rav30 Opublikowano 21 Maja 2011 Opublikowano 21 Maja 2011 Witam. Jest to mój pierwszy temat na tym forum (od czegoś trzeba zacząć) Jako, że to moja pierwsza komunikacja auta z programem vag com od razu wyświetliło kilka błędów. Chciałbym abyście je przeanalizowali. Z góry dziękuję VAG-COM Version: Release 311.2-N 1o9lo0m-n6r12p-o9ko4x-kkjahh-568f Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 8E0 907 557 Component: 2.0L R4/5VS 0006 Coding: 0011501 Shop #: WSC 63351 No fault code found. Readiness: 0110 0101 Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front D1320 Coding: 04275 Shop #: WSC 00491 No fault code found. Address 08 ------------------------------------------------------- Controller: 8E0 820 043 Component: A4 Klimaautomat 0508 Coding: 00000 Shop #: WSC 63351 No fault code found. Address 09 ------------------------------------------------------- Controller: 8E0 907 279 Component: int. Lastmodul RDW 0510 Coding: 00001 Shop #: WSC 63351 No fault code found. Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenksáulenmodul 0302 Coding: 00001 Shop #: WSC 63351 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 950 D Component: KOMBI+WEGFAHRS. RB4 D12 Coding: 00400 Shop #: WSC 00001 WAUZZZ8EZ1A058441 AUZ6Z0A0082933 1 Fault Found: 01304 - Radio 49-00 - No Communications Address 45 ------------------------------------------------------- Controller: 8E0 951 177 Component: Innenraumueberw. 0503 Coding: 00001 Shop #: WSC 00000 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AC Component: Komfortgerát T9F 0313 Coding: 06858 Shop #: WSC 00491 3 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01331 - Door Control Module: Driver Side (J386) 80-00 - Single-Wire Operation End ------------------------------------------------------- P.s Nie są to wszystkie błędy. Trzy wykasowałem na samym początku, ale przy następnej komunikacji zapewne znów się wyświetlą... Problem jest z "Camshaft sensor" oraz "Break light switch", "Coolant sensor G62" Pozdrawiam
itor Opublikowano 21 Maja 2011 Opublikowano 21 Maja 2011 P.s Nie są to wszystkie błędy. Trzy wykasowałem na samym początku, ale przy następnej komunikacji zapewne znów się wyświetlą... Problem jest z "Camshaft sensor" oraz "Break light switch", "Coolant sensor G62" Pozdrawiam wypisz bledy z engine okno 02
