sedi Opublikowano 21 Marca 2012 Opublikowano 21 Marca 2012 Witam, Podłączyłem sąsiada Passata B6 z 2006r do kompa i wyszły nastepujące błedy: ddress 01: Engine Labels: Redir Fail! Part No SW: 03G 906 021 NG HW: 03G 906 021 AB Component: R4 1,9L EDC G000SG 9308 Revision: --H02--- Serial number: VWZCZ000000000 Coding: 0000071 Shop #: WSC 05311 000 00000 VCID: 71E2D79A57F30C94 8 Faults Found 001137 - Exhaust Pressure Sensor 1 (G450): Implausible Signal P0471 - 000 - - Freeze Frame: Fault Status: 01110000 Fault Priority: 2 Fault Frequency: 54 Time Indication: 0 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h (no units): 321.30 (no units): 25.50 Mass Flow: 5.69 g/s Temperature: 294.0°C Temperature: 23.4°C 009299 - Diesel Particle Filter; Differential Pressure Sensor: Implausible Signal P2453 - 000 - - Freeze Frame: Fault Status: 01110000 Fault Priority: 2 Fault Frequency: 111 Time Indication: 0 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h (no units): -10.20 (no units): 25.50 Mass Flow: 5.69 g/s Temperature: 228.0°C Temperature: 21.6°C 001139 - Exhaust Pressure Sensor 1 (G450): Signal too High P0473 - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 2 Fault Frequency: 60 Time Indication: 0 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 12.31 V Mileage: 130 km Temperature: 54.0°C Absolute Pres.: 1764.6 mbar 001027 - EGR Valve (N18): Malfunction P0403 - 000 - - - MIL ON Freeze Frame: Fault Status: 11110000 Fault Priority: 1 Fault Frequency: 132 Mileage: 175693 km Time Indication: 0 Date: 2012.01.16 Time: 11:37:26 Freeze Frame: RPM: 819 /min Speed: 0.0 km/h Duty Cycle: 4.0 % Voltage: 14.21 V Mass Air / Rev.: 400.0 mg/str Duty Cycle: 21.1 % Bin. Bits: 00000000 005697 - Please check DTC Memory of A/C Controller P1641 - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 2 Mileage: 177170 km Time Indication: 0 Date: 2012.01.31 Time: 16:17:33 Freeze Frame: RPM: 819 /min Speed: 0.0 km/h Load: 5.5 % Voltage: 13.98 V Bin. Bits: 00001100 Temperature: 49.5°C (no units): 0.0 001031 - EGR Potentiometer (G212): Signal too Low P0407 - 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 1 Fault Frequency: 214 Mileage: 177666 km Time Indication: 0 Date: 2012.02.06 Time: 13:18:28 Freeze Frame: RPM: 2100 /min Speed: 75.0 km/h Load: 20.0 % Lambda: -25.0 % Mass Air / Rev.: 310.0 mg/str Mass Air / Rev.: 275.0 mg/str Bin. Bits: 00000000 005658 - Glowplug for Cylinder 1 (Q10): Open Circuit P161A - 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 1 Mileage: 177954 km Time Indication: 0 Date: 2012.02.19 Time: 15:56:11 Freeze Frame: RPM: 1008 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 11.55 V Bin. Bits: 00001100 Temperature: 18.9°C Bin. Bits: 10110000 005659 - Glowplug for Cylinder 2 (Q11): Open Circuit P161B - 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 1 Mileage: 177954 km Time Indication: 0 Date: 2012.02.19 Time: 15:56:11 Freeze Frame: RPM: 1008 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 11.55 V Bin. Bits: 00001100 Temperature: 18.9°C Bin. Bits: 10110000 Readiness: 1 5 0 0 0 Address 08: Auto HVAC Labels: 3C0-907-044.lbl Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH Component: ClimatronicPQ46 050 0505 Revision: 00050005 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 67D6B9C26937C224 1 Fault Found 00819 - High Pressure Sensor (G65) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00111001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 208 Mileage: 177170 km Time Indication: 0 Date: 2012.01.31 Time: 16:17:28 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 3C0-035-729.lbl Part No SW: 3C0 035 729 F HW: 3C0 035 729 F Component: Telefon 6809 Revision: 00012000 Serial number: 0000000801875 Coding: 0016043 Shop #: WSC 63576 123 84872 VCID: 2648F4C6AEBD1B2C 1 Fault Found 00992 - Consumption Cut-Off Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 223 Mileage: 177951 km Time Indication: 0 Date: 2012.02.10 Time: 17:52:54 ------------------------------------------------------------------------------- Address 7D: Aux. Heat Labels: 1K0-963-235.lbl Part No SW: 1K0 963 235 E HW: 1K0 963 235 E Component: PTC-Element 0404 Revision: 00800000 Serial number: Shop #: WSC 00000 000 00000 VCID: 2D5A0BEA8B4B2874 No fault code found. End --------------------------------------------------------------------- Następnie po skasowaniu i puszczeniu testu jeszcze raz wynik jak poniżej: Address 01: Engine Labels: Redir Fail! Part No SW: 03G 906 021 NG HW: 03G 906 021 AB Component: R4 1,9L EDC G000SG 9308 Revision: --H02--- Serial number: VWZCZ000000000 Coding: 0000071 Shop #: WSC 05311 000 00000 VCID: 71E2D79A57F30C94 2 Faults Found 001031 - EGR Potentiometer (G212): Signal too Low P0407 - 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 1 Fault Frequency: 1 Mileage: 178858 km Time Indication: 0 Date: 2012.03.02 Time: 19:19:00 Freeze Frame: RPM: 798 /min Speed: 0.0 km/h Load: 0.0 % Lambda: -25.0 % Mass Air / Rev.: 220.0 mg/str Mass Air / Rev.: 455.0 mg/str Bin. Bits: 00000000 001137 - Exhaust Pressure Sensor 1 (G450): Implausible Signal P0471 - 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Mileage: 178858 km Time Indication: 0 Date: 2012.03.02 Time: 19:22:57 Freeze Frame: RPM: 2541 /min Speed: 0.0 km/h (no units): -40.80 (no units): -25.50 Mass Flow: 54.04 g/s Temperature: 126.0°C Temperature: 5.4°C Readiness: 0 0 0 0 1 Proszę o analizę i informację. Dziękuję i pozdrawiam
przemik Opublikowano 21 Marca 2012 Opublikowano 21 Marca 2012 Skasuj te błedy i niech sąsiad pojezdzi troche passatem... i ponowcie odczyt...
sedi Opublikowano 21 Marca 2012 Autor Opublikowano 21 Marca 2012 Ok ale jeden bład pozostał a mianowice EGR tak jak opisałem. A co znaczyły te pozostałe?
przemik Opublikowano 21 Marca 2012 Opublikowano 21 Marca 2012 Wykonajcie logi statyczne 003 Basic Settings... sprawdzimy prace EGRa...
