kesick 0 Opublikowano 9 Kwietnia 2011 Udostępnij Opublikowano 9 Kwietnia 2011 witam, zrobiłem dzisiaj w programie VAG-COM auto scan. Efekt widoczny poniżej. VAG-COM Windows Based VAG/VAS Emulator Version: Release 311.2-N www.Ross-Tech.com Dealer/Shop Name: Workshop Code: 000 00000 Self-Diagnosis Log Saturday, 09 April 2011, 20:29:05 VIN Number: License Plate: Mileage: Repair Order: Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: 028 906 021 CE Component: 1.9l R4 EDC 40SG 0803 Coding: 00002 Shop #: WSC 00777 4 Faults Found: 00527 - Intake Manifold Temperature Sensor (G72) 30-10 - Open or Short to B+ - Intermittent 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - Intermittent 00575 - Intake Manifold Pressure 17-10 - Control Difference - Intermittent 01237 - Fuel Shut-Off Valve (N109) 31-00 - Open or Short to Ground Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 111 Component: ABS 5.3 FRONT D11 Coding: 0273004132 Shop #: BB 24303 No fault code found. Address 08 ------------------------------------------------------- Controller: 8L0 820 043 B Coding: 04143 Shop #: WSC 06335 Note: Excessive Comm Errors Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8D0 919 034 Component: B5-KOMBIINSTRUMENT D10 Coding: 00140 Shop #: WSC 19411 No fault code found. Page 2 VIN Number: License Plate: Address 25 ------------------------------------------------------- Controller: 4A0 953 234 F Component: IMMO AUZ9Z0T7892313 D77 Coding: 00000 Shop #: WSC 00000 No fault code found. Address 35 ------------------------------------------------------- Controller: 8LO 862 257 E Component: ZV-Pumpe Coding: 00000 Shop #: WSC 65535 16 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01373 - Alarm triggered by Radio Ground Contact 35-00 - - 01366 - Opened Due to Crash Signal 35-00 - - 01361 - Switch for Anti-Theft Alarm: Close 29-00 - Short to Ground 01360 - Switch for Anti-Theft Alarm: Open 29-00 - Short to Ground 01362 - Close Switch for Tailgate/Trunk (F124) 29-00 - Short to Ground 01363 - Switch for Central Locking: Driver's Door (F59) 27-00 - Implausible Signal 01364 - Switch for Central Locking: Passenger Door (F114) 27-00 - Implausible Signal 01365 - Lock/Unlock Switch: Interior 29-00 - Short to Ground 01365 - Lock/Unlock Switch: Interior 28-00 - Short to B+ End ------------------------------------------------------- Czy znalezione błędy to coś poważnego? Jak można się ich pozbyć? Dodam, że nie mam problemów z autem jeżeli chodzi o jazdę. Jedyny problem to alarm. Po zazbrojeniu alarmu z pilota zdarza się, że uruchamia się on samoczynnie. Dodatkowe pytanie jest takie: gdzie znajdę info w VAG-COM 311.2-N o stanie licznika i spalaniu paliwa? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
ciahciah 3 Opublikowano 10 Kwietnia 2011 Udostępnij Opublikowano 10 Kwietnia 2011 jak zrobiłeś ten auto scan to tam miałeś opcje wyczyść, kliknij i za jakiś czas sprawdź które błędy wrócą i wtedy się tymi błędami zajmiemy stan licznika masz na desce rozdzielczej, w vag wchodzisz w 17 instruments i tam znajdziesz to samo co na desce, a spalanie to sobie sprawdź tankując do pełna bo na vag to jest zabawka Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
kesick 0 Opublikowano 12 Kwietnia 2011 Autor Udostępnij Opublikowano 12 Kwietnia 2011 Dzięki za wskazówki. Czyli w audi z moim rocznikiem (97') info o przejechanych kilometrach jest zapisane tylko i wyłącznie jako stan licznika? Słyszałem, że inne czujniki np. ABS też trzymają taką informację, ale może tak jest tylko w nowszych modelach... Może i spalanie pokazywane na VAG to zabawka, ale ja dalej, uparcie chciałbym się dowiedzieć gdzie je można znaleźć?? [br]Dopisany: 10 Kwiecień 2011, 13:30_________________________________________________wyczyściłem błędy i jak na razie po przejechaniu około 100 km nic się nie pokazało Czy ktoś ma opis, w których blokach danych znajduję się jakie wartości dla audi a4? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
lukjar7 0 Opublikowano 12 Kwietnia 2011 Udostępnij Opublikowano 12 Kwietnia 2011 poczytaj podwieszone watki Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
