criss22041991 Opublikowano 29 Czerwca 2011 Opublikowano 29 Czerwca 2011 Witam! Podpiołem sobie dzisiaj Vaga i zrobiłem scana Vag-Comem. Oto co się pokazało: VAG-COM Version: Release 409.1-SChassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 ------------------------------------------------------------------------------- Address 01: Engine Controller: 8D0 907 557 T Component: 1.8L R4/5VT MOTR HS D06 Coding: 04201 Shop #: WSC 06435 5 Faults Found: 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent 17967 - Throttle Valve Control part (J338): Fault in basic settings P1559 - 35-00 - - 17967 - Throttle Valve Control part (J338): Fault in basic settings P1559 - 35-00 - - 00515 - Camshaft Position (Hall) Sensor (G40) 30-00 - Open or Short to B+ 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - Intermittent Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Controller: 8E0 614 111 A Component: ABS/EDS 5.3 QUATTRO D00 Coding: 0273004284 Shop #: BB 24334 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Controller: 8L0 820 043 D Component: A4 KLIMAVOLLAUTOMAT_D75 Coding: 04140 Shop #: WSC 06435 No fault code found. ------------------------------------------------------------------------------- Skipping Address 15-Airbags ------------------------------------------------------------------------------- Address 17: Instruments Controller: 8D0 919 861 CX Component: B5-KOMBIINSTR. VDO D09 Coding: 00042 Shop #: WSC 73148 IMMO-IDENTNR: AUZ7Z0W0476901 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Controller: Bit teA dre ss Component: e 17 eingeben No Faults Found or DTCs not supported by controller or a communication error ocurred ------------------------------------------------------------------------------- Address 35: Centr. Locks Controller: 8LO 862 257 D Component: ZV-Pumpe, Funk D03 Coding: 12864 Shop #: WSC 65535 2 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01363 - Switch for Central Locking: Driver's Door (F59) 27-00 - Implausible Signal End -------------------------------------------------------------------------------------------------- Domyślam się że przepustnica do czyszczenia i adaptacji. Bo samochód potrafi zgasnąć przy hamowaniu i trochę falują obroty. Czy mam się czymś martwić z tych błędów oprócz przepustnicy?? i od czego ten błąd Halla?
IDUAL Opublikowano 29 Czerwca 2011 Opublikowano 29 Czerwca 2011 bład 00515 jest to błąd czujnika halla który jest odpowiedzialny za wykrywanie położenia wału czyli czójnik obrotów wałka rozrzadu zwarcie do plusa sprawdz kostkę od czójnika czy nie zaśniedziała lub nie zamokła.
criss22041991 Opublikowano 29 Czerwca 2011 Autor Opublikowano 29 Czerwca 2011 A da się jakoś sprawdzić ten czujnik? Np. jakaś rezystancja czy coś?
lukjar7 Opublikowano 29 Czerwca 2011 Opublikowano 29 Czerwca 2011 oscyloskop, ale bez niego auto nie gada
criss22041991 Opublikowano 29 Czerwca 2011 Autor Opublikowano 29 Czerwca 2011 Spróbuje wyczyścić styki, a jak nie to tylko mechanik zostaje. A co do tego błędu przepustnicy, wyczyszczenie i adaptacja pomoże? Czy juz szukać drugiej?? I jeszcze takie pytanie przy okazji czy te błędy mogą mieć związek z tym że obroty spadają np. do 500 i potem skaczą na 900-1000 przy wciskaniu sprzęgła, albo poprostu po zdjęciu nogi z gazu na luzie? najczęściej mam tak przy hamowaniu, potrafi mi nawet zgasnąć samochód. Zjawisko nasila się przy włączonej klimatyzacji i występuje znacznie częściej.
lukjar7 Opublikowano 29 Czerwca 2011 Opublikowano 29 Czerwca 2011 czyszczenie kasowanie bledow i adaptacja co wroci to bedziesz sie martwil
