[B6 AVB] Błędy
Witam
Dziś robiłem diagnostyke i wyskoczyło mi pare błędów.
Dodam, że autko jest po chiptuningu, założona jest manetka do komputera, radio firmowe zamienione na zwykłe, w drzwiach od kierowcy czasem głośnik przerywa, może to jest związane z błędami. Prosze o analize.
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 FN
Component: 1,9l R4 EDC 0000SG 1413
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E02A044947 AUZ6Z0A0153255
2 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
18071 - Control Circuit for PD Injectors: Short to Plus
P1663 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1326
Coding: 04155
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 A
Component: A4 Klimaautomat 0711
Coding: 00000
Shop #: WSC 63351
No fault code found.
Address 09 -------------------------------------------------------
Controller: 8E0 907 279
Component: int. Lastmodul RDW 0510
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0304
Coding: 00011
Shop #: WSC 63351
2 Faults Found:
01331 - Door Control Module: Driver Side (J386)
49-10 - No Communications - Intermittent
01044 - Control Module Incorrectly Coded
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D21
Coding: 00000
Shop #: WSC 32468
2 Faults Found:
01304 - Radio
49-00 - No Communications
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AQ
Component: Komfortgerát T85 0214
Coding: 06720
Shop #: WSC 63351
2 Faults Found:
80-00 - Single-Wire Operation
End -------------------------------------------------------
P1557 - 35-00 - -
zapieczone kierownice w turbo - WD40 + BS grupy 11, potem masowanie pedalu gazu i moze sie rozruszaja
to po wymianie manetki - jest na forum procedurka jak zrobic kalibracje czujnika skretu
Witam
Widzisz kolego mstan, nie o taką pomoc prosze. Ja prosze o "analize". Odczytać kody błędów terz potrafie wystarczy zrobić kopiuj i wklej a potem szukaj, a pozatym obok błedu jest jego tłumaczenie.
Jak to było w temaci:
http://www.a4-klub.pl/smf/empty-t18478.0.html;highlight=dynamiczna
Diagnostyka silnika właściwa.
Diagnostykę wykonujemy trójetapowo:
1. poprzez odczyt błędów;
2. poprzez odczyt bloków wartości mierzonych:
a. w tzw. próbie statycznej;
b. w tzw. próbie dynamicznej.
Po uruchomieniu programu VAG-Com wykonujemy następujące operacje:
1. dla odczytu błędów w sterowniku silnika [ECU]:
Select [z okienka Select Control Module] > 01-Engine > 02-Fault Codes
po czym zapisujemy wyświetlone błędy [o ile w ogóle są] do pliku .txt i oczywiście zamieszczamy na forum.
Potrzebuje takiej odpowiedzi jakiej mi udzielil kolega DareQ .Chwała mu za to.
Faktycznie mam zapieczone kierownice , po chipie jest to bardziej odczuwalne. Ja daje gaz do podłogi on chwile sie muli a potem rakieta.
Wymieniałem zawór turbiny, zawór recylkulacji spalin i przepływke. Po każdej wymianie coś sie polepszyło. Teraz czas na turbo.Wiecie gdzie można ten zabieb czyszczenia zrobić w okolicach Łodzi, Kalisza albo Ostrowa Wielkopolskiego
Boje sie troszke błedu :
P1663 - 35-00 - -
Mam nadzieje ze nie ma on zbytniego Wpływu na pompowtryskiwacze.
