kosiniak 0 Opublikowano 29 Kwietnia 2008 Udostępnij Opublikowano 29 Kwietnia 2008 Podpial mnie kolega dzis i o to co wyskoczylo, co robic? co wymieniac? czego szukac?? itd.?? Dodam ze auto jakis slabo jedzie, i przy 5krpm ewidentnie brak mu sily i jakby przerywa, na dzien dzisiejszy nie wymienialem nic bo czekam na wstepna diagnoze, po wekendzie wymieniam plyny i filtry, na co jeszcze zwrocic uwage?? VAG-COM Version: Release 311.2-N Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: 8D0 907 551 D Component: 2.7l V6/5VT G 0002 Coding: 05711 Shop #: WSC 00529 3 Faults Found: 17536 - Fuel Trim: Bank 1 (Mult): System too Lean P1128 - 35-00 - - 17538 - Fuel Trim: Bank 2 (Mult): System too Lean P1130 - 35-00 - - 16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit P0130 - 35-10 - - - Intermittent Readiness: 0000 0000 Address 03 ------------------------------------------------------- Controller: 8D0 907 389 E Component: ABS/ESP allrad D26 Coding: 04395 Shop #: WSC 06435 No fault code found. Address 08 ------------------------------------------------------- Controller: 8D0 820 043 N Component: A4 KLI Note: Excessive Comm Errors Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8D0 920 930 Q Component: B5-KOMBIINSTR. VDO D05 Coding: 00162 Shop #: WSC 00000 �˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙ AUZ7Z0X1125945 No fault code found. Address 25 ------------------------------------------------------- Controller: Bitte Adress Component: e 17 eingeben No Faults Found or DTCs not supported by controller or a communication error ocurred Address 35 ------------------------------------------------------- Controller: 8D0 862 257 Component: ZV-Pumpe, DWA, Funk D12 Coding: 13131 Shop #: WSC 06325 1 Fault Found: 00956 - Key 2 09-00 - Adaptation Limit Surpassed Address 45 ------------------------------------------------------- Controller: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00102 Shop #: WSC 06325 No fault code found. Address 55 ------------------------------------------------------- Controller: 4B0 907 357 Component: LEUCHTWEITEREGLER D003 Coding: 00012 Shop #: WSC 06325 No fault code found. End ------------------------------------------------------- Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Norbi 1 Opublikowano 30 Kwietnia 2008 Udostępnij Opublikowano 30 Kwietnia 2008 Sprawdź węze od i do IC, w/g mnie masz gdzieś nieszczelność. Przy przyspieszaniu nie słychać syku ulatującego ciśnienia powietrza? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
kosiniak 0 Opublikowano 1 Maja 2008 Autor Udostępnij Opublikowano 1 Maja 2008 Przy przyspieszaniu nie słychać syku ulatującego ciśnienia powietrza? no wlasnie nie slychac, czekam na wskanzik doladowania, zamontuje i zaczne szukanie Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Norbi 1 Opublikowano 1 Maja 2008 Udostępnij Opublikowano 1 Maja 2008 Przy przyspieszaniu nie słychać syku ulatującego ciśnienia powietrza? no wlasnie nie slychac, czekam na wskanzik doladowania, zamontuje i zaczne szukanie U mnie po zamontowaniu coolerów od RS4 też była nieszczelność i zegar boost pookazywał 1.3 bara przy max ataku, dokładnie tyle samo ile bez nieszczelności, tak więc zegar nie jest wyznacznikiem .Musisz sprawdzić szczelność układu w inny sposób, odpiąć i pozaślepiać rury od tzw. serca, podłączyć kompresor i nabić układ 4-5 barami i wylezie wszystko. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
