[ALL B7] Proszę o analizę logów
Statyczne:
http://vaglog.rtnet.pl/kfcyron_48334.html
http://vaglog.rtnet.pl/kfcyron_48335.html
http://vaglog.rtnet.pl/kfcyron_48355.html
Dynamiczne:
http://vaglog.rtnet.pl/kfcyron_48356.html
http://vaglog.rtnet.pl/kfcyron_48357.html
http://vaglog.rtnet.pl/kfcyron_48358.html
No i błędy:
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 FC HW: 028 101 217 2
Component: R4 2,0L EDC G000SG 9621
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 00481 211 85020
VCID: 69D2A1207F23F454
2 Faults Found:
17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
P1586 -- 000 -- -
Freeze Frame:
RPM: 882 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00001100
Torque: 161.0 Nm
Torque: 0.0 Nm
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
P0674 -- 000 -- -
Freeze Frame:
RPM: 840 /min
Torque: 56.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00001100
Temperature: 16.2°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 50733 142 86308
VCID: 2648EA1CAEBD1B2C
No fault code found.
Saturday,11,June,2011,16:30:14:36838
VCDS Version: Release 10.6.2
Data version: 20101123
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Control Module Part Number: 8E0 920 931 D HW: 8E0 920 931 D
Component and/or Version: KOMBI+WFS 4 H12 0040
Software Coding: 0006101
Work Shop Code: WSC 08277 001 00001
VCID: 2952E120BFA33454
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
010 -- Open or Short to Plus - Intermittent
00471 - Control Module for Elect. Regulated Dampers (J250)
012 -- Electrical Fault in Circuit
Błąd cylindra został usunięty, klocki hamulcowe zmienione więc błędu nie ma.
Interesuje mnie - czy turbo przeładowuje? dodam, że auto ma typowe dla tego silnika- telepanie. Wałek jest sprawdzony - OK. Zastanawiam się nad zbierakiem pompy. Dwumas też jest ok. Z logów widze , że pompki jeszcze daja rade- no 1 trochę gorzej.
Jakieś pomysły? Gdzie znajdę czujnik temp zbłędów?
Pozdro
kiedy filtr paliwa byl wymieniany ?
