 1 [br]Dopisany: 13 Marzec 2011, 14:21_________________________________________________Nikt nie jest w stanie powiedzieć o co kaman?? Mruga mi zwojnica i auto nie ma mocy.
IDUAL Opublikowano 13 Marca 2011 Opublikowano 13 Marca 2011 008194 - Filtr cząstek stałych; zespół 1: za mała skuteczność najprawdopodobniej masz zapchany filtr cząstek stałych. Procedura czyszczenia filtra cząstek stałych (znalezione na innym forum) Procedura awaryjnego czyszczczenia DPF: Wymagania wstępne (ogólne): Włączamy zapłon Włączamy silnik Temperatora płynu chłodzącego powyżej 50 ° C (patrz MVB 002,4) Włączyć wszystkie możliwe odbiorniki energii (Światła, Ogrzewanie siedzeń, ogrzewanie szyb, klimatyzacja i inne) Warunki jakie należy spełnić: Prędkość pojazdu pomiędzy 30-60 kilometrów na godzinę Prędkości obrotowej silnika pomiędzy 1500-2500 RPM Czas trwania ok..15-20 Minut Temperatura spalin przed Turbo ładowarki powyżej 700 ° C Koniecznie należy zachować powyższe wymagania podczas procedury regeneracji filtra. Jest to warunek prawidłowego zregenerowania DPFa. Teraz czas na interfejs: [Wybierz] [01 - Engine] [Coding-II - 11] Włącz Regeneracja wprowadzając 21295. [Do It!] [Meas. Blocks - 08] Wybrać obie grupy, tzn. 070 i 075. [Go!] MVB 070,1: Regeneracja Status (xxxxxxx1 = Normalna Regeneracja , xxxxxx1x = Przymusowa Regeneracja) MVB 070.3: Regeneration Counter/Timer MVB 075.1: Temperatura spalin przed turbosprężarką MVB 075.2: Temperatura spalin przed filtrem cząstek stałych (DPF) MVB 075.3: Poziom zapełnienia filtra cząstek stałych... MVB 075.4: Temperatura spalin za filtrem cząstek stałych (DPF) Mając ustawione powyższe parametry rozpoczynamy jazdę obserwując na bieżąco bloki pomiarowe, robimy do koniecznie w towarzystwie drugiej osoby. [Done, Go Back] [Close Controller, Go Back - 06]
reniek Opublikowano 14 Marca 2011 Autor Opublikowano 14 Marca 2011 No dzięki kolego. W pierwszej kolejności jade jutro do ASO z reklamacją ponieważ pojawiło się to zaraz po tym ja demotnowali mi DPFa żeby wymienić uszczelniacz między Tiptronikiem a wałem napędowym. Mam nadzieje, że nic przy okazji nie schrzanili.[br]Dopisany: 13 Marzec 2011, 21:39_________________________________________________Jakby komuś sie przytrafiło coś podobnego to u mnie okazało się, że jeden z dwóch przewodów od podciśnienia które idą do DPF sie rozszczelnił i w konsekwencji sie stopił.
