[B6 AWX] Co wynika z tych błędów?
Panowie, podlaczylem dzis Vaga zeby sprawdzic co tam sie dzieje w mojej B6, chcialem sprawdzic co sie dzieje ze wskazaniami poziomu paliwa, co opisalem w tym watku http://www.a4-klub.pl/smf/index.php?topic=225838.0. Oto co uzyskalem:
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8EZ1A030836 Mileage: 158840km/98698miles
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front D620
Coding: 04255
Shop #: WSC 06435
2 Faults Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-00 - -
P1850 - 35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043
Component: A4 Klimaautomat 0406
Coding: 00000
Shop #: WSC 63351
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279
Component: int. Lastmodul RDW 0510
Coding: 00001
Shop #: WSC 63351
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 3001
Coding: 0010602
Shop #: WSC 63351 000 00000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0302
Coding: 00011
Shop #: WSC 63351
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 E
Component: KOMBI+WEGFAHRS. RB4 D10
Coding: 00130
Shop #: WSC 30439
WAUZZZ8EZ1A030836 AUZ6Z0A0000910
1 Fault Found:
01314 - Engine Control Module
49-00 - No Communications
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0403
Coding: 00001
Shop #: WSC 00864
Address 46: Central Conv. Labels: None
Part No: 8E0 959 433 AB
Component: Komfortgerát T1B 0313
Coding: 06730
Shop #: WSC 00864
Part No: 8E1959801
Component: Tőrsteuer.FS BRM 4.22
Part No: 8E1959802
Component: Tőrsteuer.BF BRM 4.22
Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 4.10
Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 4.10
11 Faults Found:
01331 - Door Control Module; Driver Side (J386)
49-10 - No Communications - Intermittent
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J398)
01317 - Control Module in Instrument Cluster (J285)
01320 - Control Module for Climatronic (J255)
01336 - Data Bus for Comfort System
37-10 - Faulty - Intermittent
01134 - Alarm Horn (H12)
00466 - Control Module for Steering Column Electronics (J527)
00457 - Control Module for Network (J519)
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
End ---------------------------------------------------------------------
Jak to wszystko mozna zinterpretowac :?:
Coding: 04255
Shop #: WSC 06435
2 Faults Found:
P1850 - 35-00 - -
tu jest błąd oznaczający "Przesył magistrali danych - brak informacji z silnika",
Coding: 00130
Shop #: WSC 30439
1 Fault Found:
tutaj natomiast jest "Szyna danych CAN > sterownik silnika (ECM)",
tu masz kolejno: 1331, 1332, 1333, 1334 - "Sterownik drzwi kierowcy (J386)", "Sterownik drzwi pasażera (J387)", "Sterownik drzwi tylnych lewych (J388)", "Sterownik drzwi tylnych prawych (J389)",
1317 - "Szyna danych CAN data bus - Sterownik deski wskaźników (J285)" (tutaj pewnie leży problem ze wskazaniami na liczniku),
1320 - "Jednostka kontrolująca dla elektroniki klimatyzacji J255",
1336 - "Magistrala danych systemu Comfort grupy VW",
1134 - "Syrena alarmowa (H12)",
00466 - "Sygnał o obrotach silnika (Engine speed signal to dash panel - defective)",
00457 - "Silnik 1 zamka bagażnika",
00912 - "Włącznik elektryczny szyby przód lewy E40".
Ja coś nie coś rzuciłem światła na znaczenie błędów, natomiast liczę , że koledzy którzy wiedzą więcej dadzą Ci znać co i jak trzeba naprawić odnośnie każdego z błędów. Pozdro
narobiłes sie kolego :notworthy: wedlug mnie albo cos musialo byc grzebane i albo nie jest podlaczone albo byl przekrecany kluczyk przy wypietych wtyczkach, skasuj błedy i wklej ktore wracaja
