chopaki pomocy!!! rozladowal sie akumulator i niemoge po naladowaniu odpalic auta...!
djzak
naladowalem akumulator ..i auto cyka tylko niema rozruchy i caly czas sie pali cos zoltego na blacie-->>
http://img593.imageshack.us/img593/9112/zakzdjecia847.jpg
co to jest? jak to naprawic..masa bledow sie pojawila..
Trójkąt w obwódce to kontrolka od ESP. Zniknie po przejechaniu kilkudziesięciu metrów jeśli dobrze pamiętam. Sprawdzałeś napięcie po naładowaniu akumulatora ? Rozrusznik kręci ? Wklej błędy z VAGa.
VAG-COM Version: Release 311.2-N
1o9lo0m-n6r12p-o9ko4x-kkjahh-568f
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 907 401 D
Component: 2.5L V6 TDI G000SG 0007
Coding: 02015
Shop #: WSC 63251
00005059 130 106LC150_1.V79268198284
1 Fault Found:
01259 - Fuel Pump Relay (J17)
31-00 - Open or Short to Ground
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04455
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-00 - -
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 L
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 05311
2 Faults Found:
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
01206 - Signal for Duration of Ignition: OFF
27-00 - Implausible Signal
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 00000
No fault code found.
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00042
Shop #: WSC 00000
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 J
Component: KOMBI+WEGFAHRS. RB4 D28
Coding: 00001
Shop #: WSC 05311
07699 AUZ6Z0B0107264
2 Faults Found:
01128 - Immobilizer Pickup Coil (D2)
35-10 - - - Intermittent
00668 - Supply Voltage Terminal 30
Address 37 -------------------------------------------------------
Controller: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0008
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AF
Component: Komfortgerát T03 0316
Coding: 06976
Shop #: WSC 05311
2 Faults Found:
01561 - Left Rear Door
61-00 - Won't De-Safe
01562 - Right Rear Door
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 25445
1 Fault Found:
07-10 - Signal to Low - Intermittent
Address 56 -------------------------------------------------------
Controller: 8E0 035 195 C
Component: symphony II NP2 0151
Coding: 00011
Shop #: WSC 51314
Address 76 -------------------------------------------------------
Controller: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D07
Coding: 00114
Shop #: WSC 63251
End -------------------------------------------------------
nic nie kreci robi tylko " cyk" i tyle co robi..nie sprawdzalem bo niewiem gdzie..
....czy aku jest na pewno naładowany? sprawdzałeś samo napięcie czy też jego pomiaru dokonywałeś pod obciążeniem? po tym co opisałeś jak dla mnie to padł akumulator - spróbuj wstawić na próbę inny, od tego bym zaczął:wink:...
Sprawdż klemy na akumulatorze bo masz za małe napięcie i chyba nie masz dobrego przejścia.Przeczyść papierkiem i posmaruj pastą miedziową lub wazelinką.
auto niechialo odpalic nawet na podlaczonym prostowniku..dziwne jest to ze w aucie juz wszystko dziala bez problemu swiatla radio itd itd..
zaraz ide pokasowac bledy i zobacze ktore pozostaja i tutaj je wkleje..zrobie to z klemami..
...wstaw na próbę inny akumulator :wink:....
Jak masz VAG-a to podepnij go sprawdz w nim napięcie na akumulatorze.
a jak to spradzic?..wiec tak wsadzalem akumulator z innego auta 60tke ..ja mam 100tke..i tez cyka nie odpala..przeciscilem klemy na aku i kable ..przeciscielm mase laczenie z buda..itd..i dalej nic..;/.. dziwne bylo to ze dzis rano odpalil na chwile ..pochodzil..zgasilem go by odpalic jeszcze raz i juz nie zapala;/....niewiem ocb..;/.
niewiem ocb..;/.
....w tej sytuacji wypadało by się chyba przyjrzeć połączeniom przewodu + przy rozruszniku jak i samemu rozrusznikowi, to "cykanie" o którym piszesz powoduje tzw. "bendix" równolegle uruchamiając rozrusznik (jak jest wszystko ok to cykania nie słyszysz, ponieważ od razu startuje rozrusznik)...
Czy przy próbie odpalenia silnika mocno przygasają kontrolki w liczniku.
nie przygasaja wcale..akumulator dobry bo sprawdzalem na urzadzeniu ...
---------- Post dopisany at 17:03 ---------- Poprzedni post napisany at 17:02 ----------
Ten 60 jest za słaby do rozruchu 2.5 V6 , niestety AKU powiedział papa :kwasny:
a ogolnie do v6 tdi jaki powinien byc fabrycznie? 100 to nie za duzo?
chlopaki lekka zmiana...wiec tak...
akumulator jest dobry ..sprawdzalem ..
klemy czyste
masa do auta czysta jest okey..
teraz tak..
jak wsadze kluczyk w stacyjke i czekam az swiece sie nagrzeja to auto robi "cyk" i tyle co robi..
jak wsadze kluczyk w stacyjke i natychmiast przekrece to odpala idealnie..
jakies propozycje co to moze byc? zwarcie na swiecach czy co?
---------- Post dopisany at 14:25 ---------- Poprzedni post napisany at 14:24 ----------
klemy czyste
teraz tak..
wieczorem pokasuje bledy i wkleje te co pozostaly ..
